Page 33 of 162 FirstFirst ... 232930313233343536374383133 ... LastLast
Results 641 to 660 of 3240
    Sep 2011
    #641
    Sirs goodevening po. Share ko lang yung 40k PMS ko outside casa.
    4L Eneos ATF DIII * 240pesos/L
    8L Idemitsu 5w40 * 1900/4L
    Oil filter * 880
    Fuel filter * 2200
    Labor * 400
    Total cost = 8240.00
    http://img165.imagevenue.com/img.php..._122_566lo.JPG
    http://img228.imagevenue.com/img.php..._122_216lo.JPG
    Sep 2011
    #642
    Sorry double post.
    Aug 2003
    #643
    Quote Originally Posted by zix888 View Post
    sir ilan na ba mileage? sa manual kasi every 100000kms yung transfer case, kaya nung buksan ko yung sakin at 45000, eh parang bago pa talaga yung oil, sayang. yung front diff. halos bago pa din, pero yung rear pwede na at 45k(sa gamit ko-everyday use, 4h once in a while when slippery roads). kaya i made a personal table na lang based sa usage ko when to change rear/front gear oil and transfercase oil. ( reference , from casa 0km to 45000kms actual inspections/change of oils)
    *zix, 30kms lang ako sir. 2+ years old montero. pero sabi kasi sa PMS menu ng Mitsubishi every 30k kms palit ng transmission, transfercase and gear oil. Palit ako ngayon then plan ko every 50k kms thereafter na pag out of warranty na. Para lang di ma void sakaling magkaproblema.
    *jmtyper
    1.2 L front differential, 2.6 L rear differential
    2.5 L transfercase, 3.4 L manual transmission, 9.7L auto transmission
    magastos pala 4x4 sa oil. hehe.
    #644
    Quote Originally Posted by ek2jayvee View Post
    *jmtyper
    naku huwag ka maniwala dyan sir. atf 40k. rear diff 40k, front and transfer case 80k. pag naniwala ka dyan eh talagang magastos. plus 2+ years na oto mo, konti na lang out of warranty na din, if wala ka naman nararamdaman unusual sa shifting ng tranny, shifting to 4x4, naku sayang. yung sakin binuksan ko yung front diff and transfer case at 45k, lumuluha ako habang tumutulo yung mga langis, as in bagung bago pa. atf and rear diff na lang galawin mo kung talagang ayaw mo papigil, hehe
    Feb 2007
    #645
    Just had my 5k PMS at Diamond Motors Quezon Avenue, here's the breakdown:
    Engine Oil (Mineral) 1708
    Diesel Treatment (na hindi ko naman ginagamit) 259.99
    Oil Filter 1042.72
    Varsol 95.54
    Car Care Kit 280
    Rags 11.99
    TOTAL 3398.30
    Apr 2012
    #646
    Quote Originally Posted by red07 View Post
    Oil Filter 1042.72
    Varsol 95.54
    Car Care Kit 280
    Rags 11.99
    TOTAL 3398.30
    ayos yan sir red07, mura na yan 3.4k sa 5k pms kasi mineral ang inilagay na oil. aabot ng 5.5k yan kung synthetic oil ng casa ang ginamit....
    Aug 2003
    #647
    Haha thanks for the advise sir. Yung front and rear differential na lang muna papagalaw ko. taking into consideration na nilulusong ko sa baha yung sasakyan. Yung sa tranny hesitant ako kasi may mga nababasa ako dito (strada) na nagbago feel ng transmission in terms of shifting gears (manual trans ako) kasi SAE 90 fluid lang din ata nilagay ng casa kaya multigrade binili ko.. Yung tansfercase, yes pa 4H lang naman din ako pag umuulan, magamit lang. hehe.
    Since nabili ko na yung fluids, I can just store it lang naman. For how long kaya? May idea ka sir? hehe. thanks.
    Jul 2006
    #648
    *doc jayvee, as long as you do not open the cover of your fluids, then it will last long. Just don't open them.
    Feb 2007
    #649
    Oil Filter 1042.72
    Varsol 95.54
    Car Care Kit 280
    Rags 11.99
    TOTAL 3398.30
    Pwede naman po i advise nyo yung SA nyo na wag na isama sa bill yung DT, that's what i did from my 5K, 10K and 15K PMS..due na rin ako for 20K kaya ipon muna..
    #650
    it says Gasoline Engine Oil on the container
    Jun 2011
    #651
    Beware of SFM-Lipa
    Nagpa 1000 PMS ako dito pero ang ginawa kinabitan ng pang Adventure na oil filter ang Montero Sport.Nilagay nila MD068782 na dapat ay 1230A045. Kaya pala mura change oil nila sa MS Php2,800 murang oil filter nilalagay nila. Buti na lang nagtanong ako sa Citimotors sa nilagay nilang filter, kung nagamit ko ng matagal makakasaman sa makina, apektado daw oil flow at filtration.
    Sep 2011
    #652
    Quote Originally Posted by Thumbdrive View Post
    Yes it does, pero sa ibaba, may nakalagay na suitable for gas and diesel engines.
    Yun nga lang, medyo mababa TBN nito. Around 7 to 8 lang. For diesels, mas mataas mas maganda.
    #653
    Quote Originally Posted by babynos01 View Post
    i see, i checked the spec sheet also, andun nga nakalagay.
    so, what drain interval do you follow with this oil?
    Sep 2011
    #654
    Every 10k ako nagpapalit sir e. Fully synthetic naman kasi. Pero a lot of montero owners change their oil frequently. Say, every 5k on a mineral oil while others do 5k din pero fully synthetic.
    On this case, baka sa 5k ako mapalit. Try ko lang haha.
    Jul 2012
    #655
    Hi, may nakapag PMS na po ba sa inyo sa Car World Malolos? Okay ba magpaservice sa kanila? TIA.
    #656
    Quote Originally Posted by jmtyper View Post
    Mukhang hindi normal yan sir since malapit na byahe lang naman yung tagaytay if you're coming from NCR. Ilang inches ang binaba? Did you notice if yung katabi nyong monty is naka bigger mags or tires? I heard pagnagpalagay ka ng spring cushion medyo tataas din yung ride height.
    Bumaba ng 1 or 2 inch kasi yung side mirror ko eh kita kita side by side sa monty na stock. Pero nagpanic lang pala ako that time, ngayon ayoko na mag full tank pag long travel, half tank na lang. Thanks sir!
    #657
    parang imposible naman yan sir na bumaba? maaring sleeepy ka lang nung time na yun at namali ka lang ng pansin sa tinabihan mo para ma-aktwal mo, much better refer ka sa manual kung anong min. ground clearance (i think nasa 215mm, not so sure!) then sukatin mo kung bumaba nga. mahirap kasi sa tingin lang tayo nagbabase. in case may deflection nga sa suspension mo ay pwede mo siguro ibalik sa casa yan ng macheck nila. HTH
    Sleeepy nga po siguro ako nun sir.hehehe. Nagpanic lang ako nung mga oras na yun, eh nung nag half tank na yung karga ko na diesel eh tumabi ulit ako sa stock na monty, eh ok na yung height. Ayoko na mag full tank pag pito ang sakay. thanks sir!
    Apr 2012
    #658
    Quote Originally Posted by sleeepy View Post
    ok lang yan sir sleepy, pero ok din na napansin mo kasi once na bumaba talaga ay may problema sa suspension mo. normal lang kapag mabigat talagang bababa pero babalik naman yan sa dati. you need to fill in full tank sir lalo kapag malayuan ang byahe kasi di mo sure sa pupuntahan mo o along the way kung may fuel station ba o ok ba quality ng krudo sa destination mo. be wary about the quality of fuel kasi maraming cases na problema ng ibang montero users ay dahil sa maruming diesel. tingin ko naman ay full tank + 7 pasahero ay yakang-yaka ng montero natin at di pa gagapang...
    #659
    Good day mga sirs,
    Had my 1000 km PMS at DCT Holdings Balintawak with the following:
    Baldwin BD28 (c/o a fellow tsikotero)
    Delo gold Ultra 7 L
    Miscellaneous items (casa)
    Total cost 2648
    SA is Mr Nelson Tangog. Mabait and magalang and allowed me to watch the PMS. Yung mechanic ko di na naiangat ang car initially kasi puno ang casa so ang nagawa is change filter and oil lang tapos check engine bay and lights. Medyo ok naman na sana ako but when I told Sir Nelson na hindi pwede yun and kailangsn nila gawin ang tightening ng bolts. I was impressed with customer service kaya definitely dun na ko for my 5000km. Brought the car in ng mga 8am, tapos na ng 10am.
    Aug 2012
    #660
    Anybody nagpa-1km PMS sa Peak motors Manila Bay? Do they allow you to bring your own oil, etc? Medyo mahal kasi pag sa kanila lahat, nasa 7K. Nagtanong ako sa SA, hindi daw pwede, pero as per some posts here, wag daw maniniwala sa mga SAs eh. Pa-share naman ng experience on this. Thanks in advance.
Montero Sport PMS Thread
