^kaya pala may squeek sound ang paj sa unang arangkada o atras sa brakepad pala malamig pa akala ko problema na yun at palitin pero after maginit nga nawawala. Re: sa post ko before about sa washer sa bumper area natunton ko na yun linya di naman clogged may mechanism ba yun sa reservoir o motor na nabibili if ever yun ang sira?
Pasingit sa brake problems.. kakagawa lang ng rear brakes ko resurface na rotors kasi umaalon pag preno.. so change pads narin.. kasi di pantay kain.. bendix.. umaalon parin pag mabilis tapos soft braking lang ginagawa ko.. ano pa kaya problema nito? Un front naman pantay ang kain..
Yep me motor yan, yung saken dati me leak yung seal ng pump kaya shorted sya kaya di sya nag work. Once it was sealed properly it worked properly till now, that was more 2 years ago..
*zairus sir pina reface mo ba yung brake disc rotor before replacing the pads? If not kelangan yan pa reface yan, and ideally use brand new pads as the wear on used pads especially the grooves indented by the unrefaced disc on the pads would make an impression on the newly refaced disk. refacing of disk is ideally done in pairs, so both rear or both front pair should be done the same time...Hope this helps you ...hehehe
Slotted rotors po kasi un front kaya sayang pa reface sir hehe.. kita naman siya kung pantay un kain.. so rear lang.. try ko muna palitan ulit un rear pads baka maging okay na..
The Ironman 50mm pajero lift kit should be pre ordered with 10 days shipping, The Paj was only here in manila for two days so we did the pajero mk2 lift australian style! We used patrol GQ coils and aftermarket extended shocks at the back. For the front end , torsion bar twist paired with stock shocks with sensors. Ended up having approximately 3.5 inches lift in the rear and 3 inches in front. We installed 285/75 r16 = 33x11.5 r16 Mickey Thompson muddies after the lift. (We were using 265/75 r16 mickeys at stock suspension height before the lift ). Paj looked wickedly sick after!
Patrol GQ coils sides, Pajero coils center.
[IMG]http://www.flickr.com/photos/99808093*N03/9436501996/[/IMG]
Installation
2013-08-03 10.39.10 | Flickr - Photo Sharing!
Tire fitting
2013-08-03 14.06.02 | Flickr - Photo Sharing!
LIFTED! !
2013-08-04 08.16.30 | Flickr - Photo Sharing!
HPIM1316 | Flickr - Photo Sharing!
looks really high and sick up close!
nissan patrol GQ rear coils, eto yung patrol natin nung 90s. Yung shocks was bilstein. Was not able to take a pic of the complete part number.[IMG]http://www.flickr.com/photos/99808093*N03/9436758472/[/IMG]
pero sabi sa australia standard height shocks ng hilux surf is ok. longer than pajero rear shocks. meron nun na kyb.
Hi. I'm a recent owner of a 2003 Pajero Fieldmaster. I wanted to ask what type of bulb is used for the fog lights? I haven't had a chance to remove it yet, and it does not specify in the owners manual. Hope you can enlighten me (no pun intended)...
Hi Pajero owners. Question lang po, what year ba yung pajero na meron roof rails? Thanks!
fm and gen2.. sa alam ko puros walang roof rails.. meron po nabibili stick-on roof rail.. but pang display lang daw po.. di pwede lagyan ng gamit...
if you want to put a roof rack on.. dapat ikabit sa rain gutter.. para matibay and will be usable..
guys.. questions:D
tama po ba.. ? kerosene ang gagamitin para linisin intercooler and intercooler pipe lines?
sa pajero natin H4.. nagshashare ang hi and low sa isang ilaw.. plan ko po kasi ihiwalay yung akin...
pag nilipat natin sa hi yung bulb.. namamatay na yung low.. meron po bang paraan para pag nilipat sa high.. bukas parin yung low? like other cars na... hiwalay ang hi and low? thanks
Maybe it would be easier to just change your light system. I don't think you can separate that and if you do, I think you need a separate wiring system for both the low and the high. If that were the case, the cost to do it might not make it feasible. And just to add, having both low and high on at the same time might damage the bulb. Those bulbs are made to operate at a certain temperature and if you have both on, it might increase the temeprature and make your bulb explode.
