Page 232 of 718 FirstFirst ... 132182222228229230231232233234235236242282332 ... LastLast
Results 4,621 to 4,640 of 14348
    #4621
    sir zipspeed, the coil spring squeak was previously remedied by sir promdiboy by inserting a hose on the top and bottom ends of the spring. with regards to coil spring replacement, hindi na ba pantay ang tindig sir? if needs replacement na talaga, better to replace it by pairs para pareho sila ng spring rate.
    #4622
    Ok join ako dyan!
    hanap tayo sa TRS nung kapareho ng 70mm. tapos pa-ship natin dito.
    Quote Originally Posted by blue View Post
    yan din naalala ko na post ni PB dati hehe
    #4623
    nelany, with the alcohol injection, kaya pa ba ng brakes mo yung power? also, ano exactly ginagawa sa diesel tuning ni berrima? i suppose sa injection pump siya gumagawa?
    #4624
    Mas mabilis lang naman yung accelaration niya dahil sa devilsown kaya hindi ka mahuhuli sa arangkada at sa mabilisan overtake. Plus walang usok maski sudden accelaration.
    Yung Berrima tuning ay itutuneup yung makina mo. Papakita nila yung before and after the tuning with a graph print out ng power ng makina. Yung pinalagyan ko ng devilsown yung Crosswind ko at pina tune ang layo ng performance after that. Randam mo yung changes ng ride mo. Kaya lang nga madugo ang presyo, I paid 36K for these pero masaya naman ako sa resulta.
    Di ko nakita yung ginalaw kasi nakakahiya pumanik nung pinasok na yung ride ko gawana nila.
    #4625
    ah. kasi since non-ecu ride natin, most likely fine tune sa injection pump ginawa and timing siguro hehe iniisip ko kasi yung braking power ng FM mo after devilsown. since mejo mahina stock brakes natin. may nabasa ako na pwede yung master cylinder yata na pang 3.5L sa FM natin.
    ito yung mga maliliit na from TRS. basa pa ako kung meron pa ba iba.
    #4626
    bro, madali lang bang butasan yun bumper corners ng fm natin for the fogs? i'm planning to diy na lang on my rig.
    pa-share naman ng tips!
    tia!
    sir yung 2002 special ed. oem na naka screw yung rectangular cover ng fogs. but we did a diy on a 2001, madali lang butasan.
    #4627
    Quote Originally Posted by zix888 View Post
    hindi na pala kailangang butasan yun rectangular covers ng fogs, yun center na lang talaga.
    thanks sir!
    #4628
    thanks sir!
    ang maging problem lang naman kapag hindi mo gagawin custom cover yung rectangular is yung pag adjust ng focus, dudukutin mo sa likod yun, mahirap. tsaka everytime maglinis ka nung assy ng projector, baklas bumper ka, mas matrabaho
    Aug 2009
    #4629
    sir 9701, kalingan pa din nag-auto on-off ang intercooler fan, this is to lengthen the life of the fan motor.
    others installed manual switch to the motor, they turned it off if they are moving and on if are stuck in traffic.
    but be reminded that the turbo kicks-in around 60kph, intercooler likewise will work efficiently cooling down exhaust gases back to the engine during these speeds and intermittently turn itself on-off as per required. hth!
    Noted with thanks Sir Blue...hirap nga lang maghanap. Order basis pa daw sa Mitsu Plant
    #4630
    CB, o sige check mo kung ano ang fit sa FM natin then order tayo sa site nila. Meron dapat na mahusay na installer otherwise magiging palpak ito. Ano kaya ginagamit ni garyq?
    Blue, meron sagot sa iyo so garyq tungkol sa fog light?
    #4631
    Yung install mas madali na yun. Kaya na ng electrician yan. Bracket lang naman kailangan e. Pero tingin tingin muna ako. Kailangan sealed type e. Mababasa kasi yan. Unlike pag retrofit sa HL na hindi nababasa
    #4632
    Any recommended shop para sa retrofit ng projector lamp sa HL kung sa iyo gamit?
    #4633
    si joseph atotubo nagreretrofit ng projectors sa pajero. ...may mga kinabitan na siya from PPAC
    #4634
    Quote Originally Posted by junerski View Post
    yep, pag headlight si joseph din suggestion ko. actually anything related sa pajero na maiisip mo, si joseph talaga ma-recommend ko hehe
    #4635
    Meron na kayang mag pa install dito at mag kano inabot? Wait ako ng feedback.
    May 2011
    #4636
    bossing ask ko lang, anu ba size ng belts ng 4m40.. both aircon & alternator belts? chaka anu magandang brand gamitin?
    #4637
    thanks sir zix, manual adjustments na nga mangyayari and trial and error.
    sir nelany, here's garyq's response: blue, for fogs 14k, headlights 19k or 24k
    yun nai-post ni sir cb magandang mga projectors, i think they are bi-xenons usually installed for headlights.
    for fogs, without hi-low na siguro ako (single low beam).
    pwede nga din pala kay sir joseph a. painstall but any idea how much?
    i heard may discounts daw ppac members, tsikot members kaya meron din?
    #4638
    ang alam ko meron si joseph binebenta na projectors din. China made. better text him to be sure nalang. nakakatempt yung 14k na foglights ni gary. kaso wala pa akong budget ngayon. kaya tingin tingin muna. and kailangan sealed type e. hindi siya pareho dun sa mga ordinary na pang HL.
    btw blue, nasabi ba ni gary kung anong klaseng bulb and ilang watts yung ballast?
    #4639
    hindi na ko sir nag proceed nang malaman ko yun price, i'm sure its well worth it naman but at this time my priority is change the shoes of my rig. kindly drop him pm po, he'll be more than glad to answer our queries.
    my sariling hid retrofit projectors discussion nga pala si sir garyq dito sa board under car lights lamp talk: http://tsikot.com/forums/car-lights-...s-garyq-67675/
    #4640
    Mga ka Pajero.. Pa help naman po..
    Kaka pa calibrate ko lang po ng injection ..all good naman po at sobrang nakaka amazed how the power increases ng auto..napansin ko na medyo nanginginig sya when you put it on "P" "R" at "N" .at namamatayan paminsan minsan, Pinadjust ko po ang idle,nagpalit nadin ng fuel hose at fuel filter at eto po ang catch..yung gas cable nya..is hangang dun lang sa first insert nakakabit (hindi po sya nakadetso sa injection pump po yata ang tawag dun) maganda po ang takbo ng auto..
    Nung napansin ko po na ang gas cable ay hindi naka kabit hangang injection pump..ikinabit ko po ito at ang result is matamlay ang takbo and ayaw humatak ng makina.. tumataas ang idle nya hangang 1000 rpm kapag naka "P" and "N"..at nag nonormal idle sa "D" and the rest.
    SO ngayon po ay hindi ko nalang kinabit ang cable derecho sa Injection pump..hangang sa first insert na lang po kasi mas maganda ang takbo ng makina pag ganun..Nagwowory lang po ako kasi baka masama po yun sa engine at may madamay pa na masira..at nagtataka po ako bakit pag kinabit ko ang gas cable hangang injection pump or hangang dulo ay pumapangit ang takbo.
    Ang Unit ko po is Pajero SWB JDM (converted) 4d56 engine AT tranny.
    I-try ko po makuhannan ng pics para sa mas malinaw..
    Maraming salamat po..
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
