Page 233 of 718 FirstFirst ... 133183223229230231232233234235236237243283333 ... LastLast
Results 4,641 to 4,660 of 14348
    #4641
    #4642
    Quote Originally Posted by boybig View Post
    bossing ask ko lang, anu ba size ng belts ng 4m40.. both aircon & alternator belts? chaka anu magandang brand gamitin?
    Alternator - MH014050/014055, Mitsuboshi D1-4055 or Bando RPF 2385/2380 or Gates 9.5x975
    AC belt - MB568413 or Mitsuboshi RECMF6360 or Bando RPF A-35
    Get the ones with cogged teeth.
    #4644
    RT, alternator x2 tapos AC x1 tama ba? bibili ako ng Gates this weekend. by any chance meron ka ba nung gates number for AC?
    Yup 2 yung alternator at 1 yung sa AC. Mitsuboshi RECMF6360 at Bando A-35 lang yung nakita ko eh, walang gates na counterpart. Kaya mitsuboshi japan na yung biili ko.
    Pero ito ewan ko kung tama ha. Gates 6468MC. Basta 13mm x 950mm naman ata yung sa AC. May bosch counterpat din sa site na yan.
    http://seekpart24.com/mitsubishi/paj...elt-set-100080
    May 2011
    #4646
    maraming salamat bossing... makaikot sa weekend to buy...
    #4647
    Mitsubishi Pajero II (V3_W, V2_W, V4_W) 2.8 TD (V46W) V-Belt / Set
    sige check ko nalang sa distributor ng Gates. Bando size nalang bibigay ko sa kanila.
    si Warren wala yatang v-belts e.
    btw, yung "usage number" na nasa site yung important sa mga belt center. yan yung reference nila e hehe
    #4648
    Quote Originally Posted by kurtyuan03 View Post
    Mga ka Pajero.. Pa help naman po..
    Kaka pa calibrate ko lang po ng injection ..all good naman po at sobrang nakaka amazed how the power increases ng auto..napansin ko na medyo nanginginig sya when you put it on "P" "R" at "N" .at namamatayan paminsan minsan, Pinadjust ko po ang idle,nagpalit nadin ng fuel hose at fuel filter at eto po ang catch..yung gas cable nya..is hangang dun lang sa first insert nakakabit (hindi po sya nakadetso sa injection pump po yata ang tawag dun) maganda po ang takbo ng auto..
    Nung napansin ko po na ang gas cable ay hindi naka kabit hangang injection pump..ikinabit ko po ito at ang result is matamlay ang takbo and ayaw humatak ng makina.. tumataas ang idle nya hangang 1000 rpm kapag naka "P" and "N"..at nag nonormal idle sa "D" and the rest.
    SO ngayon po ay hindi ko nalang kinabit ang cable derecho sa Injection pump..hangang sa first insert na lang po kasi mas maganda ang takbo ng makina pag ganun..Nagwowory lang po ako kasi baka masama po yun sa engine at may madamay pa na masira..at nagtataka po ako bakit pag kinabit ko ang gas cable hangang injection pump or hangang dulo ay pumapangit ang takbo.
    Ang Unit ko po is Pajero SWB JDM (converted) 4d56 engine AT tranny.
    I-try ko po makuhannan ng pics para sa mas malinaw..
    Maraming salamat po..
    bro, possible nai-connect mo sa choke yun cable mo kaya nagwa-wild ang takbo.
    dapat connected ang choke cable sa manual throttle knob.
    for the accelerator cable, try to follow as per below:
    hth!
    #4649
    Maraming salamat po sir Blue.. I will do this and i update ko po kayo..Thanks so much sir!!
    #4650
    RT, mag kano kuha mo sa Delo 400?
    Sep 2009
    #4651
    I hope i am not off topic, could anyone please explain the difference between a Pajero CK and Shogun? Do they belong to the same series? will appreciate enlightenment regarding my confusion.
    Jul 2011
    #4652
    Good Day to All, newbie here, actually been lurking around here for quite some time, reading every topic queries and replies of pajero experts here and I really learned a lot from this forum, I have a 2005 model Montero Sport, with 4m40 engine. My problem now is the ABS system, brought my car to mitsubishi casa to be checked and after it undergone diagnostics, mechanics there informed me of three (3) ABS sensors malfunctions that need to be replaced, they gave me price of 10K +++ each, I inquire at El Dorado and gave me almost the same price, and now I am seeking help for members here who can give me some info on where can I buy ABS sensor with cheaper price, even surplus stores that might offer such parts, thank you very much.
    P248/ltr and yung 1 5ltr jug eh P1,236. Sa auto supply na distributor ng Caltex yan kaya mura.
    Yung bando na orig japan for alternator pala ay Bando RPF 2385 9.5 x 975 yung complete name.
    Quote Originally Posted by ADARTSE View Post
    yes, basically they are the same. Gen 3. Mk3 is also a name used by Australians. BK is Gen 3.5 land dito sa atin but technicalle gen 4. Yung current model gen 4 pa din, wala pa yung gen 4.5 na 2nd gen VGT equipped.
    Mitsubishi Pajero Family Tree
    #4655
    Quote Originally Posted by totonski View Post
    Try to visit joseph atutubo. He might be able to help you.
    Jul 2011
    #4656
    Thank You Sir Crazy Boy, I heard so much of Joseph Atutubo, and I know he is highly regarded in this forum and and other pajero forum site, Sir where is his shop located? or is there any contact nos. that I could reach him.
    Sep 2009
    #4657
    Thanks RT, So which between the two Gen 3 was locally sold here in the Phils?
    Gen 3.5 tawag nila, yung NS Pajero afaik.
    #4659
    Yung install mas madali na yun. Kaya na ng electrician yan. Bracket lang naman kailangan e. Pero tingin tingin muna ako. Kailangan sealed type e. Mababasa kasi yan. Unlike pag retrofit sa HL na hindi nababasa
    mahina talaga buga nitong oems
    kaya during rainy seasons, retrofit din ng mas malaki na fogs, mas effective, bought a separate cover and trimmed. 4" diameter, used the same bracket, additional flat bar na naka-screw lang din.
    retrofitting a projector is much easier if you already have the oem bracket. kung wala naman, pwede naman gayahin, para bolt on lang din siya.Â*
    #4660
    sa Multinational Village garage niya. dun siya gumagawa. try to call him for appointment.
    Joseph Atutubo 09178405942
    Quote Originally Posted by zix888 View Post
    zix, if ever pala pa-retrofit ako mas maganda pa-copy ko na yung oem brackets para pwede pa-copy ng iba.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
