Page 108 of 729 FirstFirst ... 85898104105106107108109110111112118158208 ... LastLast
Results 2,141 to 2,160 of 14580
    Nov 2007
    #2141
    Quote Originally Posted by ooba99 View Post
    Metrowalk will be fine with me. How about doing this after Christmas before New Year?
    Ok ako dyan sa after Christmas. Pero dapat siguro somewhere na malawak parking and during the day para mas mausisa natin mga rides. Mahirap kung gabi tapos magkakalayo ang mga Strada natin. Although yung sa kin wala naman ako upgrade, all stock.
    Sep 2004
    #2142
    Quote Originally Posted by DonT View Post
    ^^ I like also that LCD...but...is this a local Strada? it seems that it is not a local one.
    Can't help noticing the Multi info display found on old 4x4's on top of the LCD.
    Plus the A/C knobs, which are I think standard elsewhere and not in pinas.
    Stereo also looks like a Pioneer.
    In any case, thanks for posting.
    sir, glx po sa kanya..thats why ganyan ang display...my glx is the same thing. with regards to the compasss and other gadgets on top of the lcd, i bet sir boybit bought that separately and just glued it on.
    best if he share his setup...heheheh
    Sep 2004
    #2143
    Quote Originally Posted by ent_md View Post
    im fine with that setup...the question is..who will lead? sir ent_md kayo na po mag set. hehehehe :P
    #2144
    ay...ganda ganda.... huhuhu..saving up pa rin ako.... sir...ano lcd yan? ano brand? cost? where did you get it? i notice you replaced your hu din.... how much score ninyo po sa lahat na yan?
    did you also get the rear night mode camera? inggit ako..huhuhu
    kaw tlga sir...alam mo reaction ko..natuwa nga ako when i read your post..you surely read my mind. huhuhuhu.
    i want one....i like sir boybit setup....i was thinking if i get the 2din unit..what will happend to the slot for my existing radio?
    my setup includes
    1. sony xplod 12" subwoofer P4500
    2. jbl amplifier 300wx1 mono P7000
    3. pioneer P7950ub- i changed the unit coz it has crossover to control the sound and frequency of subwoofer as well as the vocal P11000
    4. customized mdf subwoofer enclosure P3000
    5. M-tech 2 din touch screen lcd, dvd player, sdcard/usb player, tv tuner P22000- i choose this coz the store gives me 2 years warranty on this
    5. rear nite vision camera cost 6000
    i still use the pioneer headunit, magastos nga lang dalawa headunit, but the sound quality is improved using this headunit, the lcd served only as monitor, dvdplayer and tv tuner. i control all my sound output in pioneer head unit, the lcd link to the pioneer via aux in on pioneer 7950ub
    its a generic
    Dec 2007
    #2145
    Bow ako with the set-up na LCD.. it may also look like a rear-view camera... if it is, that'll be super cool!
    I just visited a Nissan dealer and looked at the new Navara. The external design didn't blow me over like the Strada. But what I like the most is when you get inside and close the doors. It gives off a solid "fomp!" rather than the usual (but excellent) "thud!" It sounded more solid than the other pick-ups that i've been able to look into.
    I was really intrigued with the 2.5 Diesel engine that the Navara has which produces a mind blowing 174ps and 403nm of torque. Our own strada doesn't even come close to these numbers and we have a 3.2 engine! I've been reading up on other sites and forums as well. It seems that the Variable Geometry turbo is the culprit for the huge power and torque rating. Many did mention that the Navara has a short power band, which means it peaks for a short moment and the peak power doesn't last long. This means that you always need to hit that "sweet spot" on your tachometer to maximize the truck's power versus other engines where the power and torque evens out longer, allowing you to stay on a gear longer. Thus the need for a six gear manual and 5 gear auto for the Navara. It helps manage the short peak of the engine. I looked at some stats and found out the following (listed below). Please note that all my assessments are mostly guess work based on the stats, I will still have to test drive it and confirm my theories.
    Strada Manual gear ratio
    1st: 4.313
    2nd: 2.330
    3rd: 1.436
    4th: 1.000
    5th: 0.789
    Navara Manual gear ratio
    1st: 4.692
    2nd: 2.705
    3rd: 1.747
    4th: 1.291
    5th: 1.000
    6th: 0.827
    Studying the manual gear ratio, you will notice that the Navara has a larger 1st gear which should give it more grunt than the Strada. The main difference is the 3rd, 4th and 5th gear of the Navara, each gear is close to each other. It may mean that Navara owners will shift quickly between 3rd to 5th, almost not being able really stay within a gear for too long. The end gear ratio is almost the same with the Strada having a smaller gear ratio. A smaller gear ratio means that you will use the engine less to cruise at higher speeds (except that it would have less punch or power).
    Strada Auto gear ratio
    1st: 2.842
    2nd: 1.495
    3rd: 1.000
    4th: 0.731
    Navara Auto gear ratio
    1st: 3.827
    2nd: 2.368
    3rd: 1.520
    4th: 1.000
    5th: 0.834
    The story with the auto is slightly different. The Navara has a bigger first gear. This gives the Navara a huge grunt above the Strada, which will be great in hauling a full cab of passengers and even a truck load of stuff up a mountain, the Strada might struggle a little bit more than the Navara given the same load. From there, everything seems to even out, the Navara's 2nd gear is almost the same with the Strada's 1st gear up until the last gear. On the last gear, the Strada has a smaller gear ratio, again giving the engine less work to maintain higher cruising speeds. Given the choice, I think the auto is the best compliment to the Navara's engine. You wouldn't want to fumble through 3rd to 5th all the time. Let the car do it for you.
    In the end, it seems that the gear ratio will make the Navara engine work harder to maximize the power and torque ratings that Nissan has been raving about. While the Strada's would have an easier time coping with the demands we place on having fun with out trucks. Other sites and forums did say that the Navara consumed more diesel than the other trucks even with the smaller engine. Hmmm... some food for thought there.
    Lastly, when I stepped inside, I was glad to find leather seats and a knob for the 2x4 to 4x4 function. The Strada would have been more refined and stylish if they followed the same thing. Other than that, I was dissapointed with the Navara's cabin. The dashboard "looked" stubby and short while the Strada has an extended feel (like that of cars today - for example the civic). Maybe perhaps the Strada has more slopped lines while the navara has a very boxy dash. The instrument panel is bland but the steering wheel does look macho tough, like that of the Ford Ranger. Seating in front was good. Yet the back was a little cramp, like all other pick-ups except for the Strada. The Strada seems to have the best rear seating room, although the Hilux has a good and high seating position which makes it very comfortable to sit at the back - if only the Hilux wasn't so bumpy. The rear windows for the Navara are very small and give you a further illusion of being cramp at the back seat.
    Lastly, I do not get the permanently raised thin "walis ting ting" antenna that the Navara has. At a time where shark fin antennas and window strip antennas are the rage nowadays, I don't understand why Nissan would place an antenna that make the car look like a remote control toy I used to play with.
    All in all, I still prefer the Strada. The Navara's engine (and by the way a limited slip differential that comes standard) is like mighty mouse on a saturday cartton show. You are amazed by it and you may like it for its sheer power and torque. But with most of it on the first gear and the end gear ratio makes your engine work more than the others to cruise on the highway... mighty mouse ends up a mouse with superpowers when you can actually be superman - refined *** appeal with superpowers under the hood.
    I hope to be able to test drive it and confirm my theories about the gear ratios. =P
    Sep 2004
    #2146
    Quote Originally Posted by boybit View Post
    my setup includes
    its a generic
    Nice..totally nice....
    May 2007
    #2147
    Quote Originally Posted by mikko_018 View Post
    Sir Ian, we bought our unit at Motorplaza - Urdaneta. installment po..
    okay naman po sales procedures.. 3 yrs LTO, 3 yrs insurance..
    Sir they offered us the old stock GLS(white with ABS) but the price was mas mahal ng 80k sa new stocks saka madaling madumihan.. our unit was not equipped with ABS.. saka ko nalang nalaman nung kukunin na namin nung unit eh nakita ko ung manual ng mga SA, GLS Sport nalang daw ang meron ..
    ur strada to my understanding has the LSPV- load sensing proportioning valve that balances brake power over load (guys, correct me if im wrong) that replaces the ABS+EBD feature. my friend from mitsu advised that the brakes, even without the ABS+EBD should still be good and linear!
    i do agree with the consolidation of the Strada threads... when will this happen? i wish i had a strada to join the EB....
    Feb 2007
    #2148
    hi guys!
    My first post here at tsikot! Nice to know that there's a thread for 2007 strada owners. I'm from La Union and I got my gls strada Feb. 2007. I installed 20" chrome rims with cooper tires, a kenwood indash monitor with dvd/stereo ( I removed the factory installed stereo ) and 2 sunvisor type lcd monitors to keep my daughter busy during long trips. I'm currently looking for a roll/slide type bed cover. Any idea on the price and where to get one? Thanks and Merry Christmas!
    Aug 2007
    #2149
    Welcome to the thread Edmeister. Nice Bling Bling Wheels there!
    Nov 2007
    #2150
    Quote Originally Posted by bonifyde View Post
    Very informative pards
    They did test the Navarra and the 2.5 strada sa 5th gear yata
    It's in youtube
    I believe the navarra won because of the engine
    I'm pretty satisfied w/ the 3,2's acceleration , it's the braking I'm worried about hehe
    My strada is almost 2months old now , almost 5000kms
    The shifting has become smoother now, I didnt know pati kambio may breakin
    The lagitik is still there , a friend told me that was fuel knock
    Doesnt affect performance but limalakas daw konsumo
    I'll have it checked again
    Alarm is still disabled , pain in the butt anyway
    Only mods are a portable dvd and a removable bike rack
    Might take it off road ( daang kalabaw )this weekend sa farm
    We'll see how it does
    Sep 2004
    #2151
    Quote Originally Posted by edmeister View Post
    hi guys!
    nice ride sir. nice nice and nice.
    wla pa yata roll/slide type for the bed...madami rin tayo naghihintay for this.
    #2152
    s
    hi guys!
    My first post here at tsikot! Nice to know that there's a thread for 2007 strada owners. I'm from La Union and I got my gls strada Feb. 2007. I installed 20" chrome rims with cooper tires, a kenwood indash monitor with dvd/stereo ( I removed the factory installed stereo ) and 2 sunvisor type lcd monitors to keep my daughter busy during long trips. currently looking for a roll/slide type bed cover. Any idea on the price and where to get one? Thanks and Merry Christmas!
    Dang, ang ganda! how is the ride sir? I can only imagine what mine would look like on 20's.
    I saw a Red Strada last week, no plates yet, GL model only, no rear bumper but with fender flairs and side door moldings to make it look GLS, and riding on 20's! My jaw suddenly dropped cause it looks so simple but oh so nice! Exactly what i'm looking for.. Looks similar to Rays TE37's except this one is dark silver. Took a picture of it while on Edsa. Will post the pic soon baka meron sa inyo nakakaalam san meron nito. Sana member din ng tsikot ehehe.
    Nov 2007
    #2153
    Ha ha. I will leave that to the Manilenos. Mas alam nyo territoryo nyo. Promdi lang ako. Susunod lang ako. Sana lang matuloy ang EB. Excited na ako...
    Dec 2007
    #2154
    hello again. dun pala sa alarm, pareho lang ba naka-install sa gls and glx models? may auto start din ba and turbo timer sa glx?
    Nov 2007
    #2155
    LIST OF STRADA OWNERS INTERESTED IN MEETING UP TO SHARE THEIR EXPERIENCES ON THEIR RIDES.
    Handle name / strada color and model / location
    1. av8or5 / silver glx / mandaluyong-eastwood
    2. ooba99 / cool silver 3.2 gls /proj. 6 q.c.
    3. DonT / White Gls sport / Boc. Bulacan
    4.Allegra / black gls sport / Calamba
    5. ent_md / black gls sport / Los Banos
    6. nismo26/black gls sport/ Cotabato City
    7. strajero/red gls sport/ pasay
    8. Bonifyde / Titanium Grey GLS Sport / Pasig
    9. Drave/ titanium mica grey gls/ San Pablo City
    10. GerNavallo / Black GLS Sports / Pasig & Cabanatuan Cities but only around every 70 days
    Aug 2006
    #2156
    Dec 2007
    #2157
    Whoa! Nice bumpers! Where can I get one?
    I was thinking of the Carryboy nudge guard, its either built with steel but doesn't match with the Strada design or built with fiberglass that might crack at the slightest nudge. That's why I didn't install any. Last night may nakasabay akong GLS and it looked eactly like mine, we had the same color and accessories. The only difference is that he had body cladding, the nudge guard and door visors. It looked good! That means my own truck looks good! hahaha!
    Nice wheels edmeister! You just made me think about getting 20s myself!
    Feb 2007
    #2158
    Quote Originally Posted by louchua View Post
    s
    Hello again! The 20's on my strada rides super smooth. I think tama lang for the strada. Anything bigger I thinK would look "cartoony" - just my opinion. It grips pretty well on tight corners especially during my frequent trips to baguio. Besides from the roll-type bed cover, I don't plan to add anything else on the exterior to draw attention to the rims. Besides, baka patayin na ako ni misis - dami na kasi nagastos hehehe...
    Dec 2007
    #2159
    I was told by Grace at Carryboy that the reason bakit walang roller type bed cover is because the Strada has a slopped truck bed. The roller types need a straight truck bed (such as the Hilux, etc). Until someone discovers how to do a sloped rail for the roller truck bed cover... I think we will be stuck with the fiber glass version.
    Jun 2007
    #2160
    11. moxxxs/red gls 2.5/Manila
