Results 1 to 15 of 15
    Aug 2007
    guys i have a pldt dsl plan 999, dati pa sakin to nung nagaaral pa ako mga 3 years ago at ang speed niya is around 380+ kbps, sa u******* kasi ang average download speed ko is around 3-10 kbps lang, madalas magfluctuate at minsan naman a couple of seconds lang ako nakakakuha ng mataas na around 15 - 40 kbps, any tips you can give me to increase my average speed to atleast 20 - 30kbps? thanks.. by the way kahit ano idownload ko kahit lumang anime series or bagong movie kahit gano kalaki yung file laging ganoon lang ang average speed ko.
    Jun 2006
    1 check your download and upload limits. Baka masyadong mababa.
    2 try downloading files with lots of seeders
    3 go to www.speedtest.net and check your actual internet connection speed. If a lot less than what you should be getting call your service provider.
    4 do you share internet conncetion woth others? If you do they may be downloading too
    assuming your connection is 100% fine.
    factors:
    1. number of seeds
    2. public/private tracker (if private, needs ******* community membership to get more out of it, rather than rely on DHT alone)
    3. download vs upload bandwidth struggle. limit your upload speed. if your connection is 384kbps. the best global upload max speed setting is 38kbps. so your download speed will exceed pass through 38kbps
    4. Luck. If I'm not lucky on u******* at first. I switch to old ******** ver.70
    u******* is the best client when it comes to DHT (trackerless) and small memory consumption. while the old ******** is a notorious leecher and kuripot sharer.
    when still not lucky, get more lucky chances by downloading more titles at the same time, let's say 4 titles simultaneously. it may take each title to take even longer, but you will get your max speed. prioritize which title you prefer to have the best bandwitdh allocation share.
    public Ip users like smartbro is lesser lucky, but maxing ******* download speed is still achievable.
    Jul 2005
    add din, check tips on port forwarding. google na lang po.
    oo nga pala, you can manualy add trackers. sometimes same ******* file are uploaded but with different trackers.
    ito yung ginawa ko ngayon sa disney's enchanted *******. daming peers but sobrang bagal... kaya hanap ako ng similar ******* with same file and add those trackers...
    Jan 2003
    Quote Originally Posted by rion View Post
    This is good advice. Search engines like www.********.com provide you with all known trackers for the file you searched for.
    Sep 2006
    sir paano mag add trackers manually? gamit ko kasi u*******
    Aug 2005
    Quote Originally Posted by vanjo View Post
    Besides userfriendly and rion posted, try mo din i-limit queue settings down=1 up=1
    May 2005
    open your router's port forwarding.
    Jul 2006
    Try mo 'to sir, sa akin yan ang setup ko ok naman mabilis siya
    [ame="http://youtube.com/watch?v=NVq2GkzNrY8"]YouTube - Make U******* FASTER![/ame]
    try downloading on piratebay. madaming seeders dun :pirate2:
    May 2007
    If you're using Windows XP, meron siyang Half-Open TCP Connection limitation which causes some problems with P2P programs. If this is so, you should also try to remove this limitation.
    Quote Originally Posted by Langabe View Post
    > first, you need to find another ******* and has the same file name and contents and file sizes.
    > copy those ******* trackers via ******* properties (advanced option)
    > trackers looks like these:
    > paste it in your ******* properties
    there are also public trackers that you can copy paste without looking it up for similar ******* like piratebay's tracker and tracker.prq.to
    Aug 2005
    This tweaking works. Just tried it last night. Follow the entire procedure including patch.
    http://triponic.com/guidestutorials/...rent-settings/
    bro reklamo mo yan sa pldt, ganyan din yung speed ko dati eh... kailangan at least 200 DL speed mo sa speedtest.net. connect to singapore.
pano pabilisin ang download sa u*******?
