Page 228 of 718 FirstFirst ... 128178218224225226227228229230231232238278328 ... LastLast
Results 4,541 to 4,560 of 14348
    Oct 2003
    #4541
    Hi fellow members. My wife just learned to drive and she bumped our pajero fieldmaster and broke the tail light frame. Where can I buy replacement aside from the casa? Any idea how much it will cost. Im from QC area.
    #4542
    Quote Originally Posted by blue View Post
    guys may nakapagkabit na ba sa inyo ng "no drill" parkng sensors? sabi ng iba kasi hindi daw pwede sa atin kasi metal daw bumpers natin. meron namang nagsasabi na mas pwede daw kasi yun buong bumper na mismo ang magiging sensor nya? (the sensor antenna is attached directly to the bumber via adhesive)
    or sa "drilled" sensors na lang talaga bagsak natin?
    tia!
    Bakit ka pa mag sensor kung pede naman back-up camera? hehehe
    #4543
    Quote Originally Posted by levi View Post
    since qc ka sir, sa banawe ka na lang maghanap... not sure though sa pricing.
    #4544
    Quote Originally Posted by acertan View Post
    guys patulong naman
    san kaya ok ipagawa or pa maintenance also idea sa price:
    change oil
    oil pan gasket
    oil filter? what brand ok?
    timing belt
    timing belt pulley
    camshaft oil seal
    crankshaft oil seal
    valve timing pulley
    timing belt adjuster
    also yung replacement ng tps sensor kasi putol yung wires sa sensor mismo and adjustment ng kickdown cable i followed the distance on manual pero delayed or hirap mag 100km/h needs 3k rev para sumampa dun if not 80km/h lang max around 2.5k rev
    kung sa north/qc/banawe... mcm autoworks
    kung sa south/laspinas/paranaque... joseph atutubo
    kung sa east/marikina/pasig/antipolo... bosch eco-tech autoserve
    lahat ng may ari ng mga shop na yan knowledgeable sa pajero dahil owner rin sila ng pajero.hehe... contact details pakisearch na lang sa google for sure lalalabas yan.
    #4545
    Quote Originally Posted by ek2jayvee View Post
    sir nelany, where did you get these fittings? thanks.
    Sa suking hardware. Pina bili ko lang siya at sa binondo raw niya nabili ito. Di na matandaan yung store name.
    #4546
    Both pwede. Yung sensor type maski madilim o raining pwede niyang i sense di na mag re rely sa vision mo.
    Dec 2009
    #4547
    thanks, ill try to call now sana open sila this long weekend ko kasi papagawa and pede mabantayan sobra busy sa office
    Quote Originally Posted by junerski View Post
    Dec 2009
    #4548
    btw san pala mura yung depo headlight for gen 2? same lang sa fm yun diba? i got projector lens na kasi kaso yung salamin eh frosted so useless sabog din buga. nasa magkano ang pair ng depo lens and san mura? thanks
    Dec 2009
    #4549
    i just called bakit ganun di nya alam yung sinasabi ko na adjustment ng kickdown cable and pinapapunta nya ko dun sa calibration ng injection pump ?_?
    tapos nung sinabi ko na i replace na lahat yung nasa taas yung selected parts nalang daw ang i replace yung mga oil seal kahit daw wag na. labor is 2k for timing belt and replace/cleaning of oilpan gasket.
    ill try to call j. atutubo now
    May 2011
    #4550
    bossing, san ba ang bosch ecotech autoserve?
    #4551
    thanks bg! actually tama si nelany, i'll install both. i have already planned a location for the reverse cam, yun type of sensor lang talaga concern ko.
    pwede ba talaga "no drill" parking sensors sa metal bumpers natin?
    thanks ulit guys!
    Nov 2004
    #4552
    bro, sent you a pm but i think your mailbox has exceed quota. anyway musta na yun general grabber aw tires mo, ok pa ba upod nya? hindi naman maingay sa highway? can you recommend this tire to us? i need to replace my ageing michelin tires (makapal pa naman but 10 years na e) but tipid mode uli ako.
    i read in the previous board na 10t per set of four yun kuha mo, kindly pm where you bought it and their contact numbers.
    tia!
    magpapalit na din po ako ng tires, meron pala 10t per set of 4 na, general grabber AT na yun? di na ba ito available? ano po kaya nasa same price range nya na ok naman feedback, AT or HT sana white lettered.
    fu question yung bridgetone ba magkano price range and ano recommeded size? Thanks!
    #4553
    parang wala na daw ata stock sabi ni nelany, interested din sana ako e.
    oem size ng fm natin 265/70R16 pero pwede din mas malapad 275, kaya lang mas mahal.
    price ng bridgestone 265/70R16 depende sa store sir, pero yun H/T is around P7,900 and the A/T mga P9,200 daw.
    #4554
    thanks ulit guys!
    Yung gamit ko uung di dikit. Ayaw lo mung binubutas sa bumper. Experience lo dyan e yung hole at hindi standard. Pag wala ka ng mabili ng dati mo ay mag bubutas ka uli para mag kasya.
    #4555
    nakakita din ako custom mounting right below the bumper, flat bar yung ginamit, maliit lang naman, pero pansin nga lang na parang may naka-hang sa bumper. ayaw din mabutas, kagandahan lang, walang wire na gumapang sa bumper
    #4556
    Quote Originally Posted by zix888 View Post
    Ayaw ko kasing mag butas ng bumper. Pag meron ibang type na back sensor lumabas later on wala na pag asang mag palit. Experience ko sa crosswind ko ay nag palit na ako ng 3x lahat iba ang size kaya bawat palit palit din ng size ng butas. Buti na lang na meron bullbar sa likod ng buper kaya siya lang ang binubutas. Pag ayaw na palit lang ako ng bullbar at hindi yung orig na bumper.
    Nov 2004
    #4557
    Thanks ser blue. Wow 8-9k each pala brisgetone... Sayang yung kay ser nelany, 10k set of 4 na. Yung roadstone made in korea(white lettered ht or at) any info mga boss magkano pricing and source? Wala pa ba westlake na pang suv?
    #4558
    Quote Originally Posted by halimaw View Post
    Mas mura yata a/t ng yokohama. Support the local industry hehe
    Mar 2012
    #4559
    Mga kuyang,
    May nagpalit na ba sa inyo ng rear axle bearing? Parang dun nangagling ingay sa likod ng FM. Hindi pa nabaklas pero one piece lang daw yun. Based on my canvass, eto mga prices:
    Best colt- 850 one piece Koyo brand
    Mitsu parts- 1100 one piece koyo brand
    Motorix- 1200 same brand
    Eldorado- Retainer: 900 / Bearing- 2600 Original parts
    Baka may experience na kayo dito, pa share naman... thanks
    #4560
    Quote Originally Posted by Zipspeed View Post
    Mga kuyang,
    If you have the bearning part number, you can buy it at any bearning center
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
