Page 32 of 162 FirstFirst ... 222829303132333435364282132 ... LastLast
Results 621 to 640 of 3240
    Jul 2012
    #621
    Quote Originally Posted by carwhacko View Post
    How about Citimotors do they allow bringing of own engine oils and filters? TIA
    Ayaw nila. Sa Diamond pwede.
    Jul 2010
    #622
    sir sa 20k pms pinakamahal na ung P13600.00 kasama na EGR cleaning, with turbo xp na FS oil P18K is too much pls check PMS schedule in your booklet
    Aug 2003
    #623
    Sa mga nagpalit na ng differential, transfercase, at manual transmission oil, ano gamit niyo?
    Aug 2004
    #624
    GLS-V 4x2 A/T 1k PMS done yesterday * Freeway Motors.. also replaced the puny stock horn. here's the amount as stated in the receipt..
    *OIL CHANGE
    ML109800 TURBO XP - 8L (615 x 8) 4,920
    1230A045 Oil Filter - 1 1,042.72
    MD050317 Washer - 1 41.44
    __________
    6,004.16
    -800 (less discount)
    __________
    5,204.16
    *REPLACEMENT OF HORN
    replace horn (labor) 450
    parts (terminal/ bosch relay/wire) 623
    parts (addt'l terminals) 39
    _____________
    1,112
    TOTAL Payment -- 6,316.16
    ngayon ko lang napansin na 8 liters ng oil ang naka-charge. di ba dapat 7 lang? nilagay kaya lahat yun? although may isinoli sa akin na 1 bottle na half yung laman. di ko na kasi nacheck kahapon yung details coz madami kasabay na resibo pinapirmahan at medyo nagmamadali na ako. brought the car in at around 1:20pm at natapos ng 4pm. anybody experienced this "8 liters thing"?
    if i may rate ang service sa Freeway Motors
    pros:
    - makikita mo yung car sa customer's lounge at pwede pa lapitan habang ginagawa basta magpaalam lang sa SA.
    - free coffee pero limited lang. nung naubos yung 10pcs yata na 3in1 sachets eh di na nagrefill..
    cons:
    - no wifi
    - no free carwash
    - may mga smudges sa fender na di napunasan mabuti
    #625
    *OIL CHANGE
    __________
    6,004.16
    __________
    5,204.16
    parang mahal ata ng change oil mo. sakin eto gastos ko for the 1st 1000kms check ko:
    -Perform 1000Kms: P480
    -Cleaning Materials: P150
    -Oil Filter: P1044.24
    -Drain Plug, Gasket, Pan: P41.64
    -Colored Rags: P15.45
    -Mitsubishi Oil 7L: P1,671.04
    -Engine Flush 3pcs: P712.05
    Total: P3634.42
    may car wash pa yan. sa Union Motors Paco ako nagpa check. synthetic ba pinalagay mong oil?
    pwede mo din makita yung sasakyan mo sa lounge habang ginagawa at pwede ding lapitan. meron ding free coffee at juice ikaw na bahala mag timpla GLS-V 4x2 A/T din ang akin
    Jun 2011
    #626
    Quote Originally Posted by ek2jayvee View Post
    Sir dapat masunod ang nasa manual na SAE 75w-85/ GL-3 or GL-4 para sa manual transmission at transfercase. Kahit anong brand importante 75-85 GL-3 or 4, kung hindi at ibang SAE viscocity mapapalagay gaganit ang shifting, ibang iba. Sa ibang casa SAE-90 nilalagay nila sa M/T resulta hard shifting tapos sasabihin talagang ganoon. Masisira synchronizer ng transmission pag nag hard shifting na. Ang problema mahirap makahanap 75-85 kahit sa casa wala ata.
    Sa differential GL-5, kahit SEA-90 LS puede na wala din SAE-80 dito na specs sa manual.
    Try to find Redline MT-80 or Castrol Syntrans 75W-85 for M/T.
    Aug 2003
    #627
    *perrydel, Sir thank you. Very valuable input. It seems kailangan ko maghanap talaga. Sa differential, mukhang madali lang makakahanap ng GL-5 SAE 90. Problema ko yung GL-4 75W-85 for the transfercase and manual tranny. Wala pa ako nakita na ganyan ang specs. Puro 90 grade e.
    Aug 2004
    #628
    Quote Originally Posted by alvinladen View Post
    Total: P3634.42
    yes, i opted for the synthetic oil kaya inabot ng 5k++.. around 2,800++ lang sana kung mineral oil.
    di ba free ang labor sa first 1k & 5k pms? bakit meron nakacharge sa into na 480. sa receipt ko kasi nakaindicate din yan pero ZERO ang charge. free din yung cleaning materials at rags.
    #629
    i used castrol limited slip 90 on front and rear differential, mag1 on transfer case gl4 75w-90
    Jul 2010
    #630
    Total: P3634.42
    sir sa ibang casa 1st 1000k pms free po yon may coupon jan sa green na booklet, tapos ang engine flush is too early for 1000k pms sayang lang P715.00 at P480.00 na labor ng 1000k pms.
    Aug 2003
    #631
    Quote Originally Posted by zix888 View Post
    Sir zix, thanks. Medyo mahirap maghanap ng fluids grabe.
    I was able to buy Castrol MTF The protector series 80W-90 GL-4 for my manual tranny and transfercase. Mobilube HD GL-5 80W-90 for the differentials. Yung Mag 1 nakakita ako fully synthetic 75W-90 pero GL-5 super mahal and mineral 80W-90, but bought the Mobilube since it was cheaper.
    #632
    yes, nagulat nga ako nung gumamit sila ng engine flush. nalaman ko lang nung tapos na at nagbayad na ako. di ko nga sure kung talagang ginamitan nila eh. ginamit ko din yung coupon dun sa green warranty booklet pero may bayad talaga.
    #633
    sir ilan na ba mileage? sa manual kasi every 100000kms yung transfer case, kaya nung buksan ko yung sakin at 45000, eh parang bago pa talaga yung oil, sayang. yung front diff. halos bago pa din, pero yung rear pwede na at 45k(sa gamit ko-everyday use, 4h once in a while when slippery roads). kaya i made a personal table na lang based sa usage ko when to change rear/front gear oil and transfercase oil. ( reference , from casa 0km to 45000kms actual inspections/change of oils)
    #634
    Mga sir, tanong ko lang kung naadjust ba height ng monty naten? kung meron paano at magkano nagastos. After kasi bumyahe galing ng tagaytay with 7 passengers pag tabi ko last night sa gasoline station sa isang monty napansin ko bumaba talaga. Thanks!
    #635
    Hi Zix, aside from almost 7 liters of oil for a 2.5L monty engine, how many liters are required for the rear/front gear oil, tranny oil (MT & AT) and transfercase oil (first time I've heard of this)? Sa previous diesel vehicle ko dati there's only the engine, tranny and rear gear oil to replace.
    #636
    Btw, thanks uli for the aircon cabin filter and baldwin oil filter.
    #637
    Quote Originally Posted by sleeepy View Post
    Mukhang hindi normal yan sir since malapit na byahe lang naman yung tagaytay if you're coming from NCR. Ilang inches ang binaba? Did you notice if yung katabi nyong monty is naka bigger mags or tires? I heard pagnagpalagay ka ng spring cushion medyo tataas din yung ride height.
    Apr 2012
    #638
    parang imposible naman yan sir na bumaba? maaring sleeepy ka lang nung time na yun at namali ka lang ng pansin sa tinabihan mo para ma-aktwal mo, much better refer ka sa manual kung anong min. ground clearance (i think nasa 215mm, not so sure!) then sukatin mo kung bumaba nga. mahirap kasi sa tingin lang tayo nagbabase. in case may deflection nga sa suspension mo ay pwede mo siguro ibalik sa casa yan ng macheck nila. HTH
    #639
    Quote Originally Posted by jmtyper View Post
    thanks din sir. yung front axle and transfer case sa 4x4. rear axle naman 2.6liters. bili ka 3liters, siguradong sobra pa. cant go wrong kasi while filling up, pagnagstart na umapaw/tutulo sa lowest postion ng filler hole, thats it
    Sep 2011
    #640
    Sirs goodevening po. Share ko lang yung 40k PMS ko outside casa.
    4L Eneos ATF DIII * 240pesos/L
    8L Idemitsu 5w40 * 1900/4L
    Oil filter * 880
    Fuel filter * 2200
    Labor * 400
    Total cost = 8240.00
    http://img165.imagevenue.com/img.php..._122_566lo.JPG
    http://img228.imagevenue.com/img.php..._122_216lo.JPG
Montero Sport PMS Thread
