Page 391 of 718 FirstFirst ... 291341381387388389390391392393394395401441491 ... LastLast
Results 7,801 to 7,820 of 14348
    Feb 2013
    #7801
    mga sir , meron na po ba saatin mga fieldmaster tsikoteers nakapag 45mm suspension lift Ironman brand ? tumataas nga po ba? kasi sabi po sa UK at australia ung fieldmaster 45mm talaga ang taas sa gen2 . baka po pag nagpalit parehas lang. we are considering it kasi yung fieldmaster 4x4 AT namin parang sumasagad yung likod pag nalulubak sa probinsya sa mindoro. thank you!
    #7802
    what brand did you get? I usually buy Bosch. i buy by the box kasi share na yun sa mga L300 van namin, which has 4d56 engine.
    It's OEM Mitsubishi. I got it from Triton on Banawe where I usually get my Toyota and Mitsubishi parts. Though they give me good prices, they screw up from time to time by giving me the wrong part like with this fuel filter. It's been months since I got it from them so I don't think I can return it especially since the mechanic took off the plastic seal on it already.
    Oct 2009
    #7803
    ang alam ko wala pong cable yong speedometer ng FM speed sensor po yan nakakabit sa may transmission
    Jul 2013
    #7804
    newbie sa pajero guys! tanong ko lang po sana kung pano mababawasan un ingay sa ng fm natin..
    malaking tulong ba mag pa sound deadening? feel ko kasi marami ng maluwag sa loob ng koche e.. 2001 model na fm po..
    #7805
    Quote Originally Posted by grewupinapajero View Post
    sa gen2 ko medyo bagsak na yung spring.. nagpakabit po ako ng spacers sa banawe.. parang donut yung korte.. 500php magkabilaan.. mga last yr siguro.. so far.. ok pa naman..umangat ng 1 to 1.5" siguro yung likod...
    magkano po ang ironman suspension lift? ano po kasama sa kit? springs? shocks? thanks
    Quote Originally Posted by zairus View Post
    sa fm po namin.. sa loob nangagaling ang ingay.. pakiramdam ko sa mga upuan.. ehehehe
    Feb 2013
    #7806
    Quote Originally Posted by AC View Post
    just had mine quoted a week ago. kit include 4 shock absorbers (gas), 2 coil springs and torsion bar. in cebu price given to me was P45K...in manila i read only P38K.
    Jul 2013
    #7807
    sa fm po namin.. sa loob nangagaling ang ingay.. pakiramdam ko sa mga upuan.. ehehehe[/QUOTE]
    Mostly po sa upuan nga.. pero di na squeks ng leather e.. at mga sides ng pinto parang maingay na un loob..
    Feedback naman po sa mga naka deadening pads kung may tulong...
    #7808
    Feedback naman po sa mga naka deadening pads kung may tulong...[/QUOTE]
    Bakit hindi mo pabuksan yung parte na maingay para ma pasikipan mo kung maluwag na siya. Dapat walang ingay yang loob ng pinto.
    #7809
    sound deadening mats is for dulling out outside noise for improving in-car audio. I think all of our Fieldmasters produce noise from the inside emanating from our seats. My recommendation is to find the source and tighten whatever bolts and screws hold that particular part together. My squeaks predominantly come from the rear seats.
    Jul 2013
    #7810
    Na eliminate ko po un squeaks using foam.. iniipit ko sa upuan.. hiningi ko lang sa tabi tabing upholstery shop.. try niyo po un maninipis lang.. fold lang if maluwag.. un mga bolts gusto ko sana diy nalang sa mga doors e.. sana magawa ko ng maayos
    May 2010
    #7811
    Got my NB's+ for 1.2k.. Stil contemplating kung mag Euroline ako for the fogs.. 750 daw.. Ok na kaya?
    And ano ba mas ok na busina?
    - Hella Supertone * 1.8k
    - Bosch Europa black * 2.3k
    Alin bang for the buck? And ano pros and cons nun 2 horn choices.. Thanks.
    Nov 2004
    #7812
    Ok na speedometer ko, 1.8k yung sensor brandnew! Ok daw gauge ko sensor lang busted. Sila jemson at pony na naghanap at nagkabit. Nagtanong din kasi ko kay motorix 3.5k speedo sensor taiwan lang, 10k kung gauge ang sira, yung speedo gauge lang yun di pa kasama fuel rpm etc. Laki na naman natipid kay jemson thanks sa paalala idol CB hehe
    Sent from my ifive MINI 2 using Forum Runner
    #7813
    Quote Originally Posted by romeocharlie View Post
    Euroline, kung yellow fogs yan, ok din yan.
    Sa busina, gamit ko Hella Supertone. Maganda ang tunog. Sarap ibabad sa mga pasaway na jeepney drivers
    Yun Bosch Europa, maganda din yan. Ika nga doon sa kabilang thread, parang busina ng lumang mga Chedeng.
    Ang inaalala ko lang sa Europa ay kung kakasya siya sa likod ng grill. Sa Hella Supertone, walang problema yan ikabit sa likod ng grill.
    Jan 2011
    #7814
    Mga bros malapit na ako mag shopping ng pang ilalim sa harapan naguumpisa na kasi ang langitngit. Napalitan ko palang dito yung upper bushings on both sides. Saan ako makakakita ng best deals for oem parts? Kung makakabigay din kayo ng price range per part malaking tulong yun. TIA
    Sent from my GT-N5100 using Tapatalk 4 Beta
    Jul 2013
    #7815
    San po nakakabili ng replacement case ng alarm natin?
    #7816
    Replacement case? Are you pertaining to the key fob? If you have lost the extra key fob and have only one remaining, might I suggest you have a new alarm system installed. Finding a shop that can provide the service of duplicating the frequency of an alarm key fob in Manila before for me was next to impossible. Anyway, the cost of an alarm system has significantly gone lower as compared to before.
    Jul 2013
    #7817
    Di po sir.. un casing lang mismo nun remote.. sira na kasi un rubber parts e
    Jul 2013
    #7818
    Guys sorry daming tanong.. un isang fan daw po sa engine.. ilalim na part di daw gumagana.. narerepair po ba un? Or saan sa banawe okay bumili ng surplus nun? Thanks!
    #7819
    Na re-repair yan sir, palit carbon brush lang. wag lang stuck-up yung motor.
    Jun 2004
    #7820
    +1 na re repair yan. Just bring it to either Wizard along Morato or to Rey's electrical shop in Cubao. Easy fix lang yan.
    Sent from my GT-P3100 using Tapatalk 4 Beta
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
