Page 222 of 718 FirstFirst ... 122172212218219220221222223224225226232272322 ... LastLast
Results 4,421 to 4,440 of 14348
    #4421
    Quote Originally Posted by halimaw View Post
    Naginquire po ako sakanila ser 4k flat black 5.5k w/ paint... Baka sakali sana may mas mura, 3.5k w/ paint meron kaya ganun na maayos din gawa?
    manual set lang kung ganun
    #4422
    Nagpakabit po ako ng apexi turbo timer sa S4S, ask ko lang sa mga ganito din TT kung pag ba manual mode set ko sa 1min then off ko na ignition tapos countdown na sya then off na engine, next on ko ignition start bumabalik sa 30secs yung timer(wala talaga memory?), tsaka pala pag off ng engine after mag countdown namamatay din yung Turbo Timer? Thanks.
    sir nun kinabit ba yun TT may inalis b na wire dun sa alarm, connected yata sa starter yun? ganon kasi ginawa noon nung nagpagawa ako, hindi ko alam kung dapat ba alisin yun.. hindi kasi nagana kapag nakaconnect yun wire.. btw, code alarm pala yun alarm na gamit ko..
    #4423
    Sa ganyan presyo, hanap ka nalang ng OEM. Sa motorix meron
    Feb 2012
    #4424
    sir pwede ba ikabit yan overrider sa gen2?
    #4425
    Quote Originally Posted by EA622 View Post
    hindi ko lang sure sir. best call motorix to inquire.
    got in to a minor fender bender with the king of the road...
    any suggestions kung san pwede magpa-mag wheel repair? parang na-gutter yung lip ng wheels ko.
    ^ Bad trip yan sir CB. tsk tsk
    #4427
    parang hindi naman nagalaw yung body, tama ba? yung plastic iinitan lang yan. pic of your wheel?
    #4428
    Ouch Bro...
    If mahilig ka mag D.I.Y. pede masilya tsaka Spary Paint.. or Ask mo mga paint shops kaya nila yan..
    #4429
    for our reference...
    symptoms... hindi tumataas rpm kapag a/c is on, tapos makalampag dahil mababa nga ang rpm
    suking mekaniko term- idle up actuator
    mitsubishi technical term- a/c vacuum solenoid
    part number: MR117684
    casa price: P3,800 (didnt have the luxury of canvassing; urgent eh)
    (medyo mahirap din hanapin ang part rarely daw nasisira buti nakatsamba sa casa at may 1pc pang stock)
    part location:
    eto itsura nung solenoid
    #4430
    Quote Originally Posted by zix888 View Post
    zix, post ko mamaya yung itsura ng mags ko.
    luckily i was able to charge the jeepney driver 1k. kahit papano menos gastos parin. hehe
    re: PM mo sa akin, sorry now ko lang napansin hehe please reserve 1 for me if meron pa. thanks!
    Nov 2004
    #4431
    Buti nagbigay ser cb ng pampagawa kahit pano bawas gastos. Hirap makabanggaan nyan mga jeep, tricycle, pedicab malamang lamang ala ibabayad sayo. Konting retoke lang kaya ng latero/pintor pati yung gutter like sayad sa mags...
    Nov 2004
    #4432
    Quote Originally Posted by bigbrocx View Post
    Di nakita ser pasensya na, ok naman yung alarm after install ng tt, pag countdown ng tt then arm ko alarm tapos pag off ng makina di naman bumubukas yung lock/alarm, hindi din umiingay o nagaalarm pag off ng engine, naka set ako sa half ng shock sensor. Pag on purpose susian ko at buksan pinto gumagana naman alarm.
    Problem ko lang talaga pag next start bumabalik sa defaults yung tt, pero pag baba ko handbrake before start di sya nabalik sa defaults...
    #4433
    sir, then sa wiring yung problem kung ganun.
    Nov 2006
    #4434
    Mga sirs tanong ko lang, I have a 3 door 4m40 subic pajero and i can only have 5 kms/liter consumption. Ask ko lang po if pina calibrate nyo ba or pinalitan lang ng noozles. Because i have a trusted mechanic that advised me not to calibrate the pump because it is still doing good also since i have no problem with hard starting or white smoke. Appreciate your advice. Thanks po
    #4435
    Quote Originally Posted by markstep128 View Post
    Ganyan talaga, the burden of having an A/T tranny and 4wd ability... ako around 6, give or take city driving dito sa Manila...
    Check mo yung ATF level mo while the engine is Warm... yung differential fluids din..
    ATF Dexron II or III
    Front & Rear diff is GL5 grade
    Transfer Case GL4 grade
    Nov 2006
    #4436
    Thanks sir.. Yung saken kasi 3 door lang eh and mostly hindi naman heavy traffic yung daan ko. palagi naman ako change ng atf every 10k and change oil every 5k.
    My mileage is about 150,000km. Will it make a big difference kaya sir if I change the nozzle tips??
    #4437
    Totoo lang yan din ang iniicip ko, you could have it checked... Update mo rin results dito. If me improve yung FC mo I'll try it too...
    Nov 2006
    #4438
    JDM din ba yung Pajero mo sir blue_gambit? I heard iba daw yung tuning ng engine natin compare sa local 4m40 then mas matakaw sa krudo. Is it true?
    #4439
    Same engine pero iba injection pump. On paper, dapat mas matipid yung jdm kasi efi na siya.
    Sep 2009
    #4440
    Quote Originally Posted by MrYoso0226 View Post
    Hi guys, new member lang po ko dito sa forum. Need some advise kung may remedy pa ung leaky na sunroof namin, seems common issue ito sa mga JDM pajero since nag-wwear-off na ung rubber mouldings. Meron na po ba nakapagpaayos nito?
    Thanks po! :-)
    Try cleaning up muna yung dalawang drain canal sa may gilid (front side) using an ordinary g.i. wire /alambre ng sampayan.Baka kasi barado na at overflow na. If still may leak pa, lagyan mo na lang muna temporarily ng duct tape ung rubber nya ,wala yata kasing mabiling replacement,at alisin na lang after rainy season.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
