Page 376 of 470 FirstFirst ... 276326366372373374375376377378379380386426 ... LastLast
Results 7,501 to 7,520 of 9388
    May 2008
    #7501
    Quote Originally Posted by mikko 828 View Post
    good news fellow monty brothers !!!!!
    i just had my JVC avx-77 HU installed this morning with my friend and guess what ? We discovered that the OEM jvc is some what converted by winterpine .....
    yes, they just adopted a module or jumpered the IR receiver to our T22 JVC.
    which we just transfer it to the avx-77 HU and it work perfectly !!!
    as long as your HU has the OE remote wire ( enable to receive Ir from the steering wheel ) i'l try to post the photos.....
    No need to buy the modular kit anymore and i dont feel any delay with the response .
    thats good news! hope it will work with the AVX44 too. Would Winterpine service mine kahit I got my HU from Amazon?
    May 2009
    #7502
    you can order at your nearest mitsu dealer
    thanks for the reply JPG111.. :D
    #7503
    sir Mikko just gave us the discovery of the month
    Yeah, I'm also wondering if it can work on 2-DIN Jvc units.
    #7504
    Sir Mikko, please post the pictures of installed avx-77 HU with power on and power off.
    #7505
    JUMPERED MODULE TO RECEIVE THE COMMANDS THE THE STEERING WHEEL REMOTE
    OE REMOTE OF THE AVX -77
    Took a shot at my wirings (avx-826 2DIN):
    So I guess it can also go for 2DIN Jvc units. Do Winterpine sell the modular kit separately?
    May 2008
    #7506
    Quote Originally Posted by djro View Post
    [SIZE=3]Hi Guys! All you wrote here are correct. I am not sure though if the GLS SE 4X4 has Cruise Control, the Ukraine version has it. [/SIZE]
    I own a GLS SE. NO CRUISE CONTROL! I want to add this accessory if possible! Can anyone do this??? winterpine!!!!!!
    Apr 2005
    #7507
    I think by default, the PHDM MS was using JVC HU. If that is the case then you guys are lucky because you don't have to buy additional module just to retain the steering control with your NEW JVC HU
    #7508
    sir Memphis Raines- absolutely yes sir , as posted photo just transfer the module , simple cut the 3 three wires ( there are 2 option 1. buy a mono jack same with regular earphone jack or 2. cut the OE remote wire and just connect the (a)blue wire to the center wire of the OE remote ( B ) black wire to the ground and lastly (C) the red wire same with the ACC power supply. HTH
    #7509
    sir Memphis Raines - if your monty is equiped with the steering remote , there's no need for you to buy the module just simple transfer the module on our stock HU
    as you can see the yellow wire with black shrink tube originally connected the the blue wire is the IR module ( receiver ) itself, so in your case your avx-826 has the OE remote wire so there is no need to jumper the wire inside the HU.....
    #7510
    sir RevD - just check your avx-44 if it is equiped with the OE remote terminal..... if not only choice is to open your stock head unit and checked the location where they solder the yellow wire ... most probably to the IR remote circuit area.... HTH
    #7511
    guys attached is my JVC AXV-77
    #7512
    wall paper mode
    video mode...
    #7513
    ipod mode with artwork display.....
    #7514
    sir RevD- i just checked the JVC entertainment website under feature that KD avx-40 is equiped with the steering wheel remote ready so i presume it would be the same with your avx-44 since its a higher model than the avx-40
    so just look for the OE REMOTE cable....
    Oct 2003
    #7515
    sir mikko,
    did you install an ipod interface or cable in order for the iPod to work? or the HU has already a USB cable, just like the stock BT-22.
    Jan 2009
    #7516
    wall paper mode
    video mode...
    Hi Sir Mikko nice set-up you got there..
    Jan 2009
    #7517
    Hi guys anybody here having trouble with their steering remote? and if you fixed the said problem. I already changed my HU then Benjie of MASPRO fixed my steering remote but after a few weeks its going nuts again..
    May 2008
    #7518
    hi sir mikko. please explain option 1 again.
    after the connection has been done, is there a need to "reprogram" the remote? will all the function of the remote work? ty
    Jul 2005
    #7519
    wall paper mode
    video mode...
    very nice indeed sir mikko. congrats! btw, did you install headrest monitors with the avx77?
    #7520
    Thank you very much for your help there Mikko I'll eventually refer this to my installer. Napaka-simple lang pala.
