Originally posted by ghosthunter
My most convenient time is when you have scanned and emailed the documents to me.
ghosthunter*tsikot.com
Don't complain... the guy from EGO also emailed his "supporting" documents the same way.
is that a wide band a/f meter or a standard 7 bar meter?
[/b]
So this proves that the device is NOT properly tested for reduced pollution! Basically this can be taken as an admission by you that the device is not tested for pollution.
[/b]
So this proves that the device is NOT properly tested for increased power nor increase fuel milage.
[/b]
I could use Jose_Rizal or George_Washington as my login name if that would change anything.
Given the two proven fakes who are giving positive testimonies for the device in question, I find difficult for find trust and honor. [/B]
Sir,
sige po email ko sayo lahat ng docs supplied to me by IIC.
alin po ba ang mas maganda, wide band or ung standard 7 bar?
Sir, i'll email you the doc that proves it was properly tested. sa Taiwan po ung emission testing para walang "lagay"
Increase in HP po wala po akong nabasa sa mga docs na binigay ng IIC sakin. Fuel mileage po, ung doc na Ford Makati Test Results ang e-email ko sa inyo.
Sino po ang tinutukoy niyo na "proven fakes"?
thanks & more POWER!
Odee
