Results 51 to 60 of 1303
March 18th, 2009 08:38 AM #51
Yes, that is the condenser that they usually transfer the location because it blocks the air that is going through the radiator and it 'gives off heat',- it, being a heat exchanger
Mine was relocated underneath the front passenger area, and another auxiliary fan was placed on it.
I am sorry, I do not know how much it would cost. Both of my original condensers are still working fine.
If you are in the SouthMM area, I would recommend a shop in Pamplona, Las Pinas. CeeJay's is the name of the A/C shop and is in the general area of Perpetual Help Medical Center....
7707:band:
- Jan 2009
- 7
March 19th, 2009 08:12 AM #52Sir SMdelfin, tanong ko lang yun bang second condenser ng a/c ay yung katabi ng radiator ang ililipat, kung sakali saan banda sya ililipat . thanks
- Jan 2009
- 7
March 19th, 2009 08:15 AM #53Sir CVT , thanks a lot sa advise, nag post uli ako sorry ha di ko nakita yung reply mo. anyway thanks again.
- Jan 2009
- 7
March 23rd, 2009 01:22 PM #54Mga sirs, patanong uli sana regading dun sa A/C ng vanette ko kc lagi na lang nawawala ang lamig medyo marami na ang pinalitan like compressor, 2nd condenser, filter and hose pero di tumatagal after mga 1 to 2 days nawawala uli lamig, medyo malaki na rin ang nagagatos ko hope may ma advise kayo tungkol dito. thnks a lot.
March 23rd, 2009 02:02 PM #55
Kinakargahan lang ba ng refrigerant, umu-okay na ulit? O may iba pa silang ginagawa? I assume na i-convert na iyan sa R34A, right? Original kasi niyan R12...
There must be a leak in your A/C system, bro. Have it checked thoroughly.
7707:band:
- Jan 2009
- 7
March 25th, 2009 11:30 AM #56Hi Sir CVT, di pa naiconvert R12 p rin medyo madami na rin napalitan like compressor, condenser saka yung mga hose na check rin and yung evaporatorok naman daw. I wander after repair ok naman sya then after 1 day lang pag ginagamit ko na bigla nawawala uli ang lamig. Siguro kailangan pa check ko sa iba mekaniko na lang kaya lang medyo nanghihinayang ako kasi malaki na nagastos ko dito. thnks uli sa advise.
March 25th, 2009 05:17 PM #57
Technically bro.,- hindi mo siya maipaparehistro na sa LTO (I think) dahil dapat ay puro R34a na ang ginagamit na refrigerant effective last year(?)..... Anyway, where is your location? Need this information para makapag-recommend kami ng A/C shop to you.... Or, you may want to go to the A/C related discussions/forums here....
7707:band:
- Sep 2008
- 3
March 28th, 2009 11:48 AM #58ETIAN,i pa check mo yung cooling coil ( parang aluminum box yun. sa may aircon box ) mo. baka kasi original pa yan at di pa napapalitan. sa katagalan nyan kasi, magkakaroon yan ng crack o butas na pwedeng labasan ng freon. yung sa akin nga, sinlaki lang ng butas ng karayom kaya yung aircon ko di nagtatagal until mapalitan nga ng bago. yung ipinalit ko surplus lang. it cost P 3,500. ayos naman ang lamig, talagang malamig!
kung maging problema mo naman yung overheating, ang gawin mo, doblehin mo yung rubber sa loob ng takip ng radiator cap. gupit ka ng interior ng gulong. kasing laki ng rubber sealer sa loob ng radiator cap. ang mahalaga, hindi makasingaw ang init sa takip ng radiator cap mo. Tapos yung isa pa, baka yung radiator fan mo nag pre-free wheeling na. ipaayos mo yun. ipasabay mo sa takbo ng makina ang takbo ng radiator fan mo, mura lang yun. P 450 lang ata, makikita mo, malamig na aircon mo di ka pa mago over heat sa kalsada.
kung gusto mo pa, alisin mo narin yung metal can na nage enclose sa air filter mo para hindi mahirapan yung van mo na humigop ng hangin tsaka palitan mo yung muffler mo ng STRAIGHT.
March 28th, 2009 04:38 PM #59
- Mar 2009
- 3
March 28th, 2009 11:50 PM #60mga sirs tanong lang po..hirap na po humatak un vannette ko 94 model lalo na sa pataas at kpag nkastop cya naka-on a/c medyo nanginginig na cya..bka po my suggest po kayo..at magaling na mekaniko...pasencia na po bago lang po ako dito...thanks po..
Ford kasi... it needs a lot of TLC. ;) Kidding aside, I don't know if other turbo vehicles have...
0dometer problem
