Using water in vapor or steam form as supplemental fuel to improve engine performance and reduce pollution is an old and suppressed technology. Using a carburetor that will vaporize gasoline very well that allow a car to run more than 150miles per gallon of gasoline is an old and suppressed technology. Why suppressed? Some people just do not like that you'll get fuel from almost free resource like water. Some people do not want you to use gasoline/diesel/lpg/kerosene efficiently that it will significantly alter their business plan.
Technically, anything can be use as fuel and the only requirement is that you have to transform your raw fuel material to something that your current engine design can take. Water can be used as a supplemental fuel for your gasoline/diesel/lpg/kerosene engines. The minimum requirement is that you have to convert liquid water into vapor for better mixing with your primary fuel and the required air.
With current internal combustion engine design in our cars, it will only accept vapor mixed with air as fuel. The challenge for us is how to manage the conversion process to vaporize our liquid fuel. Car manufacturers did not give you their best designs for fuel efficiency and only give you a system that do not do well. That is why you do not get a car that can run 40km for every 1 liter of gasoline no matter how you lighten your foot on the accelerator pedal on a highway. Car manufacturers already solved the fuel efficiency problem long time ago but did not release it for public use. Search the US patent database if you want to know and want documented tests and results of these designs. Just don't be lazy reading, the truth is out there in the open.
If you have something to contribute on how to make use of water as fuel or as a supplemental fuel for your gasoline/diesel/lpg/kerosene, please share your ideas. Each car needs some improvement to reduce the pollution it produce everytime we use it. We all share the same air and share the same planet. When someone is helping reduce the pollution from their cars or combustion engine, be intellegent enough to recognize that he is helping you breathe some less polluted air. He is also giving you ideas that does not cost you an arm and a leg and that you can use these ideas and knowledge from hard work of experimentation to improve your car and minimize expenses on fuel. We need more people to participate and do their part in stopping the pollution from our cars.
When you have nothing to contribute yet, better listen and stop claiming anything as scam when you have not tested it yourself first hand. You're not helping that way. We have seen and do these experiments first hand, we use water as fuel, we do electrolysis of water and make use of its output as supplemental fuel to improve engine performance and at the same time reduce pollution. We no longer change our engine oil, the longer we use our car, the better it will perform. When you have not done anything like it before, better start doing something now and don't be surprised later when you unlock your car potential that it perform better like never before. This is not a scam, we live with these technologies everyday, we are able to help hundreds of cars improved their performance and reduce fuel consumption and pollution.
When the fuel prices went up, who are left behind? People who have no access to these improvement like using water as supplemental fuel and people who instantly dismissed the technology. We were not greatly affected by the fuel price increase for we have improved our fuel efficiency and our cars performed better than before. The facts are out there in videos. The technology is out there in the open. It is for you to act now and do your part.
The only scam here is people who claim something does not work and yet they themselves have not tried it first hand.
