Page 99 of 106 FirstFirst ... 49899596979899100101102103 ... LastLast
Results 1,961 to 1,980 of 3240
    Sep 2009
    Quote Originally Posted by dct View Post
    May konting kabig ang 2012 montero namin. Pantay naman ang psi ng gulong. Ano next gawin? Alignment? Balancing?
    Sent from my SM-A9000 using Tapatalk
    If you have to choose between the 2, better to choose alignment. Best option is to do both. In Servitek, it would cost less than 1k to correct alignment (camber, caster, toe). It would cost around 500 for balancing of all the wheels, another 500 for rotation. So there, ~2k.
    Tell tale sign of misalignment is uneven tire wear. Hindi pantay yung kain sa gulong, either sa loob lang o sa labas lang.
    Jun 2012
    Quote Originally Posted by i.am.aids View Post
    Pag sinabing camber correction, alignment na yun? Pantay naman ang kain ng gulong
    Sep 2009
    Bale 3 yung usually ina-adjust pag sinabing "alignment". Sasabihin naman nung technician kung alin yung kelangan i-adjust.
    Jun 2012
    Thanks sir. Very informative
    Jun 2007
    Got my pair of bendix brake pads for my front wheel at approx 2t 6 months ago. Di ko pa napalitan yung likod pero brake drum yun. At least you have an idea how much would be the estimated total cost...
    Jun 2007
    Though im not expert sa battery, pero the difference could be the quality of materials used in each class of battery or could be the no. Of plates. Kaya mas mahaba ang buhay ng ibang batteries over the other. This is the reason why the warranty varies. I tried motolite gold several times sa civic at lhat naman ay lumagpas sa warranty period. Also the gs brand na tumagal sa kin ng 4years. For maintenance free batteries, after the warranty period, tinatanggal ko temporarily yung sticker sa ibabaw then dagdag lang ng distilled water. Naiiwasan ko yung biglang mamamatay na lang ang battery. Now, im using the ac delco brand para masubukan ko rin. Hth.
    Jun 2007
    Nalilinis din ba ung evaporator ng rear ac ng montero? Meron bang separate filter un just like the front cabin filter.
    Jun 2007
    Never encountered an amaron battery pero for motolite, pretty obvious na pag tinanggal mo yung sticker, meron 6 cap covers na pwd mo i unscrew using a peso coin.
    Apr 2012
    ^ imo, compromise na ang ride comfort if mag lift. for reference, check mo fb ng blueline car accessories, atoy customs 4x4 and bodykits at jeff's offroad. marami silang pinapalitan ng suspension assy to give you an idea
    Ganon ba yun sir mon_gtv, pag nag 2" lift compromise na ang ride comport eh kung hindi mag 2" lift then palit ng 4way ridemax shock at lovells spring mas gaganda ba ang ride comport compare sa stock spring at shocks, need ko idea bago ko visit blueline
    Jun 2012
    Ano pa ba dapat gawin sa 2012 montero na nasa 51k pms na? Parang makupad na sya compared dati e. Di naman sobra. Hahataw pa rin. Pero medyo napansin ko na sluggish na. Change fluids na. Change oil na rin nung 48k km. Am i missing something?
    Sent from my HM 1S using Tapatalk
    Apr 2012
    install a throttle controller bro, sisipag yan walang biro
    Jun 2012
    Hehe. Pero nagtataka ako kasi bakit parang kumupad? I mean ok lang sakin ang takbo dati. Bakit kaya nagiba?
    Apr 2012
    nuon ganyan din unit ko. try mo bro palit air filter kung oem, linis lang if k&n, linis ng maf sensor, linis ng egr if hindi naka-blank. if malapit ka kay bro zix ipa-system check mo
    Baka naman nagloloko na turbo niyan.
    Jun 2012
    Pano linis maf sensor sir?
    Di naman sir. Kaya pa rin humataw. Not a big issue really. Pero pansin kong humina
    Apr 2012
    pwede cotton bud saka isopropyl alcohol bro, linisan mo lang yung probe o yung parang palito ng posporo baka madumi. better kung may quick drying contact cleaner ka, bugahan mo lang. try mo lang along with the air filter cleaning
    Jun 2012
    What and where is maf sensor sir?
    ^ palit na kayo lately ng fuel filter? Everytime.change kasi ako nyan napapansin ko mas mabilis response ng Monty namin bro
    when you look into the abyss, the abyss looks into you
    Jun 2012
    Pinalitan din sir nung mga 45k km e. Egr blanked na rin pala yun dati pa
Montero Sport PMS Thread
