Page 6 of 7 FirstFirst ... 234567 LastLast
Results 101 to 120 of 134
    Jan 2004
    #101
    ok. thanks. i think i'll have to read more with PPOE.
    Jan 2004
    #102
    anyone here use a SmartBro and Linksys WRT54G setup? madali lang ba i-setup? kasi yung sa Netgear madali lang i-setup.not sure if sa linksys, ganun din... thanks.
    (sorry, tamad ako mag browse sa mga earlier post).
    Dec 2004
    #103
    *boybi: Globe Broadband, actually, is PPPoA. Not much different from PPPoE, except that the modem should be the one handling the password authentication churva, yung router connect lang sa modem (if not using a modem-router).
    Quote Originally Posted by ian_rex View Post
    For SmartBRO(ken), just use "Obtain IP automatically" or "use DHCP" or whatever it's called. No special password ek-ek.
    Jan 2004
    #104
    thanks. anyone here familiar with Netgear Storage Central? i mean, i've been reading their white paper. but they didn't indicate whether it will need a typical hard drive (ATA100/133) only that they indicate IDE ATA6. ano ito same lang ba ito with ATA133? thanks! i'm interested in acquiring network storage system...
    Dec 2004
    #105
    actually MAC Filtering is easier to implement... and gives slightly faster network transfer rates.
    But MAC filtering is NOT secure. The best it can do is prevent the Joneses (or dela Cruzes) next door from downloading pr0n off your connection. Your machines constantly send out their MAC addresses to identify themselves on the network. Anybody can sniff out these packets from the airwaves, and use a surprisingly common feature in OS network drivers to "spoof" their own machine's IP addresses, and gain access to the network anyway.
    Also, all MAC filtering does is prevent any unknown machine from access to the AP itself. It doesn't prevent any rogue computer from eavesdropping through the airwaves, picking up passwords and other sensitive data. Overall, MAC filtering is only useful for a small network that are strictly used by the same machines every time.
    I don't recommend MAC filtering by itself, you have to use it in tandem with WPA2 or some other strong encryption. WEP is useless, but MAC filtering by itself is even more useless.
    Dec 2004
    #106
    According to my Google searches, ATA6 should be a parallel standard. So, yes, ATA100/133/(66/33) would work.
    Jun 2006
    #107
    * Ian_REX: if you are downloading a lot of stuff from web or bit*******, you may be interested in a NAS that can download it for you. freeing you from expense of a 24-hr operating PC. It also serves as an iTunes music server.
    ASUS ang brand e. nakita ko lang sa mga offers sa akin.
    #108
    mga bros...
    last night nagloloko ang connection ko...as in super bagal pero may connection naman, ginawa ko pinatay ko yung router via switch dun sa router mismo, after than naghanap yung wLan ng laptop ko at nahanap naman niya yung linksys ko pero hinda yun secure connection na in-assign ko... open source na siya..
    nung nag click ako sa properties naka X yung unang connection ko...
    question
    1. pano mabalik yung unang secure connection na ginawa ko.
    2. maibabalik pa ba yun? o i have to do the ten steps again with the cdrom?
    3. automatic bang talagang gagawa ng unsecure connection yung linksys?
    #109
    baka nagreset to factory default yung linksys mo. i-setup mo nalang manually yang linksys mo for the security settings pero pwede mo rin ulitin yung 10-step na wizard.
    Jun 2006
    #110
    can't access my edimax wireless router config. When I type in the address, I go to google or sometimes to IE can not open the page...
    This happened after I was trying to improve my securtiy by implementing MAC Address filtering and changing the SSIDS. When I changed the SSIDS, I got the connection problem and was not able to complete it.
    The thing is my internet and network still works. I can access my router and connect to the internet without problems. Just can't open the config page. I already tried clearing my cache but its still the same.
    Jun 2006
    #111
    Found out whats wrong. My ip address is not the same as the Edimax wireless router. Its not the usual 192.168.2.1 I don't know why and what is causing it.
    I have my TCP/IP set to obtain IP address automatically. I tried to do the ipconfig/release, ipconfig /renew but it still gets a different ip address. Everything else works fine its just I can't access my routers config page which I need to do.
    pls.
    Also, how do you configure Windows firewall or the routers firewall not to respond to ping?
    Jul 2006
    #112
    probably a reset at the back of the router is the only solution to your problem.
    Sep 2004
    #113
    Quote Originally Posted by userfriendly View Post
    on win firewall. go to advanced, then highlight the net connection, click settings, then click the ICMP tab. uncheck the "allow incoming echo req."
    on a router. we normally block icmp protocol, or port 0.
    #114
    ...Also, how do you configure Windows firewall or the routers firewall not to respond to ping?
    Is there any advantage to unchecking the "allow incoming echo req" option? Also, are there any potential disadvantages or drawbacks to doing this?
    Jun 2006
    #115
    Quote Originally Posted by mikmik316 View Post
    I tried this. It worked but after sometime, I got the same problem again. What can be causing it?
    Quote Originally Posted by kingkaboodles View Post
    I treid unchecking the "allow incoming echo request" but it won't let me uncheck.
    Nov 2006
    #116
    userfriendly, do "ipconfig /all" at the command prompt (before doing it be sure that ur connected in the network). Look into the LOcal Area Connection, write down the IP address there (example: 169.254.1.100), now open ur browser type in 169.254.1.1 (just copy the whole thing and replace the last digit with 1) then Enter. You should be able to access na your config.
    The config address changes according to the IP address range that u specified in the router (192.168.1.100; 169.254.1.20), just remember to replace the last digit into 1.
    FYI: The default is 192.168.1.1 for Linksys, 192.168.0.1 for D-Link; but if you change the IP range in the router they follow ur IP range.
    Another, based on your comments I think your using a wireless laptop to access ur config. It is also possible that in your router config, u could have disabled the "COnfig Access through Wireless" it means u have to be wired to access the config/setup.
    Sep 2004
    #117
    try to logon on your XP using the "Administrator" username. If you're using the welcome screen, just press 'ctrl+alt+del' to get the oldschool logon screen.
    Jun 2006
    #118
    Quote Originally Posted by CPY61 View Post
    Thanks it worked. You were right on both.
    Unfortunatly, I renamed the administrator username to something else as a security measure. Now even when i'm logged on using this name, I can't uncheck it. Oh well ......
    Nov 2006
    #119
    No problem bro, im glad i could be of help. Sorry I cant help u with the Win Firewall, never used it (I use ZoneAlarm - its better than Win FW) - if u go to pcworld maganda ang reviews sa ZA.
    #120
    tech gurus
    i keep getting this on the #10 step wizard sa linksys
    "the router cannot establish an internet connection" chuva....
    pero kapag direct connect meron akong signal... at ambilis pa...
    DCHP lang din gamit ko kasi sabi dont change if you're unsure
    oo nga pala may reset button sa likod ng router...dapat bang press ko yun kung mag re configure ako (aka 10 step wizard)
techie tsikoteers, need your help- setting up a wireless home network
