Want to see how you measure if your car uses less fuel here's a sample on a 1.9TD VW OBD-2. These system are very cheap and if a 18 year kid can get one and do it why have none of these companies selling these kits able to do it???
Water alcohol off
Water alcohol on
Seriously how hard is that?? 6 years and you can't present simple tech facts like this to the world. Or answer basic questions. Try not to forget about the amount of what your bubble produces vs how much air the engine is consuming, I need to remind you guys of this again because you cannot answer the quetion.
Here's anouther example. Old Pajero picking up 27% increase in hp and 20% increase in torque please explain even with these gains why fuel economy reported by the owner is only about 10% better? No HHO kit can even come close to these numbers Period. You can't better economy if you can use less fuel at a lower load to produce the same power level that is a Fact you guys can't wrap your minds around.
Here is the emission test for that vehicle. I challenge you to produce any non common rail turbo diesel that is lower.
You guys like to talk about being green and making less emissions when the means has been around since the 1930s and it's already proven.
