Good day!
San kaya meron mabibili na lift kit pajero gen 2. pati snorkel na rin. Salamat.
Good day!
bro, sent you a pm but i think your mailbox has exceed quota. anyway musta na yun general grabber aw tires mo, ok pa ba upod nya? hindi naman maingay sa highway? can you recommend this tire to us? i need to replace my ageing michelin tires (makapal pa naman but 10 years na e) but tipid mode uli ako.
i read in the previous board na 10t per set of four yun kuha mo, kindly pm where you bought it and their contact numbers.
tia!
Bro, hindi ko lam kung meron ka pang makukuha ka pang General Grabber na tire so maski maganda yung performance niya ay wala din.
Old na nga yung tires mo, check mo yung FAQ ng General Tire sa tire expiration. Hindi sila buy the expiration as long as yung tire was used properly at walang crack/micro crack. They just go with the industry standard thus the expiration.
sir share ko lang experience ko with the life span of tires. bought my FM bnew 2002, never used the spare tire, so talagang bago siya. decided to use it 2009(7yrs bnew unused)and paired it with a new one(para sa front tires). 3 mos lang, bumigay. sobra hinayang ako as in bago pa siya kung tutuusin eh. kaya since then medyo allergic nako sa age ng tires. good thing wala sa byahe nung bumigay, city driving lang na traffic, so rolling rolling lang. kung sa expessway ako inabot, delikado
thanks for all you concerns. tires usually have a safe lifespan of 5 to 7 yrs. more than that and the rubber starts to separate itself from the belts (steel or nylon). yun ngang spare tire ko sir e yun original bridgestone tire pa, 12 yrs old na and hindi pa nagagamit.![]()
bihira lang naman gamitin yun rig that's why i'm scouting already for new shoes, 5 pcs na kunin ko including the spare. i'll now include the spare in the tire rotations every 5tkm.
hayyy, gastos na naman! but the cost will be worth the life and safety of my family!![]()
regarding naman sa spare tire, since sa actual use ko eh talagang lumalabas na pang emergency lang, kahit luma eh pwede na. yung sa FM ko nga 2002-2009 ni hindi gumulong yung spare tire, considering i am averaging 35000kms a year, medyo sayang kung bibilhan ko pa ng bago. plus sa tire rotation, hindi magulo since 4 lang yung nag iikutan. yung 2011 MS ko nga binenta ko agad yung spare tire as bnew, replaced it with an old one, kasi nga naexperience ko nasira lang ng hindi nagamit.
guys you can try decoding your date of manufacture using this DOT example from my michelin:
DOT FKJC FLTX 3002
3002 - means it was manufactured 30th week of year 2002
X - michelin
FLT - company optional code
JC - tire size code
FK - means the tire was made in france facility
DOT - u.s. dept of transportation
likewise, DOT codes usually have 10 to 12 characters or numbers at the tire sidewall. if you get less than this, the true DOT code will be at the other side of the tire.
hth!
bossing paano ba tutuklapin yung plastic dome sa gilid ng cover ng compass/alt/inclinometer? ayokong pwersahin, baka kako may teknik... chaka sana step by step na rin kung panu... mahirap mag-back read, bukod sa andaming pages na, mabagal pa internet!!! salamats sa magrereply...
http://tsikot.com/forums/mitsubishi-...-compass-9129/
Basahin mo lang sir para may guide ka. You can use the search menu on the upper right for other inquiries sir.
guys patulong naman
san kaya ok ipagawa or pa maintenance also idea sa price:
change oil
oil pan gasket
oil filter? what brand ok?
timing belt
timing belt pulley
camshaft oil seal
crankshaft oil seal
valve timing pulley
timing belt adjuster
also yung replacement ng tps sensor kasi putol yung wires sa sensor mismo and adjustment ng kickdown cable i followed the distance on manual pero delayed or hirap mag 100km/h needs 3k rev para sumampa dun if not 80km/h lang max around 2.5k rev
guys may nakapagkabit na ba sa inyo ng "no drill" parkng sensors? sabi ng iba kasi hindi daw pwede sa atin kasi metal daw bumpers natin. meron namang nagsasabi na mas pwede daw kasi yun buong bumper na mismo ang magiging sensor nya? (the sensor antenna is attached directly to the bumber via adhesive)
or sa "drilled" sensors na lang talaga bagsak natin?
tia!
