Page 396 of 718 FirstFirst ... 296346386392393394395396397398399400406446496 ... LastLast
Results 7,901 to 7,920 of 14348
    #7901
    Nababahala na ko sa FC ng FM namin. Last FC na sinabi ng tatay ko ay 5.7 km/L lang, Sobrang baba na talaga. Wala naman kami napapansin sa takbo niya kasi malakas naman humatak. Pero medyo mausok siya. Tingin niyo ba ay kelangan ko na itong ipa-calibrate? Ako kasi, medyo hesitant pa ko at gusto ko muna subukan sa kanya na lagyan ng 2T. Pag in a week or 2 walang nangyari, malamang magpapa-schedule na ko sa CDC o ke Berima.
    #7902
    Ganyan din FC ko pag city driving. Naglalaro sa 5.7 to 6.2.
    #7903
    Quote Originally Posted by AC View Post
    sir CB...
    naka hid po fogs ng fm namin.. mahina parin po.. wala kwenta.. maliit po yata kasi reflector.. tinangal ko nadin yung parang harang na lata para hindi nakakasilaw.. mahina talaga buga.. hehe
    nagpachange oil ako kanina.. surprised ako after only 5k.. sobra dumi na pala ng k&n ko.. dahil kaya sa offroad?
    Your filter being dirty is a sign that it is doing its job. The dirt on the filter acts like an extra filter layer. You don't have to clean it. I started using K&N back in 1994 and they produce more noise due to the extra ability of the filter to suck in more air and they do filter out more dirt. Manila air is dirty and if you go off-roading, chances are you're kicking up a lot of dust hence your dirty filter. I used my K&N filter before for 20,000 km before I recharged it but I love the look of a nice slightly reddish and very clean K&N.
    ^ I clean my K&N every 10K din hindi 5K, basta kaya pa nang ilaw from my led light na mag-pass sa filter, puwede pa yan.
    Same here. Umaabot pa nga 5.5.
    * Testament: try mo muna 2t oil.
    May 2010
    #7905
    Mga bro, ok lang ba sa 4m40 ang diesel + 2t? And ano maganda brand and ratio? Salamat po.
    #7906
    best ko na sa city yung 6.2km/l hehe
    Nov 2011
    #7907
    Sir maaring injectors lang.sa 4d56 ko maganda rin tumakbo pero mausok. Decided to have it calibrated,ayaw naman ng calibration at ok pa daw kaya injectors lang pinalitan
    Feb 2013
    #7908
    i'm only doing around 5-5.3km/L...newly calibrated, tuned up, etc. though my daily itinerary is just a short drive to the office (less than 5 mins) and uphill at that. do you guys confirm that this is a valid reason for my high FC? my filters, oil, etc. are just a few months old.
    #7909
    ganun.. maybe nga kaya ako nagbara ng ganyan.. kasi... sa offroading maalikabok..
    medyo humina hatak ng sasakyan ko.. kagabi nilinis ko.. ok na.. hehe nabawasan usok and vibrations din.. hehe
    1st time ko lang maglinis ng k&n.. hehehe
    our fm 4m40 is still doing 7km/L
    our gen2 use to be able to do 8km/L (when i started driving it year 2003) now.. its down to 6+ only...
    #7910
    one more thing guys... yung white plastic na may fins.. parang nakakaharang sa intake.. napansin ko... malinis yung area na nasa ilalim ng white fins... kaya pagkainstall ko ngayon.. tinangal ko na yung white fins..
    Or puwede mo gawin is after 2,500kms eh ilipat mo yung fin.
    Kapag new engine oil, new tranny fluid at new differential oils, kayang-kaya ko 6.5km/ltr sa city driving. Malaking bagay talaga kapag bago lahat ng fluids.
    Jul 2013
    #7912
    gud day po sa lahat bago lang po ako sa tsikot forum baka po matulungan nyo po ako mga pajero guro i have a pajero fm 4/4 m/t 99 model may problema po ako sa 4wd nya baka meron po kayo na marerefer na mekaniko or shop na marunong sa 4wd especially sa pajero k tnx po in advance sa lahat
    #7913
    Quote Originally Posted by pbboy51669 View Post
    Anong klaseng problema meron sa 4wd ninyo? Tsaka taga saan kayo sir para pwede namin kayo matulungan kung saan kayo pwede magpaggawa
    #7914
    My FC is around 5-6 for city driving. My idling speed is a bit high at 1000 rpm but at this speed, I don't really feel the engine vibrate so much. What are your idling speeds?
    #7915
    Are those white fins part of the air filter or can they be removed? Around 10,000kms ago, I took my FM to a shop for servicing and changed the air filter. Te white fins seemed attached to the OEM air filter which was already clogged up so I threw the whole thing away. My current aftermarket filter doesn't have fins but it seems to be just doing ok. I think those fins act like a spacer and the way they are curved, it seems that they make the air go in a circular motion when they get sucked in. Well, that are just my thoughts on it.
    #7916
    Quote Originally Posted by K.I.L.L. View Post
    my idle speed is around 750-800rpm sir
    Jan 2008
    #7917
    those fins is there to equally distribute the air flow around the air filter.. it can be removed and transferred to you new filter..
    #7918
    Our JDM's idle speed is at 1k RPM at normal tenperature. Our Fieldmaster idles at 900 RPM at normal temperature.
    Hmmmm, walang white fins yun sa Fieldmaster namin simula nung nabili namin. Ok lang naman siguro na wala.
    Sent from my GT-N7100 using Tapatalk 2
    #7919
    yes.. removable po fins... i removed for both sa ngayon.. feel ko kasi nakakaharang.. hindi po siya pwede maikot sa kabilang side.. only fits one side... i dont know what purpose is..
    if purpose is to get air around para magamit buong filter.. hindi maganda design.. kasi its blocking half of the filter.. ang iniisip kong purpose is... to keep it in the center of the cylinder... pero... feel ko not really required since... pag hinigpitan naman yung wingnut... masikip and hindi na gagalaw.. hehe
    kaya tinangal ko nalang for now.. let see.. kung ano mangyari.. hehe
    Nagkaproblem JDM paj ko, sira na daw IC reg at diode assembly plus maingay na din bearing nang alternator. Kahapon ko pinagawa, sana maayos na din.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
