Page 12 of 37 FirstFirst ... 2891011121314151622 ... LastLast
Results 111 to 120 of 364
    #111
    Originally posted by niky
    So I take it Mr. Rajuta's so-called testing results are likewise in question?
    Good point...
    So that means his so-called positive results have to be faked... which can be concluded that the product CANNOT hold up to its claims... otherwise, why produce FAKE people to say something positive about your device?
    #112
    awwww....sayang ganda pa naman ng discussion.
    some people talaga cannot help but resort to making fake people just to prove their losing points...
    haaayyyyyyyyyyyyyyy
    #113
    well there is still the other thread... hehehe
    http://tsikot.yehey.com/forums/showt...0&pagenumber=7
    Jul 2004
    #114
    ghosthunter/glennster,
    with regards to the claim that raijuta is a fake person with a fake results, im sorry that i have to say your wrong. beleive it or not, we both got our device and have it installed by a single distributor/dealer.
    i see the same result as he claims though not that high gain due to variation on driving style. also he owns A/T while i have M/T both 1.6L engines.
    btw, thank for the info you gave. quite happy that im getting info from third parties. this is really big help.
    with the concern on the possible emmission of NOx, i guess the test results from Ford and DOE would be enough to say that this complies with Safety Measures.
    Jul 2004
    #115
    for this statement:
    "A vacuum meter is used to monitor the amount of negative pressure (suction) in the intake manifold. A vacuum meter reading is used to diagnose a variety of engine problems, from a blown head gasket to worn valve guides. It also can be used to monitor fuel economy, with high vacuum readings indicating good fuel economy and low vacuum readings indicating poor fuel economy."
    now im quite confused, how come both of us (raijuta and myself) are getting good result in terms of fuel economy with the low vaccum reading as compared to high vaccum reading before installationor khaos? any idea?
    Sep 2004
    #116
    Hi everyone...what I did was really wrong and I apologize for this....Sir moderator sorry for doing this...
    Well we are really just testing the device...and dont want to prove anything...if you want it..get it..it doesnt work for you...return..it...again..I apologize for the trouble this may have caused..
    O continue na discussion......natin tungkol dito...sayang naman maganda ang topic...as blue gsr said..meron ba tayong pwedeng makapagtestingan ng A/F mixture...actually 2mm of HG ang minemaintain na pressure nung device...medyo mababa nga kng compared dun sa regular pressure ng engine..
    Jul 2004
    #117
    actually i already raised this concern on the low vacuum reading from the distributor/dealer. they said that tey are confident enough to say that we are not running lean with the reading. they are open for test on the A/F ratio if you want. appreciate if you could suggest a shop that offers this testing. thanks!
    Sep 2004
    #118
    Mas maganda nga na matest na to...tama rin kc yung point nila na nakakasave nga tayo pero..baka may sinisira naman sa engine...
    well, ang iniisip ko na lang is nakapasa sya sa testing ng DOE and Ford Philippines. kaso di mo pa din masabi..corrupt government ng philippines eh
    #119
    the problem with our emmission control testing is that they don't test for NOx. they only test for hydrocarbons & CO2 levels.
    hope that we can enlighten our legislators & car manufacturers about the effects of NOx.
    Jan 2004
    #120
    It's time for Tsikot.com Partylist ... heralding the cause of motorists all over the Philippines.
Gas saving device
