Page 394 of 718 FirstFirst ... 294344384390391392393394395396397398404444494 ... LastLast
Results 7,861 to 7,880 of 14348
    Feb 2013
    #7861
    Use power spray, that could do it. Also make sure na you put the nozzle of the power spray in front of the nozzle para sa maluwag na connector (part kung saan kinakabit ang rubber hose) lalabas yung bumabara. Needle paulit-ulit mo din gamitin.
    Thanks for the tip sir. Though sorry to ask this simple question, by power spray, is this like an air only spray? Or is it liquid? And can I get these in stores like Ace, True Value, etc?
    Feb 2013
    #7862
    Quote Originally Posted by K.I.L.L. View Post
    My washers also got clogged before. You may have to take out the system piece by piece to find where the clog is. In my case, the guy had to suck out all the dirt which was a lot. I changed my washers since mine were too far gone. The washers are inexpensive so it's a cheap fix.
    Thanks for sharing how you fixed your washers sir. At least I now have an idea how to go about it if Mr. Ry Tower's tip do not solve the problem
    ^^Ako din nagpalit na, hindi na kinaya before kasi hindi distilled water gamit ng previous owner IMO. Adding a washer fluid will also help keep your nozzles clean.
    Quote Originally Posted by gearguru View Post
    With water, sa mga car wash mo na lang ipagawa yan. Remove the rubber hose from the plastic onnector sa ilalim nang hood tapos dun mo pa-bugahan nang power spray sa mga car wash boy. Sundutin mo pa din needle from time to time.
    Feb 2013
    #7864
    Yeah...already solved in adding washer fluid when I solve this. But I might as well have them replaced if cost is minimal. Thanks again!
    May 2010
    #7865
    Guys, i just noticed i am at 45k.. Whats for the PMS at this point? Would do it outside the casa for the first time, perhaps sa nearest petron service dito samen.. Thankyou..
    #7866
    wow, ang baba pa ng milage mo Sir.
    #7867
    Quote Originally Posted by uricacidman View Post
    Bro, di ko pa napapaayos. Nag konk out kasi yung compressor ko kaya na divert si budget. Kamusta shifting nung fm mo?
    Sent from my GT-N5100 using Tapatalk 4 Beta
    wala naman ako napapansin na nagiba sa shifting.. kakapalit ko lang din ng atf wala pang 1 year yun.. anyway, may nabasa yata ako nung nag backread ako, meron bang filter yun?
    #7868
    Quote Originally Posted by bigbrocx View Post
    yes, may filter yan, screen type and washable.
    #7869
    Quote Originally Posted by romeocharlie View Post
    Got it for 1.7k? Yun na ba yun? Kase para labor na lang ipagawa ke zafra..
    Personally i'd stay away from Zafra...
    #7870
    Quote Originally Posted by alrorskyz View Post
    Pero mahirap baklasin. May post si Junerski at BG about this
    Sent from my GT-N7100 using Tapatalk 2
    May 2010
    #7871
    *blue_gambit
    Any bad experiences sa zafra? Konti lang kase mga underchassis maintenance dito samen sa batangas.. Ok naman pakitungo nila saken, then sila din nirerefer nun mga supplier dito ng car parts (or is it because of business tie-ups) madami din ngpapagawa sa kanila, from LGU service vehicles to big/small companies dito samen.. kaya i did assume na ok sila.. Medyo bago pa lang din kase ako nagmmaintain ng sasakyan kaya siguro im learning the ways of it..
    #7872
    *blue_gambit
    Ang daming horror stories ng Zafra dito sa tsikot kasi at madaming tsikoteer nagsasabing iwasan itong Zafra, kasama ng Rapide.
    May 2010
    #7873
    Thanks sa warning mga sir, hanap na lng ako iba kung anuman... Maraming salamat...
    Jul 2013
    #7874
    Quote Originally Posted by paj4x4 View Post
    +1 na re repair yan. Just bring it to either Wizard along Morato or to Rey's electrical shop in Cubao. Easy fix lang yan.
    Sent from my GT-P3100 using Tapatalk 4 Beta
    Malaking bagay po ba un fan doon? Napansin ko un aircon namin nawawala lamig pag naka on un sa rear.. inayos na before sa aves tinanggal nila heater ko para daw mas malamig.. ewan ko kung may effect pero ngayon di na ganun kalamig e.. san ba may free estimate at magaling gumawa ng aircon ng pajero natin?
    Also noticed na nagblink ng mahina un gauge ko pag nagsignal ako ng left or right.. naka volt stabilizer po ako at turbo timee at everytime na nagrereverse ako lagi bumabagsak voltage ko sa 11.9 may nakaexperience na po ba sainyo ng ganito?
    #7875
    saan part kaya makikita yun filter? hindi kaya madumi kaya nailaw yun A/T..
    #7876
    Pag binaba mo yun oil pan ng transmission, makikita mo doon yun filter
    Mar 2003
    #7877
    i dont know how accurate, but nung na bypass ko heater ng aircon parang lumamig nga aircon ko. wala akong patunay pero parang lumamig talaga. sa casa ko pinagawa sabi nga ng mechanic lalamig yung aircon but di ako naniwala, pero lumamig nga,
    hula ko lang, maybe kahit sarado yung heater core may init parin na nacoconduct through the coolant sa heater core, since ang liquid nga mabilis mag conduct ng init, nageequalize yung temperature ng liquids within the system, kasi both radiator and heater core contain coolant. nagkaka heat transfer, bakameronsa inyo may idea
    Jul 2013
    #7878
    Lumamig naman aircon ko nun inalis un heater.. after ilang months.. pag naka on un likod.. humihina un harap.. ano kaya problem neto? Sana may marecommend kayong shop na magaling gumawa ng pajero natin
    #7879
    guys.. nagsstuck clutch ko sa sahig.. hehe kailangan hilain palabas para lumabas..
    wala naman signs ng tulo sa master cylinder.. ano kaya problema? hindi ko pinapalitan liquid ng clutch ko.. ever.. hehe
    any tips/clues?:D
    Nov 2011
    #7880
    Quote Originally Posted by AC View Post
    any tips/clues?:D
    sir AC maybe sa slave cylinder near the tranny meron leak kung wala sa master
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
