Page 144 of 169 FirstFirst ... 4494134140141142143144145146147148154 ... LastLast
Results 1,431 to 1,440 of 1687
    #1431
    Saklap.. may issue aircon namin.. Overheat yung compressor, kasi nilagyan bubong yung garahe andun sa sulok yung pwesto nya.. Walang ventilation, 1st summer na meron bubong yung garahe.. Buti hindi naman sira, pero kailangan irelocate sa taas para dun sa open area..
    Ang laki ng kuryente namin, umabot ng 8K+.. Yung normal 3.5K to 4K lang.. Inabot 11K ang quotation para ma-relocate ang compressor.. Magpapa check pa ako sa iba, duda ako sa quotation (kakalinis lang ng aircon last month).. Baka kasi sinamantala napaka init kasi.. Pero good thing hindi ako siningil kahapon sa inspection.. Hehehehe [emoji1308][emoji16] Php 350 din ata yun..
    EDIT: nagagamit naman namin pero dating 21 hours, 12 hours na lang baka kasi bumigay pag isagad.. 9pm to 9am lang nakasindi ngayon.. Hindi pwede kapag sobra init, baka dun bumigay yung compressor..
    Mag update ako kung happy ending itong issue ko.. [emoji16]
    in truth,
    i do not understand the architectural situation.
    and what is "system reprocess" ?
    May 2019
    #1432
    in truth,
    Tinanong ko din Doc lahat nung items dyan kaya ako nagdududa hindi ma-explain sakin nung babae na customer service nila..
    Lalo na yung System Reprocess na 4,800.. Ang mahal di niya ma-explain..
    Natawaran ko hanggang 10K lang daw.. Hmmmm [emoji848]
    Mar 2021
    #1433
    Alam ko sa System reprocess is dismantle existing tubings like copper pipes, power cable from the indoor to the outdoor unit. Then reconnect ulit and lagyan ulit ng freon.
    Mukhang need irelocate ang outdoor unit ni missx kasi nagooverheat sa enclosed space.
    Mahal nga if 10k! Usually 7k if maginstall new aircon naman.
    Missx, baka may bracket na kayo para makatipid. At wag na general cleaning kasi kakaclean lang naman.
    #1434
    i imagine,
    re-install is more expensive because one need remove the old one, before the new one can be placed.
    installation is usually cheaper because one need not pay for de-installation of the old system.
    Mar 2004
    #1435
    7T installation fee is usually subsidized ...
    May 2019
    #1436
    Same din ng binanggit ko sa kanila.. May bracket na existing na, kakalinis lang din, tapos yung indoor unit gusto ibaba ng kaunti mga 2-4 inches lang naman para hindi daw dikit sa kisame.. Feeling ko naman walang masyadong maitutulong yun sa sobrang init and poor insulation ng bahay namin sagap pa din nun yung temp ng ceiling.. Parang naghanap lang ng ipapagawa pa para dumami.. Mamaya magpa-second quote kami sa iba naman..
    Sep 2012
    #1437
    Mahal yan sobra as I see it kasi walang detail ng system reprocess
    Tanungin mo
    1. may idadagdag ba sila freon?
    2. Papalitan ba copper tubes lahat and if mag exceed ba ng 10 feet?
    Sa new installation ng unit 500 per feet in excess of 10 feet ang charge sa additional copper tubing so it doesn’t make sense.
    Yung dismantling fee sige pagbigyan mo na pero yung old brackets mo gagamitin dapat and need lang bagong screws
    May 2019
    #1438
    Quote Originally Posted by jodski View Post
    Tanungin mo
    Binanggit nga din nung nag-inspect na walang idadagdag sa tubing kasi itataas lang naman yung puwesto.. Sa freon, magdagdag nga daw.. Kung siguro na explain lang sakin yung details, maiintindihan ko naman ng kaunti siguro kung bakit mahal..
    Thank you pala sa mga additional inputs.. Mag-update din ako kung maging ok na after 1 month kasama na yung kain sa kuryente [emoji846].
    Sep 2012
    #1439
    [emoji2357] get a second opinion na if ayaw mag declare ng maayos
    Usually dagdag ng freon is less than 2K and up sa iba depende sa klase and dami ng ginamit
    Jun 2005
    #1440
    in truth,
    Systen reprocess is the fancy term for "aircon flushing" in the automotive aircon scene.
    Lalagyan ng panlinis, carbon tetra and like para malinis yung loob na piping then flush out old oil, vacuum, refill.
    Sent from my MI MAX 2 using Tsikot Forums mobile app
Split Type Aircon: Which is best?
