[ame=http://www.youtube.com/watch?v=Sq5q0-1mWtQ]AGT 27w led fog light demo vs 55w stock bulb - YouTube[/ame]
share ko lang:D video ko ng 27watt led foglight:D meron round meron square:D
Liwanag talaga ng LED. Pero glare galore. Hope there were a way to reduce some glare.
Posted using TocinoTalk
Pinarepair nalang namin un old alternator namin. Okay naman. One click. At normal ang voltage.. problema umiilaw un a/t, battery at oil sa dashboard ng fm ko.. may solution po ba dito?
Kami po nagbaklas. Tapos pinarepair sa labas.. baka un alternator may problem na talaga?
Gd am mga sir. May nakapaglinis na po ba sa inyo ng intercooler natin? Just want to know the proper way of having it cleaned and pwede kaya i-diy?
Had a full tank the day after ng calibration ko. Kahapon, nagpafull tank sa Tagaytay. That 1 tank is 70% city driving, 30% highway driving, with 40% of the time eh hataw mode pa ako.
Fuel used is Seaoil Exceed Diesel with 2T
Consumed 56.xx liters.
Distance travelled is 366.3 kms.
FC was 6.47km/L.
Good day mga sirs. New owner po ako FM 2005. Just want ask po if you have experience:
1.) Delay yung pag light up ng gear indicator ( P, R, N, D) sa panel ng dash board.
Everytime pag newly start at cold pa yung engine, parang intermittent yung pag on/off ng green lights nya sa mga letters.
Pero after mag init yung engine (apprx 10-15 mins) ok naman po lahat and back to normal ulit.
I noticed po ksi pag Hindi naka green light yung "R" for reverse gear sa Dashboard Hindi ko rin po magamit at ma-activate yung reverse camera ko.
Thanks in advance for comments and suggestions mga sirs.
mga sir...
DO you know po ba ang F.C. NG pajero ck gas 3.5 V6... po ata yun?
Zairus this happened to my pajero last month after alternator repair. Indicator lights light up because of over voltage at volt meter at around 16v. IC of alternator may have a defect said the electrician after checking. Replaced with reconditioned alternator with better amperage from korea.
So over charging pala yan pag yung mga indicator lights lights up. So meron na tayong idea ngayon.
Thanks Sir blue_gambit. I will take note of your advise.
I will advise you later on the outcome. Regards.
Saan po maganda at murang magpapalit ng shockabsorber along banawe kyb brand lang ang ipapakabit ko and checkupna din ng ibang suspension parts... Tnx...
