[quote=XTO;1290593]Reply from MMPC / HARRY:
From: "h-ilan*mitsubishi-motors.com.ph" <h-ilan*mitsubishi-motors.com.ph>
To: Darwin Castro <darwin_cd*yahoo.com>
Cc: d-doctor*mitsubishi-motors.com.ph; f-zafra*mitsubishi-motors.com.ph
Sent: Tuesday, August 4, 2009 6:22:08 AM
Subject: Re: Montero Sport 4x2 A/T Immobilizer?
[SIZE=2]Dear Darwin,[/SIZE]
[SIZE=2]Thank you for your follow up query regarding the immobilizer system and please find below our reply to your concern.[/SIZE]
[SIZE=2]1. What about for MS 4x2 A/T? does it have engine immobilizer?[/SIZE]
[SIZE=2]Yes, the New Mitsubishi Montero Sports 4X2 AT is also equipped with immobilizer system.[/SIZE]
[SIZE=2]2. Whats the purpose of the immobilizer? [/SIZE]
[SIZE=2]The purpose of the immobilizer is to prevent the engine from starting the vehicle if a key other than the key which is registered for the vehicle is used after an attemp to start the vehicle after force entry.[/SIZE]
[SIZE=2]Where it was installed and located?[/SIZE]
[SIZE=2]The immobilizer is located and installed in the ignition key cylinder.[/SIZE]
[SIZE=2]3. How it will function / its work?[/SIZE]
[SIZE=2]The immobilizer works when the ignition key is turned ON. The registered ignition key transmits its own key ID via radio wave. Tthe immobilizer controls the vehicle starting sytem to function when the sent key ID agrees with the pre-registered one. Two ignition keys are provided, and up to eight keys can be registered to one vehicle as needed.[/SIZE]
[SIZE=2]4. How to test the immobilizer on MS 4x2 A/T unit?[/SIZE]
[SIZE=2]Vehicle with immobilizer system will not start using an unregistered key.[/SIZE]
[SIZE=2]We hope that the above have adressed your concern and thank you very much for visiting our website.[/SIZE]
[SIZE=2]Sincerely,[/SIZE]
[SIZE=2]
[/SIZE]![]()
Sincerely,
HARRY B. ILAN
Customer Service Department
Mitsubishi Motor Philippines Corporation
Ortigas Ext., Cainta Rizal
Tel. No. 658-0719, 658-0106 loc. 236
but when i e-mailed the MMPC, that was their reply
