Page 672 of 718 FirstFirst ... 572622662668669670671672673674675676682 ... LastLast
Results 13,421 to 13,440 of 14348
    May 2016
    #13421
    mga sir bago lang ako dito, may tanong lang ako sa fm ko, may knocking sound pag bigla kong tatapakan yung accelerator. pero pag dahan dahan ang rev ko wala naman knocking sound. nagpacalibrate n rin ako ng injection pump ko, um-ok nman sya nwala yung tunog pero bumalik ulit after a month. ano po kaya possible problem ng fm ko? wag naman sana sa engine at sigurado malaki gastos nito. salamat po
    Mar 2013
    #13422
    yan din yung white part na inayos niya sa akin. may gel daw dapat sa loob niyan and pure contact points. magkano singil ni jemson?
    1.2k halos pero 1k nalang siningil sakin. 👍👍👍
    Sent from my SM-N9208 using Tsikot Forums mobile app
    #13423
    Diyan din ako nagpapagawa kay Jemson/Jorge's radiator shop pag sa radiator. May tambay po ba ang pajero group jan? Madalas dun mga naka Patrol, mababait sila, they even gave me a bottle of beer nung nagpa overhaul ako ng radiator last time.
    Sent from my SM-N9208 using Tsikot Forums mobile app[/QUOTE]
    May 2016
    #13424
    Does anyone know the part number for Bilstein shock absorbers? front and rear
    Mar 2013
    #13425
    Quote Originally Posted by chieftein View Post
    Parts catalogue
    Hope this helps.
    #13426
    Ano ba difference ng 15C sa 17C?
    Bigger compressor kaya mas madali nya mapalameg yung cabin sir Nelany ...
    Kelangan mo lang is yung pulley ng luma ma transfer sa 17C para match sa belt.
    Btw RT
    Watcha think? Hehehe ...
    Btw RT
    Very nice bro!
    #13428
    Btw RT
    nice! sino gumawa?
    #13429
    Very nice bro!
    Thanks RT
    *CB ... as usual D.I.Y. install .. plug and play lang naman cya sa old wiring harness ... hehehe
    #13430
    Btw RT
    Ah ok.
    Nice DIY.
    Jun 2016
    #13431
    Good day po mga sir, newbie here and I would just like to ask some questions about our 2002 Pajero Fieldmaster 2WD Auto with the 2.8 TD. The car has 180000kms on it and it runs well, but there's exessive black smoke upon accelerator input or even whenever the revs go up, even with no load at idle. As I said, the car runs decent and pulls alright, although I can't make much of a comment since I haven't driven another Pajero but there seems to be too much fuel since it appears to have not so good fuel consumption and again, the black smoke.... I'm thinking that the problem's with the fuel/injection pump or the turbo(??) Also, the intercooler and its pipes have quite a lot of oil in it. I do understand that there will usually be very little or even just a thin film of oil inside from the breather but this also seems quite excessive. Any thoughts po, mga sir? Thank you po and sorry for any mistakes, I've always been reading through these forums and finally decided to sign up
    Aug 2009
    #13432
    Quote Originally Posted by Matt_hew View Post
    Same problem here. Black smoke sa revving pero wala naman lagging sa hatak. Pina calibrate ko na injector,na linisan na rin turbo and intercooler, change air cleaner n fuel filter. No avail. Need expert thoughts pls... Do i have to pullout the injection pump for calibration?
    Quote Originally Posted by omzhky75 View Post
    Yung EGR po ninyo yan, baka stuck-up na. Palinis niyo. Check niyo na lang sa internet kung saan banda egr nang 4d56 or 4m40.
    Sa akin blanked na yan. Check niyo a lang din ang egr blanking sa net.
    Jul 2014
    #13434
    mga bossing patulong naman
    2002 fieldmaster ng tatay ko may beeping sound pag pinatakbo na. wala namang timer pero pag pinatay yung makina, nagdedelay sya around 1-2 min. parang naka-turbo timer
    minsan naman nawawala.. masyadong istorbo kasi mga boss pero walang namang lag o maitim na usok pag inarangkada.
    2.8 2WD fieldmastrer yung unit mga sor. local
    salamat!
    Aug 2009
    #13435
    b
    Nka blanked na sir ang egr. Ano pa kaya possible icheck bago ko ipullout eto injection pump for calibration?
    #13436
    b
    Dalhin mo sa Central Diesel para ma check kong due na for calibration.
    #13437
    Happened to me a few years back. Pinalitan lang ung nozzle then OK na.
    Jul 2014
    #13438
    Quote Originally Posted by eric_egboy View Post
    salamat!
    Up ko lng mga sir, baka may alam kayo
    Salamat
    Mar 2003
    #13439
    meron ba kayo idea kung saan makakakuha ng Rear diff ng fieldmaster? meron na ba sa inyo nag ka problema sa gears sa loob?
    Sent from my SM-G9287C using Tapatalk
    #13440
    PB, ano problem ng differential mo?
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
