Thanks Ry and Blue, plan ko talaga 20" , 18 nga at a standard an for stocks. Magtatanung pa me sa tires Kung and di matagtag. May display sa world trade at a dis week, auto show no avid, damp din suppliers siguro dun. Anyone here knows where to convert 3rd row seats and change from bench to front facing? Thanks man!
grabe naman yung picture nung intake valve.. ang kapal naman ng dumi.. hehe parang di mag cloclose seats ng valve pag ganyan kakapal ang carbon niya or dumi.. hehe
naalala ko nga dati.. diba nung bago palang 20s.. wow 20s.. low profile suv.. di na pwede pang daily drive yan... etc etc
pero parang not so bad nga talaga 20s..
may kaibigan ako 22s.. hindi din maingat mag drive e.. stock height.. montero sport so.. assume ko di malaki diameter.. although to be honest minsan natatakot nga ako and minsan napapaisip na delikado..
Mga sir, mag-inquire lang ako ng mga recommended oil type, kung ilang liters ang kailangan kapag magpapalit and yung interval ng changes?
Engine Oil
Automatic Transmission Fluid
Brake Fluid
Rear Differential Fluid
Power Steering Fluid
Medyo maingay na rin yung brakes sa harap. Brake pads lang kaya yun or may deeper problem pa?
Yung pajero namin is 2001 4x2 FM na 4m40 engine. Thanks!
1) 7 liters of delo 400
2) atf- mobil 220 (don't use anything else i had mine rebuilt after using shell spirax
3) with respect to brake, differential, power steering fluids, wala namang problema yan. you can use anything.
4) i spent a little fortune restoring the fieldmaster but i think it's all worth it.
5) replace the pads. they're not expensive. ask the mechanic to check the rotor disc and the piston if they're still working fine.
6) it's a 15 yr old work horse, so change all fluids.
nasa magkano po yung delo400?
i use cheapest oil lang kasi.. petron superdiesel. tapos naisip ko palitan ko nga to better.. masyado yata mura oil ko.. 105php per liter and 95php after discount... i use it on all our vehicles except yung bago..
medyo malakilaki na rin bro. wala namang nagbago sa maintenance cost after the restoration. the good thing is, oil change na lang every three months with mineral oil plus baldwin oil filter (BD28), bosch air filter and baldwin fuel filter every 6 months.
more than one year yung restoration project ko. i started sa suspension (replaced all worn out parts), then a little tweaking on the engine (di ko pa na overhaul), rebuild the AT, calibrate and overhaul the IP, replaced the starter, compressor, alternator, radiator, changed the mags, bought new tires, installed bumper overider, installed foglamps and rooflights, upgrade the headlamp, new upholstery, new HU and subwoofer, installed turbo timer and volt meter. when i reached 100k i stopped counting anymore. cguro i can already buy an old vios (2010 or older) for all that. i replaced the steering wheel too. i'm planning for a washover but casa quoted me 60k. i will install a TPMS soon. papalitan ko din yung steering shaft joint assembly (part number: MR113004).
Try niyo Rimula R4x. Very satisfied with it. 215/L.
Welcome back Bro JM! Ang dami mo na palang pinalitan sa FM mo. Ganyan talaga pag me edad na yung rig natin puro labas ang pera.
