Page 4 of 8 FirstFirst 12345678 LastLast
Results 61 to 80 of 1303
    mga sirs tanong lang po..hirap na po humatak un vannette ko 94 model lalo na sa pataas at kpag nkastop cya naka-on a/c medyo nanginginig na cya..bka po my suggest po kayo..at magaling na mekaniko...pasencia na po bago lang po ako dito...thanks po..
    Original pa ba ang transmission mo?..... Talagang makupad humatak ang Vanette bro.... Lalo na sa paakyat, halos walang power,- kaya alagaan mo na lang kung nasaan kang kambyo at kumuha ka ng buwelo sa susunod na paakyat...
    OT: Our Vanette have experienced the likes of Baguio (Marcos Hiway at Kennon Road), Banaue via Nueva Ecija/Viscaya mountain pass, Pagsanjan-Cavinti-Majayjay-Luisiana-Lucban zigzag roads, Famy-Real, Quezon mountain roads, Antipolo-Teresa-Montalban mountain roads et al. I tell you, it's a surreal feeling driving the Vanette on these mountain (zigzag) roads....
    Kailangang medyo i-rev mo ng husto bago ka mag-shift to get the desired power and speed.... Again, it's a different style driving this vehicle.... And, it's worth it.....
    Iyong nanginginig ang makina kapag naka A/C.... Does this happen even if the engine is already in its operating temp? O, kakabukas pa lang?... If the former, ask a tech to adjust your idling RPM...
    7707:band:
    original pa transmission nya sir cvt..ilan beses na din umakyat ng baguio un van.napansin ko lang kasi na mahina na cya humatak..kailangan na kaya ipa engine overhaul? thanks sa info sir cvt...
    Engine overhaul,- I don't think so, unless there are traces of oil in your engine....
    It could just be tune up (spark plugs, contact point, condenser). I suggest that you use original Nissan parts. At, baka kailangan lang na i-advance mo ng kaunti ang timing. I suggest that you have it checked by a reliable mechanic....
    OT: Isa pa nga palang na-conquer ng aming Vanette ay iyong Bitukang Manok sa Quezon... And during those mountain road drives, practically, puno ang sasakyan (>8 persons)... I still love driving this van better than our second 2004 van....
    7707:band:
    thanx sir cvt....
    Apr 2010
    May binebenta po sken n Nissan Vanette99 model mganda po b un? based po kc s mga nbasa k dito thread eh ung ibang model like 94 model ng vanette eh mlakas maginit ang makina. thank you po.
    Feb 2010
    *kharen
    ok yung 99 model na vanette or what they call the grand coach. . . wala na cyang overheating problem just like mine. . . kasi tama na yung position ng condenser. . .
    Aug 2007
    Hi, just want to share. my vanette spews white smoke a few weeks ago. I had it checked and my mechanic suggested to check the piston rings as he was certain the problem emanates from there. he was 100% correct. Had it overhauled and I love how it drives now.
    I need to check my front shocks also but I can't seem to find them.
    pls help me locate these shocks. I'm planning to try the KYB gas.
    thanks.
    Aug 2008
    Quote Originally Posted by butsok View Post
    Guys i've just acquired my Nissan vanette and i'm starting to re-condition it but DIY na lang sana sa mga pwede DIY. I've just recover the AC, so OK na yung AC nya. My next move is to change the air filter, clean the spurplug, clean carb then change oil then adjust the idling... any one here known a site for the engine of vanette or anyone can teach me where's the idling adjustment located.. hope to here soon..thanks a lot
    dun sa ilalim ng carburetor nya adjust ung idling.turnilyo lng un na my spring.mgpalit ka ng fuel filter na dn.caue un kc ng sinisinok.o kya kulang sa fuel.dun nkalagay un sa ilalim ng baterya.iilalim k tlaga bgo momatangal.
    Aug 2008
    gud am sir.gawin mo sa vannet mo,check mo ung fuel filter under the battery casing,medyo mahirap tangalin un nasa ilalaim kc ng battery.un lng ang sira ng vannet mo.ive got vannet for 10 yrs kc.thanks angd ingats
    Quote Originally Posted by shumaker66 View Post
    I agree that this may probably be causing it. Mukhang natso-choke ang paglabas ng gasolina.....
    8303:dishwash:
    Aug 2008
    gud am.ung adjustment ng carburator idling nya ay sa ilalim dn ng carburador my maliit na screw type na my spring.un ang adjustment nya.and mgpalit k ng kontact point.dun nkalagay sa my distributor nya.my technic ang pg adjust ng contact point nyan.kelangan my siwang ung tip to tip nya ng contact point
    Nov 2006
    nasira ata ung power window motor ko sa driver side; ayaw na gumana; any idea kung saan makakahanap to (surplus) and kung magkano? thx
    Quote Originally Posted by cc81352 View Post
    Try at Evangelista bro.... Medyo malapit ito sa iyo....
    8303:dishwash:
    Just found out this morning that Caltex now offers only Gold (pure gasoline) and E10 Silver... Nawala na ang Silver (pure gasoline)....
    Anyway, Gold naman ang pinakakarga ko sa Vanette....
    8303:dishwash:
    Nov 2006
    galing ako ilocos kanina, so bago kami nag-byahe pina-check ko pang-ilalim ng van andami na daw papalitan...rack end, bushing, tire rod etc etc. quote nila sa kin is 22k (parts and labor!), mga sir ganito ba talaga ang presyuhan ngayon?
    Aug 2008
    d ako agree sa vanet n advise,una matagtag,matakaw sa gasolina.mahina preno,sirain ang aircon,tpos pg luma na tlaga miinit sa pwet,dahil nan dun ung makina.madalas mgbaba taas ng idle.and ung fuel filter nya pg d mo pinalitan.ititigil ka s gitna ng kalsada.nkakadisgrasya.un lng po/.
    Nov 2006
    di po kaya napabayaan lang sa maintenance?
    Aug 2009
    Gud Day po!
    Kita ko to sa isang Ad.. plano ko po kasing bumili ng sasakyan next week..mukhang maganda pa sya.
    http://www.sulit.com.ph/index.php/vi...%2C09089759310
    Malakas po ba talaga sa gas ang vanette? Yung ganitong model ano po usual na problema?
    Feb 2005
    Quote Originally Posted by planetmarz View Post
    More than the concern on fuel efficiency, Vanettes, particularly for models 1993-1995, were problematic due to OVERHEATING issues (no radiator shroud). But if the one you're looking at is a 1998 model, that should be already fine.
    Again, a trusted technician's opinion is suggested prior to any purchase. Better to be safe than sorry bro.
Nissan Vanette [Merged threads]
