Results 701 to 710 of 9388
November 17th, 2008 02:20 PM #701
yup- i have seen display units here in baguio sa dealer- saw the pack and no remotes have been seen... haiz.
i think JVC has a local distributor here... i think it is somewhere in manila yata... they might have the remote that anyone can buy perhaps...
otherwise, anyone can change the head unit...
November 17th, 2008 04:09 PM #702
- May 2008
- 12
November 17th, 2008 04:34 PM #703MS Owners!
What has been your experience so far with your Fuel Consumption?
City: ?
Highway: ?
Mixed: ?
Thank you in advance and more power to the MS Club!
- Aug 2008
- 405
November 17th, 2008 04:39 PM #704I heard may pila na daw for the montero sport. any idea how long will it take for a unit to be delivered?
November 17th, 2008 04:41 PM #705
When our unit was delivered the alarm was turned off(blue led light is on all the time, especially driving at night its annoying). then i tried to turn it on..and when parked on the streets or a mall...a little noise or vibration makes it buzz..
I asked the SA in citimotors mkti..to adjust the sensitivity...but still the same
Is you're blue led on all the time? dont you find it annoying at night..
November 17th, 2008 04:45 PM #706
November 17th, 2008 05:52 PM #707
November 17th, 2008 06:08 PM #709
Sir please try to close your door, if hear a beep open it and again close. Dont lock using the remote button instead lock it using your ignition key.
It will not buzz in any vibration around but only sound the alarm if you open it by key and not by remote. Mitsu technician teach me this procedure.
November 17th, 2008 08:32 PM #710
Hi you can lower down or add the sensitivity of the alarm. My alarm came from citimotors makati try this.. i guess we all know there is a valet button hidden inside our dash. first put the key in ignition put it on acc on just like putting our car at valet hold the valet button for about ten seconds then we will hear a 3 chirps. push the valet button again then we will hear 4 chirps then again push the button we will hear a 5 chirps. After the 5 chirps press the OPT button on our alarm key. then press the arm key (indicating add sensitivity) for disarm button (indicating minus sensitivity) after choosing your sensitivity remove the key. hope this helps kinda complicated at first.
Nope Prius had variable speed/inverter Acs since its 2nd generation(~2004)....
A/c
