Page 148 of 169 FirstFirst ... 4898138144145146147148149150151152158 ... LastLast
Results 1,471 to 1,480 of 1687
    #1471
    Maybe you don't need to relocate the outdoor unit if there's enough headroom space to install a flexible air duct. That will prevent the hot exhaust air from looping back into the intake.
    Something like this... but with the air duct hanging from the ceiling.
    looks like a good idea.
    it won't be pretty, but i think it will work.
    #1472
    I don't mind bringing food, just like last time.
    [emoji3]
    missek, si archer for sure makakaayos nyan. kain nalang ako popcorn habang nag survey sya
    Mar 2004
    #1473
    You'll need an exhaust fan at the end of that tube to suck the hot air out ...
    Jan 2009
    #1474
    For short lengths like a few meters, no need. The fans used in outdoor A/Cs are static pressure optimized with their wide blades and steep pitch angles.
    There will be some losses in efficiency for sure, but specific to the guy's issue, the fact that it's going to pull in fresh/cooler air with the ducting installed makes up for the loss and he'll end up with a net-positive efficiency compared to the current setup.
    To further reduce this loss, it's also best to keep the ducting as straight as possible.... no sharp turns or hairpins.
    nag hanap ako large diameter na ganyan but didn't find one big enough. ano diameter nakuha mo?
    Jan 2009
    #1476
    I don't use one. I just posted it as a possible solution.
    #1477
    miss X,
    your papa is right.
    perusing carousell,
    just the cost of the ducting, depending on the type, them ductings can be very expensive... thousands if the diameter is big...
    it might be cheaper and longer-lasting in the long run, if the unit were relocated, instead of running that ducting...
    i am now curious,
    how come your papa knew?
    May 2019
    #1478
    miss X,
    your papa is right.
    perusing carousell,
    i am now curious,
    Tinanong ko papa ko bakit niya alam.. Basta alam nya lang daw.. Hahahahahaha [emoji23] tinamad mag-explain..
    May 2019
    #1479
    UPDATE: Salamat po ulit sa mga input.. Ok na po mga Sir, sa halagang Php 6,500 hindi na namin tinawaran.. Na-relocate na po outdoor unit, nalinis na both indoor and outdoor, nadagdagan ng freon.. Balik lamig na sya [emoji4].
    Sabi nung gumawa, baka yung last na naglinis ng aircon namin, binawasan yung freon kasi hindi niya ma-solve yung leak.. Resulta humina ang paglamig.
    Umaliwalas pati ang garahe. [emoji41]
    #1480
    reminder lang po, in case lang naman,
    gawan nyo ng doghouse o bubong. proteccion laban sa ulan.
Split Type Aircon: Which is best?
