Mga ka-FM, when did you changed injection nozzles? And usually ba nozzle lang pinapalitan? Or meron pang ginagawang calibration?
Thanks po.
Dalhin mo kay Berrima. Dala ka ng fuel filter at air filter pag naka pag pa schedule ka sa kanila.
Mga sir ask lang ako ... medyo nag babawas ng engine oil ako ngaun .. so far wala naman ako leaks na makita ... wala rin sa ilalim .. di rin mausok pajero ko. Medyo out of ideas ako san mag hanap ng prob bket nababawasan...
Btw no-leak sa halfmoon seal or valve cover gasket ..
Your inputs are highly appreciated ... thanks
Did you wash your valve cover? Dapat linisin yung valve cover esp the area and where the breather hose will be connected. My experience, ang dumi sa loob. It is blowing oil out of the valve cover. Clean the gunk out and oil wont be blown out of it.
I think malinis naman yung valve cover since pinalitan na ng mechanic ko ung halfmoon last year and it was cleaned.. but i'll check the breather hose if its blocked. Currently naka connect yung hose sa OCC ..
But if things dont improve i'll check the valve cover and have it cleaned
Yung fuel tank mo drain mo at kuha ka sample. Kapag medyo hindi kulay diesel at grayish na, baka same symptoms with testa and my rig. You need to check yung injection pump nang 4m40 mo.
Nagbabawas din dati kasi engine oil ko pero wala leak. Ayun pumupunta na pala sa injection pump and then sa fuel tank.
nung nagpa overhaul ako ng IP kay malabon diesel before, kumuha din siya ng sample sa fuel tank ko. luckily simula palang ng leak kaya hindi pa contaminated diesel ko. pag contaminated na diesel mo, tapon na lahat yung nasa tank.
dapat clear ang color ng diesel. pag euro4, clear as water na. pag euro2, yellowish. pag may traces na ng black/brown, contaminated na with oil yan.
Yun din sabi ni Central Diesel sa akin nung isang araw kaya ni-advise sa akin palitan nila ang fuel filter. Kaka-text lang nila sa akin ngayon na ibabalik na nila yun injection at nozzles. Baka bukas pwede ko na makuha Pajero ko.
Nangyari sa injection ko daw is normal wear and tear dahil sa kalumaan. So labas, overhaul ng injection nangyari. Pati nozzles ko na pinalagay ke Berrima 2 years ago ay pinalitan din nila
Hindi RT, 23.5k ang inabot ng repairs hahaha! Nagtext na sila sa akin na binabalik na nila today ang injection pump at nozzles. Baka bukas makuha ko na sasakyan ko.
Yun lang. Madugo pala. Pero palit nozzles na rin naman pala. Complete overhaul siguro talaga. Sana tumipid para bawi yung cost hehe.
