thanks for the link na remote bypass.... san ba makakabili ng original na bosch or fleetguard or any other reliable oil filter brands?
salamat ulit!!
salamat ulit!!
pag Bosch, sa binondo alam ko
Amazon Merchandising
1127 G. Masangkay St.
Sta. Cruz Manila
2548580 2548581
WARREN AUTOMOTIVE CO
1054 BENAVIDEZ ST, BGY 294, ZONE 028 BINONDO
Manila, Metro Manila
244-1775
Bosch na gamit ko ngayon kasi ang mahal ng VIC tapos hindi ka pa sure kung orig ba or fake. and based doon sa thread, Bosch will be better than VIC or OEM.
For reference,
Bosch oil filter for 4M40 390pesos
Bosch oil filter for 4D56 350pesos
Bosch fuel filter for 4M40/4D56 350pesos
Bosch 0986450508 yung fuel filter number, OEM number ng sa 4m40/4d56 is XB220900.HTH
Fasten your seatbelt! Or else...Driven To Thrill!
Good day!
Mga pips, nag-DIY replacement po ako ng front stock shocks (h-m-s) to KYB gas-a-just. Mga 30 mins siguro inabot per side. Medyonahirapan lang ako sa pag-compress ng KYB kaya kinompress ko muna tapos pinatali ko sa kaibigan ko ng alambre para mas madali isalpak. Yung sensor harness tinanggal ko nalang. Next week naman likod papaplitan ko.
Pajero J-top JDM pala yung sasakyan.
KYB Gas-A-Just (mod # 554091) front Php 1,300 each (Rey's auto parts, Marikina). Excel-G naman 1,150
Suggestion ko lang, you can open the remote and clean the contact of the alarm using pencil eraser ( yung may nakasolder na portion). And also, take out the rubber buttons ( color gray) and wash and dry it complete, or wipe it with alcohol. 6 years na rin yung remote code alarm ko, but everytime I feel na mahina ang control I just open and clean the contacts.
Ako naman tanong ko lang mga kuyang.... re: A/T Mode switch, when do you use this and how do you know if it is working? My ride is 2005 FM...thanks
AFAIK, yung HOLD para i-hold nya sa certain gear yung A/T... magagamit ito kapag nakacruising speed kana sa expressway para hindi nagdodownshift yung paj... ganun ang gamit/ginagawa ko. based on my experience, kapag naka-HOLD habang papa-accelerate ka pa lang, parang nanginginig/sakal yung paj, until magshift to a higher gear.
ganda sana ka david kung na restore yung canvass para pwd top down, may nakita kasi ako taka top down ang ganda ng dating, yun nga lang di pwd iwan, ganda pang display, thanks ka david, kung makuha sana yung contact ng pinsan mo para makapag inquire, post na lang po , thanks
sir's, sira na kasi yung horn pad ko (yung plastic sa loob ng manibela), nadurog na and di na kayang ihold yung mga spring.
so ngayon wala ako busina, would you know kung merong nabibili nung plastic lang?
Nagtanong tanong ako sa surplusan ng manibela, 4k yung pang gen 2 kaso ayos pa naman manibela ko except lang dun sa plastic sa loob.
or baka may luma kayong manibela ng pang gen 2 pajero na pede ko bilhin mga sir.
yung mga aftermarket SW ba e may adapter for Pajero? may nakita kasi ako na Nardi kaso dilemma ko e baka wala ako makitang adapter.
you can reach me at 09178156174.
Good day mga kapaj Medyo masaklap nangyari sa FM ko Baka blow by na cya kc nagspill oil sa may oil cap mausok na cya pero wala namng langis sa exhaust pagpinastart aandar cya then mga 2-3 min manginginig na parang mauubusan ng fuel then patay engine then mga 5 cranks start cya ulit smooth naman andar and hatak. anong mas maganda parebuild Ko na Lang or change engine? Kong change engine San kaya magandang kumuha ng engine at kong rebuild San may magaling mag overhaul TIA
Tama si CB, fuel dilivery yung problem, hindi naman lack of power. Happened to my hi-lander a few years back ganyan. Sabi sa bosch a few months ago basic calibration would set me back more than 8K, kung overhaul yung injection pump dagdag na lang sa parts needed to be replaced. I'd recommend bringing it to Bosch Service centre ...
15w-40 sir gamit Ko Sir balitaan kita mamaya pagnasilip ng isang mekaniko Ko before Ko dalhin Kay Sir Dave
mga papi good afternoon, may ilaw ba sa dashboard yung hold and power button? pag switch ko sa hold wala ilaw ganun din sa power.. thanks
