Results 41 to 44 of 44
December 29th, 2016 09:49 AM #41
^ hindi naman kaya magcondense ang water vapor nyan?.............resulting to hydrolock?
December 29th, 2016 10:52 AM #42
December 29th, 2016 01:00 PM #43
December 29th, 2016 06:24 PM #44
if you think about it, the condensation from the evaporator and the suction hose depends on a couple of factors:1 airflow across the evaporator, 2 relative humidity, 3 temperature difference between two materials. in this case, the suction hose will have passed the superheated region of the evaporator and will not pick up a whole lot of humidity. even if it did, it will not amount to 1 cubic centimeter per second. imagine the engine with multiple cylinders sharing that 1 cc of moisture, it should not result in catastrophic damage to the engine
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
