Results 21 to 30 of 123
September 24th, 2014 10:23 PM #21
Sirs,
Ask ko na rin po? paano naman po pag bihira gamitin ang sasakyan (low milage) ano po ba ang susundin for timing belt replacement? yung years age ng sasakayan or yung KMS required?! before replacement?
Possibly, baka yung monty namin, within 5yrs, hindi pa po aabot ng 25K KMS, dahil bihira lang po gamitin.
- Apr 2007
- 285
September 24th, 2014 11:58 PM #22Madugo talaga timing belt change....
Minimum parts to be replaced are the
timing belt/s
tesioner belt/s
tensioner bearings
camshaft oil seal
crankshaft oil seal.
Not going to the casa ...that's for sure.... but hinde naman ako malakas mag mileage, around 15k a year, baka maunahan pa ng benta ng Monty ko yung palit ng timing belts.
But if you really want casa...I suggest you wait for their rainy day promo's or out of warranty vehicle promo, usually 20% off yung parts and 30% off yung labor....
- Sep 2011
- 241
September 25th, 2014 12:04 AM #23
Someone correct me if I am wrong but the timing belt pati ata ATF has a separate annotation sa service booklet/manual parang sa mileage lng sya based ( timing belt is 60-80K kms ata), wala naka specified na time interval. Pwede rin naman na iassume mo yung counterpart ng 60K kms sa time interval just to be safe, so 60K kms will be 36 mos o 3 years ( kung 10K kms or 6mos whichever comes first ang PMS). Yung iba 100K kms magpalit ng belt so 5 years yun.
- Jun 2013
- 244
September 25th, 2014 01:23 AM #24sobra mahal ng mga bearing. kung may replacement sa autosupply. ok na ba? koyo daw kasi replacement. same brand ng oem. may nakabili na ba sa inyo?
Tsikot Member Rank 1
- Jul 2009
- 4,090
September 25th, 2014 01:31 AM #25nakakatawa lang na ang fort/hilux/innova na may timing belt change indicator lights up *150k kms. same belts supplier (thailand). laki talaga ng kita ng mitsu kung susundin mga isinasuggest nila. my gtv now is 102k kms. no plans of changing tbelt as of now. 120k kms to be done at my shop
- Jun 2013
- 244
September 25th, 2014 11:46 PM #26^ sabagay. lapit na kasi ako mag 80tkms. masubukan kaya paabutin ng 120k pataas? hindi kaya delikado pag 150k papaltan? sab kasi ng mekaniko ko silipin muna namin kung palitin na timing belt eh. kung ok pa daw wag muna
September 25th, 2014 11:55 PM #27
ako din paabutin ko ng 100k kms or even more bago ako palit ng timing belt.
bakit nga ba timing belt pa din at hindi chain na ang ginamit sa monty natin? sabi sa akin ng s.a. dahil daw for weight considerations. totoo ba iyon?
- Oct 2013
- 2,537
- Jul 2009
- 4,090
September 26th, 2014 01:39 AM #29
- Jul 2010
- 57
September 26th, 2014 03:40 AM #30Tama si sir zix888 dali lang silipin timing belt 4 bolts lang tanggal na cover at pwede na i-judge kung palitan na or ok pa. Note po di maganda sa serpintine belt ang belt dressing fyi lang po.
Dati kasi, Sojitz Corp ang distributor ng Geely locally, ngayon Geely Motor Philippines Corp....
BYD Philippines
