Page 240 of 718 FirstFirst ... 140190230236237238239240241242243244250290340 ... LastLast
Results 4,781 to 4,800 of 14348
    #4781
    CB, kailan ka pupunta sa Berrima for your devilsown installation?
    already ordered parts from US. sana by end of this month dumating na lahat ng parts ko hehe nag order na din ako ng boost controller and boost gauge. btw, did you do the washer mod?
    Mar 2012
    #4782
    pag coil spring, alam ko pwede balutan ng hose yun para mawala yung ingay.
    Quote Originally Posted by blue View Post
    sir zipspeed, the coil spring squeak was previously remedied by sir promdiboy by inserting a hose on the top and bottom ends of the spring. with regards to coil spring replacement, hindi na ba pantay ang tindig sir? if needs replacement na talaga, better to replace it by pairs para pareho sila ng spring rate.
    Sorry late reply. Thanks Sirs CB & Blue. Baka nga I will do the same. Pantay naman sila but its the noise thats bothering us. Actually after our long trip last week mas lumakas ang ingay.
    I think I need to find a good 4 x4 shop to have complete diagnosis. Pati na bearing, differential, shocks, etc... Just to be sure. may recommeded na shop si OTEP sa bandang Malabon area.
    #4783
    Quote Originally Posted by Zipspeed View Post
    Dr. G yata yun. sa A.Bonifacio lang hehe pero suggestion ko, joseph atutubo hehe both of them are good naman
    Mar 2012
    #4784
    Parang Offroad house ang name ng shop, sa may Navotas pala. May suggestion si Joseph dati to replace the differential...to Limited slip differential, tempting kaya lang mahal at P18 thousand. Isip isip muna, madaming magagawa ang P18T sa suspension
    #4785
    Ano model na order mo sa US? Suggestion ko lang mas maganda bumili ka na lang sa Berrima. Pag may problem replace agad nila. Tulad ng stage 2 ko sa kanila pag me problem ako change agad nila ng parts. Pag order ka pag me problem it will take time at mahal ang shipment cost. Di ka naman makakatipid ng malaki kung duon ka bumili.
    Im using mech boost controller.
    #4786
    stage2 sir hehe
    #4787
    stage2 sir hehe
    Waiting mode ka na lang pala!
    #4788
    Oo sir hehe decided to get it na din cause it is an investment to prolong the life of the engine na din naman. Tapos added power pa hehe
    Btw, san ka pala bumibili ng methanol? Thanks
    #4789
    Saan sa malabon area? I might know the place...
    #4790
    199 offroad house yata. No experience with 199. Pero ang alam ko, ok sila mag set up. Hindi ko lang alam if may mechanical ba sila. Ayaw mo kay joseph nalang? Worth it naman kahit malayo. Ako tiga tondo, pero kung major na, kay joseph ko parin dinadala. Basic pms sa suking mechanic ko nalang pinapagawa.
    #4791
    Ahh.. Tondo yan not malabon... hehehe
    CB 20petot yata yung denatured alchohol sa hardware yung parang bote ng rugby? pede yata yun sa alcohol injection na binili mo...
    Anu ginamit mong courier? pobox.ph ba?
    #4792
    Dyan sa Alyson sa G Araneta, lagpas pa ng Quezon Ave, malapit na sa dulo.
    #4793
    yan sir yung g araneta in between del monte and amoranto? magkano kuha mo? diyan ako kumuha ng tawas para sa pool
    #4794
    ok sir. check ko na din before ako magpunta kay Berrima for install. para ready na siya. same question din ako kay Zix hehe
    Quote Originally Posted by zix888 View Post
    sorry OT ito, Zix, totoo pala na tawas para sa pool para hindi mag lumot hehe
    #4795
    Huling bili ko last month ~ P1020 per carbuoy (20 liter container).
    May 2008
    #4796
    Having problems with my unit again. Hard starting in the morning, about 4-5 clicks before it starts. Akala namin busted glow plugs na naman but when our mechanic checked, all plugs were still working.
    Apparently, the fuse of the plugs tripped. Per their diagnosis, the plugs don't shut off after starting, causing the fuse to melt. What's broken is the control unit of the glow plugs. El Dorado quoted us 28k to replace it. Tama ba diagnosis?
    #4797
    Quote Originally Posted by Reepicheep View Post
    ito yung nasa right side foot well ba? parang computer board siya?
    Nasiraan na ako dati niyan sa Strada Gen 1. 14K quote nung control unit nga. If sobrang mahal para sa'yo, you can opt for a manual timer. Ikaw ang mag-papalamig sa umaga ng glow plug tapos start by turning the key. Tricky siya if marami gumagamit esp if sa morning pa nagpapalit ng driver. Pero sa experience ko, kahit 4 hours na nakalipas, basta umabot sa operating temp ang engine, once click lang yan dapat. Ako noon isa lang gumagamit ng ride kaya nag-manual na lang me, 7 seconds sa umaga, mga 5 seconds warm-up naman ng glow-plug sa lunchtime kapag pauwi na. Black box yun iirc.
    #4799
    Pano nasira sayo RT?
    Repicheep, try niyo muna linisin with contact cleaner.
    May 2008
    #4800
    As much as possible, we try to preserve the OEM setup. Anyway, kung sira na nga, palitan na lang siguro. May surplus kaya nito?
    Will try. Thanks!
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
