Page 547 of 718 FirstFirst ... 447497537543544545546547548549550551557597647 ... LastLast
Results 10,921 to 10,940 of 14348
    #10921
    In relation to BG's post, had the time to drop by Rey's Electrical to have an additional 12v outlet installed so that the plug-in voltmeter has a "dedicated" area... Medyo obstructive kasi for me dun sa power outlet sa may shifter and I often use it for charging as well. I decided to place it sa blank space above the hood opener.
    Total cost was P300 parts and labor (excluding plug-in voltmeter)
    Just like BG's, it was tapped sa accessory power supply and a fuse was installed.
    12V socket bought from DIY Shop for 80pesos
    Rear view
    Front view
    Finished product (For that OEM look hehe)
    Wala ako makitang voltmeter dito na maliit. Kakainis, gustong-gusto ko yang set-up mo sir junerski.
    #10923
    Thanks RT... Marami online sellers nagtitinda ah... Meron yung plug-in type, meron din naman yung parang may nakaabang na wires lang (for flush mounted applications; although wala ata lugar for our dash for this type) And most of them ship their items. Price range P250-800... (Malaki magpatong though yung P500 up price range IMHO and same din naman na product yung tinda nila)
    Eto yung itsura ng flush mount
    [IMG]http://cdn01.*******/20140813163535-7a6e9d44f2bad03b9ed9e76f1a633968.jpg[/IMG]
    plug and play
    [IMG]http://cdn06.*******/20140615043555-7c65221b2e13230275c8ccca7ddaa2dd.jpg[/IMG]
    #10924
    I observed lately na may dripping of coolant sa grahe. When I checked the radiator, mukhang may leak kasi may wet area palibot ng radiator top. Mukhang hindi naman galing sa radiator cap. What could be the problem? I also observed na medyo tumataas yung temperature gauge pag minsan.
    Thanks for any advice.
    Posted via Tsikot Mobile App
    #10925
    Quote Originally Posted by Sinoda View Post
    Sir baka may tagas na radiator top nyo... had my radiator top repaired recently... Please check my post sa page 1040...
    Quote Originally Posted by junerski View Post
    plug and play
    Kaya nga, order na lang ako online nung plug ang play tapos gayahin ko sir set-up mo ha. Maganda yung medyo madali makita eh.
    #10927
    Rear view
    Front view
    That's a good place to put that socket. Good idea!
    By the way, have you guys had problems with charging your phones from your lighter sockets? I bought a 2 USB slot Griffin socket charger and it doesn't seem to work in my FM. It works in other cars so I know the charger works. Now I tried using the lighter and it also works so I don't really know what the problem might be.
    Aug 2011
    #10928
    Sir para saan po b to? Sira na ung sakin hindi ko mabili kasi nobody seems to know what it is or what it is for. Saan po makakabili? Salamat po.
    Attached Thumbnails Attached Thumbnails 1408411811976.jpg   1408411832399.jpg   1408411853708.jpg   1408411876473.jpg
    #10929
    Yup no problem... Lalakihan lang ng konti yung butas dun sa area na yun kasi the 12v socket is kinda big.
    #10930
    Quote Originally Posted by zee View Post
    Sir, why not try bringing it sa casa para macompare nila sa parts catalogue nila... Based on your avatar you're from Dagupan? Ito nearest Mitsu dealer sa inyo based sa MMPC website
    Motorplaza, Inc. – Calasiao
    McArthur Highway, Calasiao,
    Pangasinan
    (075) 653-0174 (Service) / 653-0156 (Sales)
    Aug 2011
    #10931
    Salamat sir. Try ko casa.
    #10932
    Zee,
    Mukhang JDM yung Pajero mo. Subukan mong konsultahin si Joseph Atutubo kasi kabisado niya ang local at JDM na Pajero. I-search mo nang lang dito yung contact number niya.
    KILL, I usually encounter the same problem with my auxiliary socket below the radio. The lighter socket is not as "picky" as the auxiliary socket. Have you tried using another usb plug with the lighter socket?
    #10933
    Quote Originally Posted by Monty View Post
    Zee,
    Yes I have. Before I bought the Griffin, I bought a cheap one from a stall in Glorietta. It didn't work so I thought it was just a faulty product. I got a box of these Griffins and they work OK in other cars except on the FM. It makes me wonder what kind of voltage actually passes through. I used to stick a digital voltmeter in the auxiliary socket and it worked fine. The lighter also works OK in the lighter socket so I know both work. Maybe chargers require higher voltage?
    #10934
    KILL, why not have an electrician take a look at it. Maybe there's no contact with the sides of the lighter socket; which you need for a USB plug but may not be necessary to make the lighter work. Just a thought.
    #10935
    Ganito naman ung direct wire tap RT ... for reference ..
    Sep 2013
    #10936
    would like to share mine though it's not installed in FM, wire tap as well. God bless.
    #10937
    I'll probably give that a try. Thanks man. I just hope they find a solution. It's quite annoying how I can't charge in the car when I'm driving.
    Jul 2013
    #10938
    Quote Originally Posted by santosestrella View Post
    Finally received my first set of bay15d brake lights. The one on the left screen is led while the right is ordinary bulb
    Attachment 22579
    sir ask ko lang po, nagpalit din ako ng led.. ang problema ngayon pag apak ko ng brakes.. nag on un ilaw sa dash at speedo ko... mahina lang naman siya, after 1 week bago ko napansin kasi sa madilim ako nagpark.. kala ko naiwan ko naka on..
    May 2008
    #10939
    Quote Originally Posted by zairus View Post
    if it's not grounded...it has something to do with resistance since LED are very efficient.. a small electrical current is enough to power it. the phosphorous is also a culprit in some cases. use a tester and see if there are current running even when turn off
    Aug 2009
    #10940
    Gd am po mga sirs. San po ba dapat itap ang oil temperature sensor if i were to install an oil temp gauge?
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
