Page 29 of 48 FirstFirst ... 1925262728293031323339 ... LastLast
Results 561 to 580 of 954
    Aug 2004
    #561
    Defender lang on all 3 machines. I also told my kids not to click anything suspicious. One even found a new browser with built in adblocker recommended by online playmates. So far no issues.
    Sent from my SM-A605G using Tapatalk
    Dec 2009
    #562
    Survey sa mga tsikoteers na windows ang laptop. Is windows defender enough for you or you replaced it with free anti virus or are you using a paid anti virus? Which one?
    Some anti-virus contain VPN function..so if you are into netflix or youtube which restricts availability of some videos to certain regions then its all worth it
    Sent from my SM-G532G using Tapatalk
    Aug 2004
    #563
    Our printer/scanner conked out years ago so I do all printing and scanning via USB at the nearest seedy neighborhood internet cafe. Nadetect naman ang virus from one of the shops and Defender quarantined it at once.
    Jan 2016
    #564
    Also stopped buying printers since our last one conked out. All my printers had the same issue of ink cartridge drying out as it is seldom used. Found it cheaper to just have it printed outside, hassle lang lumabas. And less clutter too.
    Aug 2019
    #565
    Bumii ako Huawei Matebook D14 na Ryzen 7. Sulit na sa 43k [emoji3]
    Jan 2009
    #567
    Can anyone help me tweak this "daddy" setup? This is my 24x7 Plex server, FWIW.
    CPU: E3-1285v4 (Broadwell). This was recently upgraded from an i5-4570 (Haswell)
    Motherboard: Z97-D3H
    Cooler: Noctua NH-U12P SE2
    GPU: IGP + 1050Ti (for transcoding)
    DRAM: 32GB DDR3 1600
    Other than the BCLK, are there tweaks I can do in BIOS to squeeze more oomph out of this Xeon? It's a locked processor, I know. Still...
    CPU-Z details: Intel Xeon E3-1285 v4 * 3573.39 MHz - CPU-Z VALIDATOR
    CB R23 results with stock config:
    Jul 2013
    #568
    KFC made a bucket-shaped gaming PC that warms chicken | Engadget
    the KFConsole could be a pretty speedy machine, as it’s equipped with an Intel Nuc9 Extreme Compute Element that we called “the new king of tiny gaming PCs.” It includes an ASUS-built hot-swappable NVIDIA GPU and Intel CPU (though Cooler Master didn’t specify which), along with a 1TB Seagate NVME SSD. Cooler Master claims that it’s VR ready, supports ray tracing and can handle 4K TV gaming and frame rates up to 240 fps.
    #569
    That's why we switched to a black & white laser printer. It's pretty much Use & Forget until the toner runs out (a year later).
    #570
    You can only do bclk with Haswell/Broadwells.
    Probably you can find a coffee lake or a Ryzen 2nd gen APU for cheap.
    Jan 2009
    #571
    Quote Originally Posted by mda View Post
    No can do. That will compel me to replace the board and all 32GB of DDR3 memory. Anyway, decided to keep it stock na lang. It's a server so I guess keeping it stable should be top priority.
    My main PC is a Ryzen 5 3600 * 4.2 all cores.
    #572
    For plex, overloaded na ba yung ganiyang setup?
    No experience using that but the IGP / quicksync should help a lot hindi ba? hehe
    EDIT: Remembered that the 1050TI and all the other NV consumer cards are limited to 2 simultaneous transcode streams before dumping the rest of the load back to the CPU...
    If that's your bottleneck, a quadro card or a driver hack (if exists for your OS/platform?) should allow more concurrent streams.
    Jan 2009
    #573
    Yup, I know about the limitations. I haven't found it necessary to hack the driver. Of course I've been waiting for a bargain P2000 to come along but after a couple of years, they're still expensive and hard to come by.
    Anyway, both the Intel Iris Pro Graphics P6300 (IGPU) and the dedicated 1050Ti, together with the CPU, do pitch in to do the transcodes. That said, Nvidia's 2-stream limit is not too big of an issue for me. At least, not yet.
    CPU, GPU 0, and GPU 1 utilization while plying 4 or 5 streams:
    #574
    Looks like that box can handle another 3-4 streams easy haha.
    Jan 2009
    #575
    True. But of course, it depends on the media and the playback device. In the test above, I forced all streams to transcode to force the CPU and GPU to work their arses off. In reality, however, if the playback device supports the media type, it will use Direct Stream or at most Direct Play.... which consequently consumes very little processing and is only limited by the storage IO.
    Anyone have monitor that can turn into portrait? I'm thinking of buying a cheap one for viewing source code.
    #577
    I used to have a Dell IPS monitor from long ago (U2412M) that I sometime use vertically for spreadsheets. The mount is rotatable for vertical and horizontal use.
    I gave it to my brother na, this is his current WFH setup:
    A used Dell IPS monitor is about 3k nalang these days.
    Thanks for the tip. I'll try to look for that one.
    Jan 2009
    #579
    Just sharing what I did with my old PC hardware... from E-Waste to E-Art.
    I still have a lot of old, defective, or otherwise obsolete hardware I might put up and make eyesores into something cool.
    Feb 2014
    #580
    pop the lid from the K6 turn it into a keychain
    meron ba dyan S3 virge 3d decellerator LOL
Computer and Laptop Tech Thread
