Page 390 of 395 FirstFirst ... 290340380386387388389390391392393394 ... LastLast
Results 7,781 to 7,800 of 14348
    Aug 2014
    Ask if converted, mukhang converted at surplus.
    aio....
    Sent from my mobile phone using Tapatalk
    Feb 2017
    Hello masters,
    Ilang liters of ATF ang kailangan for Pajero Fieldmaster? Drain and clean filter po kasi ang gagawin. Not sure id ilan.
    Thanks
    Sent from my ONEPLUS A5010 using Tapatalk
    Mar 2003
    lsd install sa FM
    lsd install sa FM
    Nasira sir LSD ng FM niyo?
    Mar 2003
    nag kamali ako dati sa gear ratio. palit whole diff with lsd ginawa ko dati. iba pala yung ration sa harap. kaya binalik ko oem pinion and ring gear. yung lsd lang ang nilipat pala dapat. ngayon ok na uli 4x4 ko
    PB, ano difference at performance kung mali yung gear ratio mo?
    Mar 2003
    nelany, di mo. magagamit 4x4 pag di same ang gear ratio.
    high gear yung nabili ko dati na rear diff. mas mabilis takbo ko kaysa sa speedometer ng mga 10 percent. mas ok si high gear sa expressway cruising Mas mababa rpm
    Nov 2017
    Hirap lang yan sa ahon [emoji16]
    Mar 2003
    Di naman po sir going to bagyo 8 pax no problem naman
    So mas ok gamitin yan sa 4X2?
    Mga sir,
    May nakapag try na ba ng akebono brakes from lazada? Ang mura kasi compared sa casa na 3-4k ang isa.
    Jun 2006
    Mga paps, warning light came up in the dashboard. Comment naman kung ano possible error and where to fix. Have not used my pajero for 7 days, biglang umilaw kanina.
    Quote Originally Posted by dave_ph2000 View Post
    Check your fuel filter tsaka yung battery mo baka may problem din sa alternator.
    Sent from my SM-G965F using Tapatalk
    Jun 2006
    Boss san ba pwede dalhin na reliable and affordable shop sa Banaue? Baka may recommend kau. Andito ako sa area ngaun.
    Appreciate ur help.
    Appreciate ur help.
    Sorry late reply and I am not from that area. Not from MM kasi ako so not familiar with the place sir.
    Appreciate ur help.
    inquire via fb: zix performance. he works on most diesels eapecially mitsus
    Jan 2008
    looks like alternator problem.. baka bumigay yung regulator mo..
    Guys, alam nyo po ba kung san nakakabili ng door lock mechanism ng rear door for Gen2?
    Need lang ng tatay ko.
    Thanks!
    Quote Originally Posted by winter789 View Post
    Thanks!
    Search mo sa facebook sir yung PAJERO & 4x4 UNITED na group. Madami sellers dun sir.
    Feb 2019
    Ano kaya ang belt size for pajero fieldmaster 2005? What magandang brand? Pasensya na, i tried searching this thread pero sobrang haba na,... Thanks
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
