Page 682 of 718 FirstFirst ... 582632672678679680681682683684685686692 ... LastLast
Results 13,621 to 13,640 of 14348
    Quote Originally Posted by ollopasagla View Post
    Patulong mga Boss, ayaw umabot ng 2000 ang RPM ko, ano kaya posibleng problema? 4m40, automatic
    Thanks,
    ollopasagla
    Tranny issue yan or fuel pump problem. Ipacheck mo na suki mong auto shop sir. Baka lumala pa yan.
    #13622
    Thanks,
    ollopasagla
    Like RT said ... its probably your fuel pump or fuel filter. Ganyan saken dati namamatay lagpas 2k .. buti me call a friend RT tyo ... hehehe
    hehehe
    Mar 2013
    #13624
    Quote Originally Posted by boybig View Post
    mga bossing san po ba ang shop nung jemson? nababasa ko mga post sa kanya mukang ok gumawa e. electronics ba ang forte nya?
    t3enks sa rereply
    Banawe boss. Near sogo tapat ng chicken charlie. Sa gilid ng kalsada lang yun. Pero okay sya gumawa. Tried and tested numerous times ko na
    Sent from my SM-N9208 using Tsikot Forums mobile app
    Mar 2013
    #13625
    Thanks,
    ollopasagla
    Everything previously mentioned is plausible reason. Add to that pa check mo na din ATF fluid or have an ATF dialysis. It should be done every 70-80k kms.
    Mar 2016
    #13626
    boss para saan po oil catch can? ano benefits nya? wala kasi fm namin eh hehe
    Mar 2016
    #13627
    may nakapagpalit na sa inyo ng stabilizer link? maingay kasi ilalim ko pag nalulubak. medyo budgetarian kasi ako. ang replacement daw kasi 700 ea. ang original 1400. okay na kaya replacement or worth it ang original? tia!
    Quote Originally Posted by laurencet View Post
    Basta japanese made at trusted nang mekaniko mo puwede naman.
    Mar 2016
    #13629
    ah ok boss. tanong ko kung saan gawa. nagdadalawang isip kasi ako baka madali masira rubber nung replacement kaya napapaisip ako sa original. thanks sa input boss. laking tipid kasi ng replacement
    Mar 2013
    #13630
    Go for original kung di naman ganun kalaki difference than doble gastos pag nag fail replacement and save time pag punta punta sa mekaniko
    #13631
    Quote Originally Posted by Yeo View Post
    Agree, kung pang ilalim na parts I always use yung OEM. Sa bigat ng FM siguradong hindi mag tatagal yung replacement parts. I already have this experience na doble gastos in the long run sa mga pang ilalim.
    Mar 2013
    #13632
    Just got back from cabanatuan.. tested my turbo back exhaust upgrade. I must say walang kahirap hirap makina.. up to 155kph at 4k rpm kaya pa i sagad kaso redline na.. dont want to push it too hard. Hehe.
    Yun lang... nataon din bumigay na fan belt.. bigla naputol haha. Wala tuloy aircon, good thing gani ang byahe. Had it fixed and replaced other belts as well.
    Mar 2003
    #13633
    todo sigaw na makina niyan. kawawa naman
    sayang yung for sale na used hitch pro adapter sa fb pajero page. 2k lang. sana may mag benta uli.
    Sent from my SM-G9287C using Tapatalk
    Mar 2013
    #13634
    Boss pb. Nag order ako don sa site na nirefer mo sakin. Okay! Within 3 days dumating delivery. Sulit yung T5 na 3SMD sa aircon panel.. not as bright as sa dash pero mas brighter and better than noong isang tutok lang na t5 white. 🖒
    Mar 2003
    #13635
    yes ok yan bro. same tayo ng gamit. sa aircon Control Try mo buksan para malinisan yung loob. sobra itim ng ganyan ko. Laki ng niliwanag. so far wala pa ako nasisira na 3 LED. sa experience ko mas matibay yung mga mukhang maliit na board with leds kaysa dun na naka plastic base.
    Mar 2016
    #13636
    help po. nung nagpakarga ako ng diesel sa shell nagcheck yung gasoline boy ng engine oil level. ang reading below minimum level. pero wala naman ko nakikitang tulo sa ilalim kapag nagpapark ako. chineck ko engine may nakita akong black. possible kaya dito nagleleak?
    yung location nya katabi ng 4m40 na elevated.
    Mar 2016
    #13637
    mga boss meron kayong marecommend na mekaniko qc area? tia!
    #13638
    Hindi kaya kapareho before na na experience ng isa nating kasama na pumupunta yung oil sa gas tank kaya nag babawas yung engine oil?
    Mar 2013
    #13639
    Yun nga din gusto ko sana gawin kaso nagaalangan ako mag baklas baklas ng mga adaptor sa likod ng aircon panel.. may step by step procedure ka ba doon boss pb? Hehe
    Mar 2016
    #13640
    mga boss pwede po ba DIY ang intercooler cleaning? paturo naman po simple steps. thanks!
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
