Results 181 to 190 of 217
- Jan 2008
- 4,726
January 6th, 2022 03:26 PM #182i don't recommend lifting the car on the suspension arms lalo na sa macpherson strut design.. unless nasa ramp na using ramp aux lifter.. para sabay lift yung both sides..
sa macpherson kasi, yung suspension arms eh pang locate lang ng position nung front wheels.. yung bigat ng car eh nandun sa struts
pwede naman lift ang car sa sides.. may markers yan dyan kung saan yung lift points.. check your owner's manual nandyan lahat yan
regarding plug (pasak) thingy.. watch nyo sa youtube yung test na ginawa ni projectfarm kung ano yung effective na pasak product.. alam ko sa test nya may possibility pa din na sumingaw talaga yung pasak at pwede din mahugot ulit
- Jan 2008
- 4,726
January 6th, 2022 03:33 PM #183Best Tire Repair Kit? SLIME, Westweld, Dynaplug, Grand Pitstop - YouTube
eto yung video ni projectfarm
- 54,211
January 6th, 2022 04:39 PM #184
- Apr 2016
- 203
January 6th, 2022 05:05 PM #185
The old car Honda CRV 2004 has patches done to the 2015 Michelin tyres. So far ok naman so believe ako sa patches. Kala ko lang yun string plug nagamit sa kamuning sa Subaru ko is new tech (first time for me to see a string patch). The technician told me outdated na daw yun tangal pa tyre and open up rim to do patch. Mas modern daw just insert plug.
Anyway, I think Honda CRV Thailand edition pinaka worse na cars sa lahat 'no? Halos lahat na major parts na palit na many times. The radiator failed (nabutas) while I was driving, nasira brake fluid pump while driving, napalit lahat na suspensions 2 times, even the power steering rack and pinion na palit na, dati I kept adding steering fluid kasi nabawasan half of reservoir in one day.
Now the problem is the engine oil leak and coolant leak. I have to add engine oil and coolant every week kasi it leaks to my parking. Pero ang rami palitan almost 40k na repair if ma ayus ko oil leak. And mahirap mahanap coolant leak. The car is worth 120k now in used market kasi it used up gasoline so fast.
It's for coding use. Honda has replacement parts. Pero not Subaru. Sobra mahal parts ng subaru so ayaw ko mangyari yun nangyari sa Honda.
If I didn't stop them from using car lift on the suspension arms early this week, possible na bent na now suspension arms ko. This is why even though ayaw ko na mag post para matahimik na ako.. pero I learnt a little tips can save thousands of pesos of unnecessary damage and repair. Hence make sure ko hindi nila put car lift sa suspension arms.
After na change na all the 4 tires ng Subaru ko. Mag move on na ako. I hope LTO would soon require all tires more than 5 years old to change to new para ma force ako change all tires ng Honda ko which is now 7 years ago. Wala na talaga budget for now to change them. Maybe after mawala na Omicron and back to normal business na. Affected kami since early 2020 at dawn of pandemic
- 54,211
January 6th, 2022 05:11 PM #186i have a 2005 innova with over 140K km on it.
i have replaced the four shocks and two support struts of the rear hatch.
and oh yes! the front break disk. someone didn't recognize the warning signs of worn disk pad...
- Apr 2016
- 203
January 6th, 2022 05:32 PM #187Halos lahat na crocodile jack is used perpendicular to the running board diba? Mahirap ata parallel? Meron ka na kita reference na not advisable ang crocodile jack sa unibody jack points? Baka hindi payag gamit ng scissor jack yun tire shop bukas sa all 4 tires ko. Baka better to find tire shop with car lift and positions the lifter on the 4 jack points at same time 'no?
In the following video
Why did the crocodile jack moves and ruin the door, frame?
- Jun 2005
- 3,774
January 6th, 2022 05:39 PM #188Sabi mo nakaloan pa kotse mo? So safe to assume less than 5 years pa goma mo since brand nrw mo binili.
The mvis requirement is the least of your worries. Then again, just replace everything. Pati kotse kung pwedeSent from my MI MAX 2 using Tsikot Forums mobile app
- Jun 2005
- 3,774
January 6th, 2022 05:46 PM #189Parang panibagong alterego ni kags/OB ito.
Come to think of it, hindi pa sumasagot si kags dito ah
- 54,211
January 6th, 2022 08:15 PM #190dumulas? nag-collapse yung panel?
jack-er probably did not position it well-enough, or did not use the correct lift point.
it happens.
don't blame the crocodile. blame the user.
the crocodile doesn't care at what angle it is used.
it's up to the user to decide which works for him and the space available.
actually,
between scissors, bottle and crocodile,
the crocodile is argueably the easier and safer choice, in my opinion.Last edited by dr. d; January 6th, 2022 at 08:40 PM.
Dito sa pinas, daming dahilan kung bakit natetengga pero kadalasan niyan gusto lang ng pampadulas....
Makati Subway. Completion date: 2025
