Page 6 of 14 FirstFirst ... 2345678910 ... LastLast
Results 101 to 120 of 279
  1. FrankDrebin Guest
    #101
    Turbo-prop is not old for Philippine Standard anyway. Go for it!!:D
    Mar 2005
    #102
    swedish stealth ship.
    #103
    here's another site of the super tucano showing the intruments and night vision gear for the pilot...
    http://www.aviationweek.com/shownews...e/topsto02.htm
    Aug 2003
    #104
    Diesel-Electric subs are only usable in shallow waters and for short operations only (great for defending ports & channels).
    Tell that to WW2 Grand-Admiral Karl Donitz, who sent U-boats into the Indian Ocean (the Monsoon Group).
    Their batteries will only last upto around 12 hours only (provided that you don't run at full speed) and afterwards they already need to use the noisy diesel engines to recharge them. In that process, they also need to snorkel for fresh air (although some newer diesel-electric subs have developed more advanced air circulation systems that will allow longer snorkel time intervals).
    Diesel-electric boats have changed a great deal since World War II. We're not talking about Type VI-C U-boats or Romeo-class boats here..
    German U-212/214 class boats with hydrogen fuel-cell Air-Independent Propulsion system:
    http://www.naval-technology.com/projects/type_212/
    Swedish Gotland-class diesel-electric boats have Stirling-cycle closed-loop air-independent propulsion and can go 3 weeks without surfacing. The US Navy rented the HMS Gotland from Sweden in 2005.
    http://www.naval-technology.com/projects/gotland/
    "In May 2005 the Gotland was leased to the U.S. Navy for one year, complete with Swedish crew. The Gotland will initially be based in San Diego, where the U.S. Navy will practice joint maneuvers with the stealthy AIP-equipped diesel submarine.[4] The vessel will later operate on the east coast of the United States. According to the Swedish newspaper Blekinge Läns Tidning, U.S. interest in the Gotland class was aroused during joint naval exercises when the U.S. Navy was unable to track the Swedish submarine.[5]"
    In this case, if a CBG suspects that a diesel-electric sub is operating in the area they can just deploy further from shore to limit the sub's effectiveness.
    The Los Angeles class of the USN is one of the best ASW (anti-submarine warfare) / CBG-escort submarines around. If that is not enough, the USN also has ASW aircrafts that can be deployed (Orion or Viking???). A new ASW aircraft is also in the works.
    the LA class is obsolescent.
    Many of the boats have already been retired and cut up. The Virginia-class SSN is the replacement.
    http://en.wikipedia.org/wiki/Virginia_class_submarine
    diesel-electric boats are quieter because they don't need reactor pumps. the only nuclear sub with passive cooling is the Ohio-class SSBN.
  5. FrankDrebin Guest
    #105
    I stand corrected by the Sub Guys! :D
    Anyway, I remember this old Sean Connery-Alec Baldwin movie-The Hunt for Red October, is that technology in that Russian Sub currently used nowadays?
    Aug 2003
    #106
    actually in the book, the "caterpillar drive" was just a ducted turbine (instead of a propeller). the current British SSN's (Trafalgar-class) use this technology (also known as "pump jet" propulsion -- same principle as a jetski).
    in the movie they changed it to an MHD (magnetohydrodynamic drive). which is currently not practical (only a few experimental Japanese boats -- as in boats, not submarines, not ships) have it. MHD has no moving parts but requires tremendous amounts of electricity. it basically moves seawater past the ship's hull using a magnetic field alone.
    #107
    The new gen diesel-electrics (with AIP) is still not yet widely used. Only the Germans & Swedish have a handful of them.
    3 weeks at the speed of 5 knots.
    As I've said... good for short / homefront operations only. They still need to refuel somehow after their diesel is gone.
    Plus, SSNs are more difficult to manage in shallow waters - that is why Diesel-Electrics will definitely have an advantage there (as I've said before). Plus, operating on homewaters will give them a very BIG advantage as they can blend in with local water traffic & even the environment.
    But for deep water operations - the SSNs will still lord it over them anytime.
    That is still up in the air. Although some LA class have already been decommissioned but the US is still contemplating on refueling some LA class to extend their service life (as the new Virginia is a bit costly at around $2B each).
  8. FrankDrebin Guest
    #108
    Hmmm, the German diesel U-Boats of WW2 terrorized the British at the Atlantic Ocean.
    #109
    Quote Originally Posted by FrankDrebin
    That just during the first few years of the war.
    Afterwards - it was a downward spiral for the U-boat.
    Watching The History Channel & Discovery is now paying off. ;)
    Dec 2003
    #110
    mga walking military encyclopedia ata kayo e!
  11. FrankDrebin Guest
    #111
    Is it that the Allies uses both its Airforce(Catalinas) and Navy(Destroyers) to flush down the U-Boats?
    Jun 2005
    #112
    Re: the myth about CBG (carrier battle group) invincibility. The soviets were practical in their military doctrines and they developed simple crude strategies which work. During the 60's up to the 90's all soviet made anti-ship missiles had 3 basic characteristics:
    1- OTH range (40 to 60 nautical miles as the americans would put it)
    2- accept mid-course guidance from a Kamov tandem rotor helo
    3- pack a 20 kiloton nuke warhead (minimum, some had 1-megaton nukes)
    haven't you noticed that practically all the soviet anti-ship missiles were nuclear-tipped up to the 90's (even those fired from fast attack boats) for saturation attacks.
    The idea was to launch a sea-skimmer from an OTH (over-the-horizon)position with the Kamov to correct terminal guidance from the horizon, arm the missile and guide it to the center of the carrier battlegroup. Once within the vicinity, detonate the nuke to wipe-out the entire carrier battlegroup. The soviets were not targetting individual ships, the nuke would take care of all the ships in the CBG.
    To address this, the americans brought out the ER (extended-range) variant of the Standard missile with OTH capability principally to shoot down the Kamov so it won't be able to provide terminal guidance, nor arm the missile and hope the missile would just go astray.
    Same principle with Warsaw Pact invasion doctrines. After the Berlin Wall fell, the soviet land forces hurriedly packed and went back home. In the central command base in Poland, NATO forces saw field manuals on how the Warsaw Pact armies would use tactical nukes of up to 5 kiloton neutron bombs since these had no blast damage, only enhanced radiation to kill all living organism and the neutron radiation would dissipate in minutes (electron radiation takes years to dissipate). As NATO admits, their villages are just 2 kilotons apart. (the a-bombs dropped in Japan during WWII were 2 kilotons).
    #113
    Quote Originally Posted by jaeger
    ahhh, ang alam ko ang hiroshima bomb 12 kT, ang nagasaki bomb 15kT.
    Dec 2003
    #114
    alin ba talaga? 2 kilotons seems too weak for an a-bomb..
    Sep 2005
    #115
    Grabe ... ang bilis humaba nitong thread, hehehe. Maghapon lang akong busy, bilasa na yung mga posts na sasagutin ko. Anyway, na-DIY ko na ang annual service ng harabas kong Civic. Pasado na siya sa safety/emissions test at bayad ko na rin ang Road Tax. Pulubi na naman ako, all in one day.
    * rhops - personally, mas gusto ko hardware nung WWII - aircraft and armor. Walang fly-by-wire, plug-and-play, point-and-shoot, hehe. Matira ang matibay. Although I hate their politics, I admire the skill of people like Michael Wittman and Erich Hartmann, and also Douglas Bader, Saburo Sakai, etc.
    Mga tanong mo na MBT's ngayon ... Challenger II (UK), Leclerc (France) and Leopard II (Germany). Germany and the US used to work together on the MBT-70 tank, but design thinking was really at odds so they separated and the US made the Abrams and Germany the Leopard I.
    * badkuk - The US did use helicopters in combat in Korea but not as widely and extensively as in Vietnam. They did a battalion-size insertion once behind enemy lines, that's the biggest ops afaik. Trivia: As early as 1938-41 the Germans were already testing helicopters for rescue of downed pilots.
    Tama ka sa plight ng mga beterano natin. The simple fact is, nung 1941-1945 hindi pa sovereign ang Pilipinas at ang sundalong Pilipino under pa sa command structure ng USAFFE, 'merkano pa leader, si dugout Doug.
    Mar 2005
    #116
    when you say kilotons, yun yun di-nrop o yun yun magnitude ng naproduce na bomb
    Sep 2005
    #117
    Quote Originally Posted by orly_andico
    Adding to this ... German U-Boats even made trips to Japan and back to Germany during the war, and so did fleet submarines of the Japanese navy made trips to Germany. On some trips, there were cargos like the ME-109. PAK-88, etc. even the ME-262 jet fighter during the closing stages of the war.
    Mar 2005
    #118
    Quote Originally Posted by badkuk
    hmmm...anong brand/model ung maliliit na helicopters na laging kalaban ni AirWolf dati? i think it's the same one sa BlackHawk Down -- the really small ones who were doing strafing support? swak na swak sa budget natin un
    eto ba yun MH-6
    yun minsan sa movies may naka-mount na chain gun left & right.
    meron ata tayo ng ganito, sa mga Lito Lapid movies mayrun hehehe
    Sep 2005
    #119
    Yes ... PBY Catalina's, B-24 Liberator's, Short Sunderland's ... basically any long-range aircraft the Air Force guys can give to close the air gap between Canada and Britain. This was closed by the addition of Greenland as a base and introduction of escort carriers (with Wildcats/Hellcats) into the convoy system.
    But none of it would have mattered if it weren't for the British invention, radar.
    Mar 2005
    #120
    correction AH-6 Little Bird pala kapag may naka-mount na weapons
    siguro puwede na 'to sa tin. can afford na nga natin ito ...
Military Hardware Thread [Split]
