Page 234 of 718 FirstFirst ... 134184224230231232233234235236237238244284334 ... LastLast
Results 4,661 to 4,680 of 14348
    May 2011
    #4661
    sige check ko nalang sa distributor ng Gates. Bando size nalang bibigay ko sa kanila.
    si Warren wala yatang v-belts e.
    btw, yung "usage number" na nasa site yung important sa mga belt center. yan yung reference nila e hehe
    mga bossing, anu mas magandang brand mitsuboshi o bando? may negative feedback ba sa kanila? tenks sa magrereply...
    #4662
    sa Multinational Village garage niya. dun siya gumagawa. try to call him for appointment.
    Joseph Atutubo 09178405942
    zix, if ever pala pa-retrofit ako mas maganda pa-copy ko na yung oem brackets para pwede pa-copy ng iba.
    yes sir, yun ang dapat para hindi na gagalawin yung set up mo pag naretrofit na. usually projectors from TRS eh ranging from 2.5"-3.5" dia so kahit alin dun pwede. naisip ko nga yung bi-xenon na kunin para nag high beam din yung fogs.
    #4663
    Quote Originally Posted by boybig View Post
    mitsuboshi is the OEM brand installed sa pajero so i guess its better... although some car manufacturers (like isuzu) use bando as their OEM brand for the belts of their vehicles.
    As long as you get the japan made cogged tooth v-belt tingin ko pareho naman yang matibay. Mas mabenta pa nga bando but as per junerski, Mitsuboshi kasi OEM natin kaya yun din pinili ko.
    May 2011
    #4665
    maraming salamas mga bossing!! makahanap nga bukas ng mitsuboshi...
    #4666
    mitsuboshi also for me since they are oem installed.
    #4667
    sir zix, how do you attach the fog rectangular cover, clip type ba sya or by screw?
    mine kasi is one-piece together with the bumper corners na e.
    #4668
    Quote Originally Posted by blue View Post
    the oem bracket has that slot where you will screw the rectangular cover thru that small hole( blue arrow )
    when retrofitted a bigger fogs, wala na pagscrew yung rectangular cover, Â*kaya custom hook na lang, using spring hooks( custom hook to oem bracket arm)
    #4669
    P248/ltr and yung 1 5ltr jug eh P1,236. Sa auto supply na distributor ng Caltex yan kaya mura.
    Yung bando na orig japan for alternator pala ay Bando RPF 2385 9.5 x 975 yung complete name.
    RT, salamat. Makabili na para maka pag stock para sa next oil change.
    #4670
    Quote Originally Posted by zix888 View Post
    Ganito siya.
    #4671
    [QUOTE=zix888;1992931]the oem bracket has that slot where you will screw the rectangular cover thru that small hole( blue arrow )
    got it sir! thanks!
    #4672
    Bro yung fog lamps ko napundi so papapalitan ko sana ng bumbilya..kaso loose thread na daw turnilyo so hindi matangal...kelangan daw baklasin yung bumper....kaya ibabalik ko nalang sa ibang araw kasi matagal daw gawin...
    Btw bumalik nanaman yung sakit ng paj ko..pag natratrapik humihilaw yung aircon pag umandar na lumalamig uli...aux fan kaya ulit to?
    Quote Originally Posted by oliver1013 View Post
    Malamang bro. Kapag stationary hindi na kaya i-dissipate yung heat eh. Pero kapag bumibiyahe kasi, kahit papano nakakatulong sa pag-cool down ng buong engine bay.
    #4674
    Yun nga rin duda ko kasi malamig naman pag tumatakbo o kaya pag kakaalis lang pagtapos iparada... San ba mura ang ng aux fan dati singil sakin parang 2500 ata motor lang
    #4675
    Yung fog lights, sa akin dati hindi na tinangal yung bumper. Yung rectangular lang takip posted above.
    Regarding the aux fan, kay jemson ako nagpagawa. Sealed type daw sa atin kaya hindi repairable. Nakahanap ng exact size na motor na pang toyota. Galing daw land cruiser. 1.2 -1.4k yung motor. 300 yung labor. Buong front part baklas.
    #4676
    May chance pala mag overheat pag sira aux fan. Pati compressor baka masira kasi mag high pressure yung system.
    #4677
    Yung aux fan ng aircon ko ay ni repair ni Rey's electrical sa Marikina. Singil sa akin ay Php 500 ~ 3 years ago. Ito yung dahilan kung bakit hindi gumagana ng husto yung aircon. So far ok pa rin yung aux fan. Normally palit lang siya ng carbon brush. Pag sunog na hindi na ma rerepair.
    #4678
    Nelany, repairable pala? Kala ko sealed type siya.
    Pa-repair ko yung akin. Para kung may kailangan pwedeng hiraman nalang muna hehe
    #4679
    Yup, binaklas nila yung fan. Yung nag recommend na pa repair sa kanila ay yung RAE Aircon sa katabi nila nung pina check ko yung aircon. Instead daw na palitan ng bagong aux fan pa repair nalang daw sa Rey electrical. Pina ikut nila yung fan at umandar kaya sabi nila ay carbon brush lang ang papalitan.
    #4680
    Ah. Yung tinoktok ng screw driver? Hehe ganun nga din nangyari sa akin. Atleast now alam ko na repairable pala siya. Buti di ko iniwan yung motor ko.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
