Quote Originally Posted by kotiko View Post
Has anyone here installed a different shower head connected to those wall mounted water heaters? Specifically those rain shower ones.
I'm planning to retrofit one of those fixed large rain shower heads (maybe one between 10" to 15" depending on the price and quality), a guy from home depot told me its possible by using one of those T pipes.
Anyone got any experience?
What's a good rain shower head brand that has good quality?
Thanks!
Thanks!
it's easy to attach.
if you are a handyman of sorts, you can do it yourself.
or you can hire a good tubero or all-around handyman.
a problem might arise, if your wall-mounted heater has a limited gallon per minute capacity. it might not be able to supply enough heated-enough water, for you to fully enjoy your large head (errr.. showerhead, sir).
some product shower heads may indicate in the package the minimum required gallon per minute requirement...
also, is your water source powerful enough to supply your system's needs?
the wider the showerhead (more holes), the stronger the needed pressure..
good luck.
