thank you sir.. pabuksan ko nga buksan sa mekaniko.. hehe parusa mag drive.. not to mention delikado... hehe
Last week I had a change oil and filter. Then pag nagstart sa umaga ayaw tumuloy as in nag ka crank and fire pero namamatay. But once you step on the accelerator a bit, ok na sya for the day. But the next morning same same na naman. Before this, one click lang sya without stepping on the pedal. Also, may leak na yung oil sending unit lately. Please comment and suggest. As always, thank you in advance for your helpful feedbacks.
First, have your oil sending unit replaced since sabi mo may problema na.
I would like to ask kung nagpalit ka rin ba ng fuel filter? Kasi based sa statement mo, parang kulang yun pumapasok na krudo sa makina, kaya kelangan mo pa apakan yun accel pedal. Baka hindi na-bleed nang mabuti yun injectors.
Thanks for the feedback. Oo nga, nakalimutan ko yung fuel filter. Baka nag clog na. Pero teka and pardon the ignorance. . Ano naman yung bleeding ng injectors. Kelan ba to ginagawa? Hindi pa yata nakakatikim ng ganito yung Pajero ko. Thanks again.
Pardon the ignorance. Nag backread ako ng konti about bleeding injectors and was enlightened a bit When I have my fuel filter replaced, I will ask the mechanic to bleed injectors too. Thank you.
Sa wakas nakapag fog lamps na uli ako sa pajero.. okay lang daw 100watts na fogs? 55w lang kasi un piaa na nakakabit dati.. ngayon euroline na yellow 100watts..
depende kung kakayanin ng fuse mo... Kung Orig gamit mo na wiring ng FM meaning 1 fuse is used for the dash board lights and fog lights, I suggest di mo sya gamitin ng matagal. Bibigay malamang fuse mo and you will be running at night with a blind dash and instrument lights and fogs, but your headlight will still function enough to get you home... Based on experience..![]()
Panu ko po macheck kung 1 fuse lang? Pag nag on ako ng fogs ko naka on narin un gauges ko sir.. un na ba un?Thanks!
Edit:
Inalis ko un fuse sa loob ng hood.. fr fog lamp nakalagay base sa diagram na nakuha ko dito.. nawala fogs ko pero umiilaw parin un gauges ko.. ibig sabihin po ba safe ba ko sa 100w sa fogs?
sir CB...
naka hid po fogs ng fm namin.. mahina parin po.. wala kwenta.. maliit po yata kasi reflector.. tinangal ko nadin yung parang harang na lata para hindi nakakasilaw.. mahina talaga buga.. hehe
nagpachange oil ako kanina.. surprised ako after only 5k.. sobra dumi na pala ng k&n ko.. dahil kaya sa offroad?
btw may benta ako foglights led.. special prize for pajero tsikot peeps...
nag putik putik na sa dumi.. hehe
linisin ko mamayang gabi..
btw guys... sa mga naka k&n.. 800php nalang for pajero tsikot peeps..
aerosol type napo akin... sa iba squirt type.. thanks
sabi ko sayo AC eh madumi na yan yong akin nga every after 2 months ko nililinis kaya mabilis maubos yong recharger kit ko
sir nelany.. oonga e.. bilis pala magdumi ng k&n.. hehe
hindi pala totoo yung 20t miles.. hahahaha
mukhang every 5k nga yata cleaning dapat
bro..rols.. magkasing dumi tayo after 2 months mo? or hindi pa masyado sayo? wag mo muna linis pag hindi pa super dumi.. sayang.. hehe...
anyways... bigla humina pajero ko 2 months ago.. kaya ako nagtatanong dito about calibration.. hehe.. umok na uli.. ipagawa ko sana for 100k service ng pajero ko extend ko nalang siguro calibration tutal pinagawa ko siya nung 60k
guys.. ask ko nadin sainyo.. kasi... sabi ng nag cacalibrate.. tuning daw is 1200... adjust daw tappet etc etc..
nung nagpa change oil ako kanina.. sabi ng mekaninko.. wala daw tappet ang pajero ko.. di daw niya alam ano daw gagawin sa tuning...
ano po kaya ang tuning matatawag for 4d56? hehe.. meron ba ganun service? pang bawas vibration sana gusto ko para sa pajero ko..
update lang... sa question ko last week... about clutch cylinders... sira nga master and slave ko.. pinagawa ko na last week nung sabado... hehe kanina ko lang nakuha sinabay ko na change oil
was looking for seiken brand... yun kasi palagi ko binibili for elf.. pero.. wala ko mahanap.. used FIC.. sabi nila japan daw.. hehe sana maganda
master is 1200php slave is 750php
:D
thanks
