Ayaw gumana nung heater namin ngayon.. Feeling ko kasi humina water pressure sa amin. May work around ba don without voiding the warranty?
Bought an aeg water heater sa ace hardware at php4400 with the 10+10 % discount. Sana tumagal din sya.
Sent from my SM-G920F using Tapatalk
Would not want to tamper with that pressure switch ... setting it to allow lower water pressure might cause the heater to, um, overheat and possibly cause a fire ... better to install a pressure tank ...
Ah yun pala explanation non. Thanks! Now the question is pano ko siya magagamit ulit. Hehe. Pressure tank? Magkano kaya aabutin non and baka kelangan pa ng mga plumbing?
Sent from my Flare_S4_Plus using Tapatalk
it might be more expensive now.
a non-deep well-type, italian 1 hp electric pump/motor alone, already costs 10K in SM. a weaker motor will cost 7K, but i do not know if it can generate the appropriate pressure.
magkano na ba pressure tank ngayon?
there are several ways you can up your house pressure, po. and they will all have to depend on your water supply. questions like, "is your water supply reliable? tumitigil ba? continuous throughout the day? etc etc."
Guys meron ba specific na shower hose para sa hot water, yung naka connect sa outlet ng water heater na dapat heat resistant?
Yes. Bendable type yun not yun binebenta Sa ace na nga flexible.
Yun original na nilalagay Kasama ng heater page mag install Sila.
Yun ordinary na flexible na parang braided pay tagal nabubutas.
Parang ganito pero stainless Sa natin Hinde copper.
Thanks shadow. San kaya makakabili non ang kailangan ko ay 1.5 meters ikakabit ko sa hand shower?
AEG. Puwede na ba yung nabibili sa mga hardware?
i bought my cheap, generic rubber hose with matching plastic basic shower head, from the mall. it was the cheapest on the shelf. it's not even "marketed for hot water". it's been over five years now, and still going strong.
don't worry, po. at the temperatures we use, it's more heat-resistant than our bodies.
i don't like the metal ones. they're too... terminatoresque.
Hinde Pala tayo nagkaintindihan yun sinabi ko Sayo na bendable nilalagay Sa water heater mismo and I'm talking about multi point heater.
Sayo pala.yun na nakasabit sa shower head and youre talking about telescopic shower head.
Ops sorry di ko pala naexplain na yung hose para sa hand shower ang kailangan ko.
Good day everyone. Im planning to install water heater in my house. Which do you think is better? Install a solar water heater? or Install a multi point electric water heater? By the way, i plan also on installing solar panels to defray cost of electric consumption. Your inputs will be highly appreciated. Thank you.
