Page 3 of 13 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 123
    #21
    Sirs,
    Ask ko na rin po? paano naman po pag bihira gamitin ang sasakyan (low milage) ano po ba ang susundin for timing belt replacement? yung years age ng sasakayan or yung KMS required?! before replacement?
    Possibly, baka yung monty namin, within 5yrs, hindi pa po aabot ng 25K KMS, dahil bihira lang po gamitin.
    #22
    Madugo talaga timing belt change....
    Minimum parts to be replaced are the
    timing belt/s
    tesioner belt/s
    tensioner bearings
    camshaft oil seal
    crankshaft oil seal.
    Not going to the casa ...that's for sure.... but hinde naman ako malakas mag mileage, around 15k a year, baka maunahan pa ng benta ng Monty ko yung palit ng timing belts.
    But if you really want casa...I suggest you wait for their rainy day promo's or out of warranty vehicle promo, usually 20% off yung parts and 30% off yung labor....
    Sep 2011
    #23
    Quote Originally Posted by playplugg View Post
    Sirs,
    Someone correct me if I am wrong but the timing belt pati ata ATF has a separate annotation sa service booklet/manual parang sa mileage lng sya based ( timing belt is 60-80K kms ata), wala naka specified na time interval. Pwede rin naman na iassume mo yung counterpart ng 60K kms sa time interval just to be safe, so 60K kms will be 36 mos o 3 years ( kung 10K kms or 6mos whichever comes first ang PMS). Yung iba 100K kms magpalit ng belt so 5 years yun.
    Jun 2013
    #24
    sobra mahal ng mga bearing. kung may replacement sa autosupply. ok na ba? koyo daw kasi replacement. same brand ng oem. may nakabili na ba sa inyo?
    #25
    nakakatawa lang na ang fort/hilux/innova na may timing belt change indicator lights up *150k kms. same belts supplier (thailand). laki talaga ng kita ng mitsu kung susundin mga isinasuggest nila. my gtv now is 102k kms. no plans of changing tbelt as of now. 120k kms to be done at my shop
    Jun 2013
    #26
    ^ sabagay. lapit na kasi ako mag 80tkms. masubukan kaya paabutin ng 120k pataas? hindi kaya delikado pag 150k papaltan? sab kasi ng mekaniko ko silipin muna namin kung palitin na timing belt eh. kung ok pa daw wag muna
    #27
    ako din paabutin ko ng 100k kms or even more bago ako palit ng timing belt.
    bakit nga ba timing belt pa din at hindi chain na ang ginamit sa monty natin? sabi sa akin ng s.a. dahil daw for weight considerations. totoo ba iyon?
    Oct 2013
    #28
    mahirap ma putulan ng timing belt... pag na putol yan eh major engine repair bagsak nyan...
    mali sabi ng S.A. mo, luma kasi technology ng mitsubishi... year 1980's pa ang 4D56
    ang advantage lang ng 4D56 eh proven na siya and no need to further experiment needed...
    #29
    Quote Originally Posted by katsupoy View Post
    yan ang dapat, check mo muna. sakin at 80k kms, super sayang palitan
    pag casa sinunod mo, donate ka na sa mitsu bwahaha
    Jul 2010
    #30
    Tama si sir zix888 dali lang silipin timing belt 4 bolts lang tanggal na cover at pwede na i-judge kung palitan na or ok pa. Note po di maganda sa serpintine belt ang belt dressing fyi lang po.
Montero Sport Timing Belt Replacement
