Page 39 of 48 FirstFirst ... 29353637383940414243 ... LastLast
Results 761 to 780 of 954
    #761
    ... how does one type on the laptop's keybord?
    You don't. You use the desktop KB.
    #762
    there must be a good reason why he's using a laptop there and not another monitor.
    Doc sa setup na yan wala naman ata siyang PC. Yung isang monitor pang dual screen niya
    The laptop is the main computer. The large monitor is a screen extension of laptop. The reason why he is using a laptop is because the laptop is his only computer/CPU.
    Aug 2004
    #765
    Ganda ng ganitong bracket. Isa lang bracket ng monitor at laptop. Pareho naka angat, ang linis tignan.
    Sadly hindi pwede sa kin. I have to change a lot of things on my setup and it would be expensive. Dapat talaga mag plano muna before building your WFH setup.
    Interesting. Pwedeng-pwede pa to sa home office ko. If my bunso asks for a faster monitor for himself then I'll inherit his current 24" IPS.
    First verify that you can remove the monitor stand and when you remove it there's no protruding bar below the monitor. That's one of my problem why I can't buy this.
    #767
    and the laptop can be bought to the office. i have a similar setup but no laptop docking station. 2nd monitor in the office and at home. too cluttered if working with the laptop monitor only
    It's also good on zoom meetings. I realized zoom has 2 screens, 1 is the camera focused to the presenter, another screen for the slides of the presenter.
    Aug 2004
    #769
    Checked the box and it is VESA compatible and wall-mountable thankfully.
    Sent from my SM-A605G using Tapatalk
    #770
    As pointed out, the laptop is THE computer. The other monitor is just an extension of the laptop screen. Kind of like attaching your laptop to a projector during meetings/presentations. He then attached an external KB and mouse using USBs. I use multi-monitors at home and the office. having 2 monitors is great even before the pandemic for me. You can edit a document in one screen, edit figures or run command-line scripts/codes in another. For online meetings, one screen can be the gallery of the participants or the speaker and the chat box, the other yours or the speakers presentation.
    Jun 2015
    #771
    May nabibili rin namang adapter/holder for monitors that don't have the rear screw holes. Magmumukha nga lang malaking cellphone holder.
    Sent from my PL2_sprout using Tsikot Forums mobile app
    Jan 2010
    #772
    Since work from home is over for us (bummer), I finally got to transform my former home office setup into what I really wanted it to be.
    Highlights:
    • Rig: Full mesh mid-tower case with vertical GPU mount, CPU air cooler, a couple of LED bars, 6 case fans, (they somehow all fit), and aRGB everywhere
    • Video: 34 in ultrawide + 24 inch widescreen (in portrait mode) both 1440p and an old GoPro Hero 8 (used as a webcam)
    • Computing: Ryzen 7 3700x, Radeon 6800XT, 32GB RAM (DDR4-4133 CL19), 2TB NVMe, 2x10TB HDD, 120GB SATA SSD, X570 mobo, Windows 11 and Ubuntu 20.04
    • Controls: Logitech G102 & G512 + Hori Fight Stick + Fantech mousepad
    • Audio: AKG studio headphones, cheapo BM800 mic, Edifier R2000DB stereo speakers, Hercules DJ Controller, One Odio DJ headphones, Behringer Q502 mixer+interface
    • Portables: MBP M1, MS Surface (old 5th gen), Samsung Galaxy Tab A (got this for free)
    Use-case: Adobe CC & Captivate, development, project management, amateur audio, and gaming, of course
    #773
    looking for an autocad friendly mid-level laptop locally. max budget is only 40k.
    scanning the net but no success! halos turo lagi sa amazon.
    any good recommendation? tia
    Jan 2012
    #774
    Autocad just needs at least 8gb of ram. An ssd would be nice to have though. Integrated graphics is ok if youre only doing 2d autocad work.
    I would just get whichever Dell, Asus, or Acer is the best value. Check Villman or pchub for laptops.
    Jun 2015
    #775
    MSI Modern 14 B11M-652PH - Laptop Factory
    MSI Modern 15 A11M-81PH 15.6" i5-1155G7 | 8GB | 512GB | Win1 – DynaQuest PC
    You could also opt for second hand on shops in FB.
    There's a better chance you'll get a higher specs laptop (Intel i7 or better) for your budget.
    For your budget, you'll most likely get an i3 and lower spec if brand new.
    Of course, the best option is still to go to the mall or brick and mortar store and pick the unit yourself. Dynaquest has physical stores where you can pick up the item yourself.
    #776
    Quote Originally Posted by viper888 View Post
    noted on the RAM min. reqmt.
    thanks bro... hirap din talaga maghanap ng medyo disente if you're on a budget
    #777
    Secondhand X1 Carbon for 40k:
    Log in to Facebook
    16GB RAM, i7 processor, crazy light, crazy good battery life.
    I have a similar laptop (also X1 Carbon but with 512GB storage and 2560x1400 display) - almost 3 years old but still handles my resource-intensive work very well. Tibay ng X1 Carbon and will last you 5 years easily, maybe 10 if you take care of it well.
    #778
    Log in to Facebook
    surely will consider this bro. thanks
    Mar 2004
    #779
    *jut
    Would the used X1 Carbon better than a new Macbook Air? ...
    Jan 2010
    #780
    *jut
    if the Macbook Air is an M1, it will run circles around the X1 Carbon. The video quality of the retina panel is much better too, heck, even the speakers sound better. The build quality is also better (metal vs plastic). It also is a lot quieter as the Macbook doesn't need a whirring fan.
    The Macbook Air M1 will probably get a huge sale soon since the M1 Pros have just been released. It's rumored that an all-new version is due out late next year, though.
Computer and Laptop Tech Thread
