yung sensor in between ng air intake box saka turbo
^ no idea sir sa ride comfort ng mga binanggit mong items, all stock ang 2012 old na unit ko. wala pa ginalaw sa suspension assy
Hi Sirs,
I will be having my 1k PMS soon and would like to check with you if I can bring my own engine oil and what variant of full synthetic engine oil should I get for Montero 2017. Thanks !
Sent from my SM-G950F using Tsikot Forums mobile app
Question po.
Kakasya ba ang Baldwin BD7028 sa Montero 4D56?
Thank you.
Sent from my SM-G7102 using Tsikot Forums mobile app
Thank you, Sir. Hindi ko sure kung anong year. Sabi lang ng kapatid ko 4D56 Turbo. Pero I believe pasok sa 2010 and earlier.
[QUOTE=monty_GTV;2886347]i have not use yokohama geolandar. you may want to check out gt savero at+, i'm on my second set na, so far ok naman...
Alright, il give it a try. Ilang years din ang lifespan nya?
[QUOTE=HugoThor;2886585][QUOTE=monty_GTV;2886347]i have not use yokohama geolandar. you may want to check out gt savero at+, i'm on my second set na, so far ok naman...
Sir, planning to have my EGR blanked, then bka try din K&N filter ska OCC. Newbie question lang, ano po advantage? Ska magkano din kaya budget na need allocate?
Hi,
Pahelp naman anong K&N air filter and cabin filter ang kailangan for monty 2017. Yun part number. Paturo naman po kujg paano hahanapin. Thanks
Hello sir
Ano po yun model o product code ng K&N Cabin filter for montero 2017 gls premium ? Salamat in advance
Hello sirs
Question lang po sa Cabin filter ng Montero 2017 Gls premium. Ano yun compatible equivalent nya sa K&N ? Thanks
* mask rider, you need to know the model. BD7028 will fit 2010 or earlier. kapag gen2 na 2011 and up to 2015, BD28 yung kasya.
* hugo thor, lifespan depende sa gamit mo. iirc, 1st set ko lasts more than 86k+ kms, almost 3yrs used
15KKm PMS - P7.2K
Practically oil change (semi synthetic)...
Waived recommended cleaning of EGR and wheel alignment
Condenser fan replaced under warranty (mabagal daw ang ikot - i have not noticed it,- so maybe caught through a diagnostic test).....
Peeps anybody tried using Blue Chem CRDI fuel additive? pros and cons?
What's the biggest tire size that can be installed in Montero without any lift/mods?
Sent from my ONEPLUS A3003 using Tsikot Forums mobile app
Am using stock rims. Gusto lang sana lakihan gulong while maintaining stock. Thanks.
^ ganda nga tingnan iyong mga slightly malalaki gulong pero stock rims na naka a/t tires at mas lalo na naka mud tires. 😍
Usong uso sa australia at russia ata iyong ganyang setup sa mga 2nd gen na monty aka challengers sa down under at pajero sport naman sa russia at ibang bansa. Bangis eh! 👌
when you look into the abyss, the abyss looks into you
