Results 1,471 to 1,480 of 1687
- 54,205
June 4th, 2021 07:48 AM #1471
June 4th, 2021 07:56 AM #1472
June 4th, 2021 11:10 PM #1473
You'll need an exhaust fan at the end of that tube to suck the hot air out ...
June 4th, 2021 11:39 PM #1474
For short lengths like a few meters, no need. The fans used in outdoor A/Cs are static pressure optimized with their wide blades and steep pitch angles.
There will be some losses in efficiency for sure, but specific to the guy's issue, the fact that it's going to pull in fresh/cooler air with the ducting installed makes up for the loss and he'll end up with a net-positive efficiency compared to the current setup.
To further reduce this loss, it's also best to keep the ducting as straight as possible.... no sharp turns or hairpins.
June 5th, 2021 12:05 AM #1475
June 5th, 2021 01:27 AM #1476
- 54,205
June 5th, 2021 08:11 AM #1477miss X,
your papa is right.
perusing carousell,
just the cost of the ducting, depending on the type, them ductings can be very expensive... thousands if the diameter is big...
it might be cheaper and longer-lasting in the long run, if the unit were relocated, instead of running that ducting...
i am now curious,
how come your papa knew?Last edited by dr. d; June 5th, 2021 at 08:44 AM.
June 6th, 2021 09:14 PM #1478
June 6th, 2021 09:21 PM #1479
UPDATE: Salamat po ulit sa mga input.. Ok na po mga Sir, sa halagang Php 6,500 hindi na namin tinawaran.. Na-relocate na po outdoor unit, nalinis na both indoor and outdoor, nadagdagan ng freon.. Balik lamig na sya [emoji4].
Sabi nung gumawa, baka yung last na naglinis ng aircon namin, binawasan yung freon kasi hindi niya ma-solve yung leak.. Resulta humina ang paglamig.
Umaliwalas pati ang garahe. [emoji41]
- 54,205
June 6th, 2021 10:20 PM #1480
Personally, I'd sooner keep a donut spare tire in the trunk than use a tire sealant. Trust me. I...
Liquid tire sealant
