Yup, mas mura kera OEM na whole assymble.
*K.I.L.L. - pacheck mo din baka na-drain battery mo, if yes, then ibang problem din yun.
- - - Updated - - -
RT, yung return line alam ko kasi mahaba yung metal tube. So kelangan baklasin buo and bring to hydraulic shop?
- - - Updated - - -
That's right. There's a lot to take off with replacing the return hose. The return hose crosses underneath the engine which is why a part of it is metal.
Going back to my own fieldmaster, I tried starting it this morning and it did. When I got home last night, I fiddled with the battery terminals and I thought I felt something was loose but I couldn't really see it but this morning when I checked, it wasn't. Anyway, I'll keep on observing it and will post if I have any more issues.
- - - Updated - - -
Hmmmmm, does your dashboard indicators lit up even though the engine is running? If yes, you have an alternator problem. If not and you think your battery is not the problem, then you may have a starter motor problem. But first, have your battery checked. Mind you sir, how old is your battery and what brand of battery did you use?
Pwedeng ganun. Pwede din na kung ayaw mo pa-crimp, bili ka nalang ng hose clamp. Lagariin lang lumang hose hanggang sa pinakadulo ng crimp para naka-expose lang yun metal tube. Yun iba ganun ginagawa para mas madali lang magpalit ng hose. Yun sa akin naka-clamp nalang yun hose at hindi na crimped.
thanks for the link. i'll check later on.
no black smoke emits while cruising..minsa meron kapag tipong pataas un daan tas curves pa. kung tawagin lugar papunta
manila is Sta Fe, in nueva viscaya. ibang klaseng daan kasi dun.
then sa umaga lang once start nun rig.
other than that, wala nman.
hirap kasi dito probinsya, wala gaano matikas na shops and all.
but thanks anyways. pag luwas ko nlng, sikapin kong maipakita para back to hataw na nman.
Testa thanks sa tip. Ganun nalang gagawin ko para hindi na ako magbaklas. Easier and cheaper pa hehe thanksOriginally Posted by testament11
Btw, nagpalit na ako ng headlight bulbs to NPS. Laki ng improvement from stock. Napansin ko lang, ang dumi pala ng sockets nung sa akin. Kaya siguro mahina yung kuryente and mahina yung buga ng bulbs. Wala kasing takip yung sockets. Try ko palitan ng ceramic sockets na. Sana madali lang mag diy hehe
