Page 671 of 718 FirstFirst ... 571621661667668669670671672673674675681 ... LastLast
Results 13,401 to 13,420 of 14348
    Yup walang nga daw conversion from 15c to 17c. Kapag bumigay na sa akin surplus na 17c din ipapakabit ko. Si BG alam ko 17c na din ac compressor
    Sent from my LG-H818P
    #13402
    Ano ba difference ng 15C sa 17C?
    Pang toyota hiace van kasi 17c so mas malakas magpalamig.
    #13404
    Salamat RT,
    Jun 2007
    #13405
    Hi Guys, re. my FM A/C. I ended up having it fixed at Ceejay in Las Pinas. I decided also to retain 15c compressor. They said that 17c is bigger than 15c thus it is an additional burden to the engine. So far so good, but still under observation.
    FYI, according to Ceejay, A/C at the back should be used at all times because its part of the system.
    #13406
    Quote Originally Posted by andrewbugs View Post
    Yup dapat naka on yung likod na aircon. Im still using 15C since ok pa siya. Still malamig yung aircon. Regular cleaning lang ang kailangan.
    Mar 2013
    #13407
    Hello mga sir ask ko lang if may idea kayo where i can get this Part. Airbag assembly, Part No. MR 307479
    sira na kasi yung horn pad, stuck up na busina tuloy tuloy na. Asked the casa if kaya nila gawin, ayaw nila open airbag assembly kasi delikado daw.
    May nakausap na ko from Lipa Batanggas kaya lang when i looked at the pic he sent me, wala ata yung wiring na red and black unlike nung nandito, di pa sya nagreply ulit e.
    Thank you for the reply!
    Attached Thumbnails Attached Thumbnails 13087726_10206249664264402_1524004408390095042_n.jpg   13055469_10206249664424406_6486674370526165154_n.jpg
    #13408
    Quote Originally Posted by Yeo View Post
    i had that problem also before. taga saan ka ba bro kasi dito sa amin may marunong mag open sa airbag na yan.
    yung small white horn pad sa ilalim ng airbag assembly ay stuck up na yan. what they did was, they slice that white thing in half para makapag bounce yun the moment you press the horn.
    or yung circular thing na dilaw at itim yung color dyan sa may steering (yan yung saan mo idikit yung dalawang wires na sinabi mo), ang sa ilalim ng black and yellow circular thing na yan ay mga ribbon wires. baka dyan din ang problema.
    i hope i make sense to you ☺
    #13409
    bro ito yung yellow circular thing na sinasabi ko (i dunno what is its part name kasi):
    #13410
    hornpad ko naman before ayaw tumunog. si Jemson lang nag repair.
    #13411
    ^thanks CB for posting your pics.
    *Yeo, this is what i meant (sa ilalim daw dyan ay mga ribbon wires that connected to the horn pad and airbag)--
    #13412
    i remember Jemson prying open the airbag, in between the airbag and the horn pad, theres a gel like substance in a bag which eventually nauubos daw. thats the reason why mahirap pindutin yung horn pad.
    for the continuous horn, not sure lang if same ba.
    Mar 2013
    #13413
    *Juan Martinez thanks for the quick response sir, i think yung yellow and black thing youre referring to is yung clock spring ata if im not mistaken. Manila area ako sir, tondo.
    *crazy_boy di naman na damage yung airbag sir?
    Salamat sa reply mga sir
    Sent from my SM-N9208 using Tsikot Forums mobile app
    #13414
    ^hindi na damage yung airbag. sa banawe lang si Jemson.
    Mar 2013
    #13415
    *crazy_boy sige po sir try ko din. Coding lang ako ngayon medyo alanganin baka abutan hehe. Salamat ng marami!
    Mar 2013
    #13416
    *crazy_boy sir magkano pala gawa nung sayo nun kay jemson?
    #13417
    mura lang. less than 800 lang yata nagastos ko that time.
    Mar 2013
    #13418
    Boss *crazy _boy thankyou. Medyo nagtaas konti price ni jemson pero okay lang sulit naman okay na gawa. 👍
    #13419
    yan din yung white part na inayos niya sa akin. may gel daw dapat sa loob niyan and pure contact points. magkano singil ni jemson?
    #13420
    ^yan din problema sa akin in the beginning. it was fixed, but after sometime na nagkaproblema yellow circular disc na may mga ribbon wires daw sa ilalim.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
